Question about Brother DCP-110C All-In-One InkJet Printer
Ink cartrige wont work
Hi my black ink cartrige isnt working and ive tryed to do all different things but still wont work
  • Anonymous Mar 27, 2014
    ink cartriges wont come out or move.
  • 832 Answers
Press menu then start mono then arrow up button 4 times.
machine will be in mainténance mode. press the arrow up button until 7 is displayed. press menu. press arrow up til 6 then press menu. press arrow up til 3 Dispaly shows powerp_all press start mono. machine runs a power purge. after that press arrorw up til 0 press menu press arrow up til 9 machine will print test sheet. In case you dont have a good result do the power purge again. If you dont get a good result after 3 times purging, the printhead is clogged and cant be fixed anymore!
to leave the maintenance mode press arrow up til 9 then menu then arrow up til 9.
Posted on Nov 05, 2007
Black Cartrige Missing
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
May 02, 2017 | Dell AllinOne Multifunctional (v515w)...
Cant print in black and white when out of a color.
disregaurd any prior solutions in cleaning any contacts. that model doesnt have an electrical contact to clean. there are little magnets inside each color and black cartrige that work off a float mechanisim inside each one. when the levels get low the magnet indicates to the printer it is empty. unfortunately for you this stylis model as with all brother model printers wont work even if the color your setting up in the properties or settings feature are set to black and the black is full. its the companies way of forcing you into buying new ink. be aware though that my brother catriges cost 78.00 for the 3 color and one black set. i found these cartriges online through ebay but with one more additional black cartrige for a total of 5 not for ,for a total cost of 13.11 with free shipping. sounds too good to be true but for 13.00 it was worth a try. i have now purchased several 5 packs from them and couldnt be happiere.
Jul 10, 2009 | Epson Stylus CX5000 InkJet Photo Printer
My Kodak 5300 won't print color
MAYBE YOU ADDED A BLACK INK CARTRIDGE RATHER THAN THE COLOR ONE ? OR MAYBE YOU HAVE THE COLOR CARTRIDGE PLUGGED INTO THE BLACK INK ONE ? DONT KNOW IF THIS WILL HELP BUT THOSE WOULD BE THE FIRST FEW THINGS I WOULD CHECK. I ALWAYS SEEM TO MISS THE OBVIOUS WHEN SOMETHING ISNT WORKING FOR ME
Jan 09, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Says new bnlack ink cartriges are empty when they are new
1st check the little gold plates on back of the cartridge.
clean them off and were they make contact to the printer.
If that don't work.
Download SSC Service Utility. (Voids warrenty use at own risk free program)
http://www.ssclg.com/epsone.shtml
If that don't fix it there is still one more thing you can do.
Get a chip restetter for your cartridges.
http://dsacme.blogspot.com/2008/10/service-tool-for-reset-canon-i320.html
(this one is not free)
This will reset the chip on your cartridge and make the printer think its a new one.
I use both programs works great.
Jan 09, 2009 | Epson Stylus Photo R220 InkJet Printer
Ink problem
You need to go to HP.com and download updates. Sometimes the all-in-ones will need them after adding new ink. Also stay away from generics inks they will cause problems. Hope this helps.
Oct 31, 2008 | HP PhotoSmart C4180 All-in-One Color...
Printing lighter on left side
Try cleaning the corona wire/ charge roller if this doesn't work replace the image drum
May 16, 2008 | Samsung CLP 300 Laser Printer
Black ink problem
It could be also the clogging of nossels in color Balck?!
For this purpose you need a special Cleaning solution, wich you
put first in the balck cartrige and start 2x cleaning(when cleaning you should observe if the balck ink is realy transported through the tube !!).Then you shut down your printer for about 24 hours.After that you clean also
for 2x times and check after that the nossels printing test. If not all nossels are free you should repeat the hole thing once again....till the nossels are free.Another problem i observed at my printer is that at some CISS ore kompatible cartriges the rubber-sealing get used with the time and do not seal enough the
conection from cartrige to printer-head and they **** only air...
For this problem i sugested a solution ..see epson stylus 1400
i hope i could help
Apr 13, 2008 | Epson Stylus R265 InkJet Photo Printer
Lexmark x3470
Hi, can you help me? This printer1.gif was working fine for about 4 months and then in wont print anything anoymore. All it says to do is close the lid, but the dam thing isnt open. I tried opening and closing, removing ink4.gif cartrige and even slamming it down but still say door opened?
Feb 24, 2008 | Lexmark X3470 All-In-One InkJet Printer
No black ink print. Prints in light blue
Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
Nov 06, 2007 | Office Equipment & Supplies
Brother DCP-110C All-In-One InkJet Printer Logo
208 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
