Question about Coleman Heating & Cooling
Trying to figure where all the wires connect on a/c contacter?
Replacing contacter on outside a/c unit.i have all my wires connected,except one single black wire left.This is a single pole w/ 3 red wires on top left side of contacter and 2 black wires on top right side. There are 2 blue wires 1 on each side of contacter, and of course the 2 main power wires on either side on bottom. My problem is I dont quite know where this little black wire goes. Can you give me some insight?
  • 614 Answers
The two wires coming from your inside unit. They are the low voltage wires go on either side of the contactor coil. You should not have two blues on one side. see if the black wire comes from inside unit. Rus
Posted on Jun 25, 2009
What is the ground & neutral wire for a JPK15 GE Oven?
Assuming this is in the USA there are 3 wires normally in a 240 volt circuit. A black, red and white. Sometimes there is a bare ground wire. The white wire and bare ground wire are basically the same.They connect to the same place in the electrical box. The red and black are your power wires. They would connect top the outside connectors and the white and bare wire (if supplied) would connect to the center connector.
Mar 22, 2015 | GE JKP15 Electric Single Oven
No access to outside lines from one jack
Hi, What you can try is check the plug connection. If they are bent or broken. Replace the cable to and from the phone. If that is OK then you know the phone is the problem. Take it to be repaired.
Jan 20, 2014 | Panasonic KX-T7730 Corded Phone
Intermatic/GE 15071 digital wall timer - Connection Problem
1) GE 15071 (Tork SS20) is single-pole timer, and cannot be wired as 3-way timer
http://waterheatertimer.org/How-to-wire-timers.html
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
2) Check wire nuts are tight
Remove light bulb and spray WD40 into socket. Reinstall light bulb
3) Reset timer using paper clip or tooth pick, then reprogram to see if functionality is restored
4) Move timer to different location and see if it controls different light
5) Buy another 15071 from home depot.
Remove bad timer, take photo of wires, and install new timer same wire-for-wire.
Return bad timer to home depot in new package.
This is GE's extended warranty plan, but do not mention warranty at return desk.
5) Intermatic and GE are fierce rivals in the timer business.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Intermatic makes their own products. GE timers are generally made by Tork. Both companies sell timers worldwide.
Feb 09, 2013 | Hardware & Accessories
I have a 1755 3 rocker switch, http://communities.leviton.com/docs/DOC-1920, that I'm trying to install in place of an older switch. Here are the pictures for both, the new switch and old one:...
Ledio, I am unable to access specific photos on Picassa
https://plus.google.com/106982528064073343888/posts
I have downloaded instruction manual for 1755 rocker switch
This is ordinary triple-rocker-switch to control 3 different loads.
It is like having 3 single pole switches and each switch controls a separate light (Load)
This is single pole switch for 120Volt, and not suited necessarily for 240Volt loads.
Switch is not for 3-way application as typically found in hallway where 2 switches control same light.
1) You have 4 wires.
Electricians don't guess, they test.
There are 4 types of wires in 120Volt and 240V household wiring: Hot wire, Neutral wire, Load wire, and ground wire.
Load wire means the wire that connects to switch and goes to Light, fan, motor (load)
Hot wire always connects to one side of switch.
Neutral never connects to switch.
Load wires connect to side of switch opposite Hot wire.
Bare copper ground wire connects to any green ground screw.
2) One-and-only-one wire in each 120Volt electrical box is Hot. (assuming you are not replacing
3-way switch or working with 240V)
3) Separate all 4 wires for testing. Tape tester leads to wood sticks. Turn power ON.
Test each wire to bare ground wire. Tester will light up on Hot wire.
4) Hot is identified. Next, find the neutral wire if it is among the 4 wires.
Test Hot wire to all other wires in box, except bare ground wire.
Tester will light up on neutral wire.
Tester will not light up on Load wires.
5) NOT EVERY switch box has a neutral. Or the neutral wires can be twisted together and covered with wire nut and pushed to back of box.
The neutral may be up in the light fixture. Neutral located in ceiling box is typical with bathroom fan-light-heater combos.
If neutral is not one of the 4 wires, then don't worry about the neutral connection because it will already be wired together.
6) Image of 1755 switch shows 1 screw terminal on the Hot side, so connect Hot wire to this single screw.
Other side of switch has 3 screws for connecting each of 3 Load wires.
Note: Neutral wire is NEVER connected to a switch.
http://www.frostelectric.com/WOE-IMAGES/00381764.jpg
7) Since I cannot see wiring project or know what loads or how the testing comes out, I suggest connect the Hot wire to single screw terminal.
And then connect 1 of the other wires to other side of switch. Not a neutral.
Turn power ON, and try switch.
Process of elimination might yield result.
8) Add a comment with more question, and it sends e-mail. I will respond.
More resources:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html
http://waterheatertimer.org/images/How-to-wire-double-rocker-s.jpg
Sep 25, 2011 | Electrical Supplies
Im trying to install a Utilitech 0192773 self adjusting wall timer. It has four wires, black(hot), red(hot), white(neutral) and green(ground). I have a standard three light switch plate(outside light,entry...
Thank you for clear description of wiring, switches, and for including timer model number.
1) Open following link for ez programming and wiring for Utilitec.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
2) Your single-pole switch has 2 wires.
0192773 replaces single-pole switch only.
Black wire that connects each of the switches is Hot wire: connect this wire to timer Black wire.
