Hi Aaron J Fraley, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?Hi Aaron J Fraley, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
It is the place to go when you want to find unique furnishings for your children's rooms by BeDazzled Baby & Kids store . They offer artistically hand-painted items personalized especially for your child.
Check out here: BeDazzled Baby Kids Custom Bedding Furniture Clothing Personalized Gifts
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
Maholo, get you some 4x8 sheets of wall styrofoam from lowes or home depot and tack it up against the wall. this will be the easiest and maybe the cheapest
When to moved into the penthouse, there are more walls between the wireless router and the laptop in the bedroom. The walls are probably reinforced concrete walls which will stop or weaken the radio waves penetrating into different rooms. When you lived in a house this was not a problem.
The only way to solve this problem is to move the wireless router near an opening such as a door and move the laptop as close as possible to the wireless router to get a better signal strength.
The outer way is to install a wireless repeater or connect a long network cable to the router and the laptop.
Unfortunately, there is no solution for this issue. The remote control sends out an infrared signal, which can be picked up as far as 40' away from the device. And to make things worse, the signal will reflect off any surface such as glass, mirrors, or even brightly painted walls.
The only way to solve the problem is to block the path of the beam to the other room. This may require closing a door or drawing heavy drapes closed.
money seems to be an issue for lots of us. but if you don't mind a coupla extra bucks get a few axial muffin fans and use them to spread out the heat pattern at your bedroom doors
