Question about Whirlpool LER5636P Electric Dryer
How do you remove fan blade from dryer motor.Do you turn it clockwise or counterclockwise
    President:
  • 1,136 Answers
Hi, If you are looking at the blower from the rear of the dryer, the blower needs to turn clockwise to be removed.
Posted on Jun 25, 2009
Are the Cutting blades bolts for a John Deere LT 160 right handed thread or left handed thread?
It is typical to use right handed thread so you would turn them clockwise to install, and counterclockwise to remove. The blade rotates towards the cutting edge which is typically counterclockwise, so to remove the bolt, you unscrew it, with the handle of your wrench pulling towards the back of the blade.. These bolts can be really tight. Pull the spark plug lead or remove the ignition key so you don't get an accidental start. Wear gloves, there are sharp bits.
Mar 17, 2015 | Cars & Trucks
Which way does the bolt turn to remove the blade from a hayter harrier 41 mower
You can figure this out by checking the direction that the blade turns when it is operating and the bolt will tighten the opposite way because if it turned the same way it would loosen off when the motor was turning the blade, so almost univerdsally it will loosen clockwise and tighten counterclockwise.
Sep 19, 2014 | Garden
I wish to know which direction do i turn the bolt to take the cutting blade of a john deere ride on/ clockwise or anticlockwise?
As you are looking at the blade and bolt from under the mower, if the blade is rotating counterclockwise, then the blade bolt is standard threaded and will turn counterclockwise to loosen. If the blade is turning clockwise, then the bolt is left hand threaded and will turn clockwise to loosen. John Deere produces mower decks with both setups.
Dec 30, 2010 | John Deere Garden
Does the bolt on the blade come off counterclockwise or clockwise.
If you are facing the blade from where the bolt is, and the blade's normal operation is to turn counter-clockwise, then the bolt will loosen counter-clockwise. This is universally true for any blade which is held on by a center bolt (table saws, grinders, etc.) This is because the motor is turning the shaft counter-clockwise, and the resistance against the blade as it does it's work is clockwise - thus tightening the blade rather than loosening it. If the blade normally turns clockwise, then the bolt will loosen clockwise.
Jun 24, 2010 | Craftsman Garden
I am replacing the electric motor in my gas dryer I have it disassembled, and am removing the fan on the back of the motor. does this fan turn counterclockwise or clockwise to remove
Look at your fan and the way the blades curve...to deterimine the rotation of the motor. They can run either direction... some run CW and some CCW....
Once you determine the rotation you can then determine the way the blower comes off. The motor will always spin to tighten the blow on the shaft..... so going the reverse direction would be the way to take it off.
I wish that I could give a definitive answer like yes it goes CCW... but that would not be the correct answer all the time...hope you understand....and that my explaination is clear...why it could be either way.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 02, 2009 | Refrigerators
Replacing lawnmower blades on 38 inch yardman
Need to plug spark plug [for safty]. Install 2x4 blocking between blade and chassy,use clamps.Coat threaded area with wd 40 and torque in clockwise position,not counterclockwise to remove old blade and install new turning bolt counterclockwise or [unscrewing direction].
Please rate. Thanks jj505
Mar 28, 2009 | Mtd Products Yard Machines 158CC Tiller
Dryer drum won't spin
remove rear panel remove screws in blower housing ck for objects in blower ..if you still have dryer apart remove belt from motor pulley and try turning by hand
Nov 15, 2008 | Estate TEDS840JQ Electric Dryer
Can't remove the blower fan from the motor shaft.
blade turns clockwise to remove..but ck door switch first also are you referring to small white fuse on blower housing or the one on element ..the one on blower will cause it not to run other heat only..also possible timer contacts ..motors are least likely to cause problems ..if unable to remove fan will need to be broken o0ff to remove
Nov 11, 2008 | Roper RES7648E Dryer
Remove blower blade from motor
A guy who has been repairing these for twenty+ years told me sometimes the blower fan is just too tight to remove. If so, you have to use a screwdriver or punch from the motor side and literally break the plastic fan apart. I thought that was going to be my problem, but..... With wrench tightly fastened to the nut at the back of the motor and resting against the post of the rubber wheel, I put a sturdy wrench on the shaft at the front of the motor and whacked it in a clockwise direction with a hammer. It snapped and came loose! Hooray. Try that before you demolish the blower fan.
Jan 15, 2008 | Dryers
Whirlpool LER5636P Electric Dryer Logo
471 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