Other black wire that connects to switch goes to load: connect this wire to timer red wire.
Timer white wire connects to white wires that are covered with wire nut.
Timer green connects to bare ground wire.
3) How to connect stranded wire and solid wire
http://waterheatertimer.org/How-to-twist-electric-wire.html#stranded
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Intermatic & Self-Adjusting Wall Switch...
I have purchased a Utilitech 7-day digital In-Wall timer and I cannot seem to install it properly. Step 2 of the instructions states that if "hot" and neutral wiring is not present you may need to add...
What you have a single pole light switch you are replacing with the timer. As you say you have 2 black wires. One black wire is the incoming power wire and the other black wire goes up to the light. On a normal single pole switch is makes no difference which of the screws you connect it to. Of course with the exception of the ground screw. Tie all the white wires back together that are in the wall box and shove them to the rear as they are not needed to make this connection. The correct connection is to connect one of the black existing black wires in the wall switch box to the black wire on the timer. Now connect the other black wire to the blue wire on the timer. The red wire is not used in a single pole connection and is only used in a 3 way switch connection, so just put a twist connector on it and shove it back in the box. To recap, connect black wire on timer to either black wire in box. Connect the other blue wire to the other black wire. Do not use the red wire. Hopefully you did not hurt the timer by connecting it incorrectly. If it does not work after setting the timer up according to the instructions you have ruined the timer by wiring it incorrectly. Hopefully no damage has been done.
Aug 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
How do I connect multiple (two or more) 3 phase ac power sources (from wind turbine alternators) to a single 3 phase junction to power one device?
what did you mean by single 3 phase? single phase motor have two wire output 110-110, 3 phase gen have 3 wires 110-110-110. if only two wires here ,this is single phase, all appliances are only single phase so you can connect it here, except some 3 phase motor or dynamo. the ac current has no polarity so you can connect to it all kinds of load depends upon the amperage of of your turbine generators
Jul 22, 2010 | Kitchen Ranges
Thermostat wires running from house to outside Kenmore AC unit were chewed by dog. Got replacement wire. Took panel off. There were three encased wires running into AC unit that were chewed. Only see...
If you have a central air conditioner, or a split system, where the indoor unit is attached to the furnace and a outdoor unit is located outside of the home. 2 copper lines will be connected to it, a larger and a smaller one. If it is a air conditioner and not a heat pump, the A/C usually uses 2 wires, that are connected. Allot of times a installer will use a 3 wire thermostat wire, to run to the outdoor unit, if this is the case, the third wire will be folded back out of the way.
The color of the wire is usually picked by the installer, I myself usually use white and red and fold the green out of the way. If you only had 2 wires hooked to it to start with, it really would not make a differace which one you hook up to either one of the yellow wires.
All you are doing it having one wire coming in and one wire leaving,,,, just creating a complete circuit, just don't connect the two yellow wires together.
Example: If you have 2 yellow wires on the A/C unit and 2 wires coming from the house "example a red and a white" hook the white to "One yellow wire" and the red wire to "the other yellow wire".
You are just creating a complete circuit, when the thermostat calls for cooling, it creates a magnetic pull and closes the contact points, in the air conditioner, outside, this allows the 220 volt to flow to the compressor,,, and ahhhh cooling!
I hope I have not confused you, I am just starting to help on this site and still trying to make things understandable.
Wish you the best,
Paul Gibson
Mar 29, 2010 | Heating & Cooling
Bare wire sub to single RCA jack receiver
Yes you can modify RCA cables to make bare wire tails.
If the unit has a sub o/p then you just connect up your sub bass unit to whatever the amp needs.
An RCA cable is 2 wire which is all you would normally need for sub bass speaker level signal.
It may be a good idea to eventually upgrade the wire size if you want really good sub bass as lower frequencies draw more current and so require more copper.
Please let me know if this any help, thanks for using FixYa.
Sep 20, 2009 | JVC RX-554V Receiver
I keep getting a Protector reding on my screen and it will not let me do anything. What do I do to fix this?
Try disconnecting everything (speakers cables, signal cables, all other units) except the power cord, then turn the unit on, if the protector message persists, then the fault is in the reciever.
If this is the case, you should check the speaker and signal connectors for any damage, shorts or loose solder contacts, also check the unit for any shorted or broken wires, loose wire connections, bad solder contacts on connector pins, bad solder contacts on ANY other components (give some extra attention to the components that tend to warm up while they operate, like main power amp transistors / ICs, voltage regulators, power resistors, diodes, also coils, capacitors, etc). Any loose solder connections should be resoldered.
If there's no message when you've disconnected the outside equipment, you have either a bad speaker, a bad speaker cable, a bad signal interconnection cable, or a fault in any of the units that were connected to the reciever. You can find which one is the cause by turning the reciever off, then connecting one cable or unit, turning the reciever on again, see if there's a message, if there's none, turn it off again, connect the next unit / cable and so on, until you get the protector message. The cable or unit that will make the message appear is most probably the cause for the trouble (there might be loose solder connections on other units' cable connectors or other components). When you plug and unplug the cables many times, with time this will loosen the solder connection on the pins inside the unit, so these need to be resoldered.
Hope you can find out what it is.
regards
3rq8 (Triarcuate)
Aug 08, 2009 | Sony STR-GA8ES Receiver
Heating & Cooling Logo
69 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
