Question about Samsung 26.0 Cu. Ft. Side-by-Side Refrigerator, RS265LABP
Samsung rs2630 frig/freezer
Water collects and freezes in the bottom of the freezer. i have cleaned the drain many times but the problem repeats. the manual says check the lock of the filter. i don't know what that means and neither did the samsung rep. any suggestions??
  • 87 Answers
SOURCE: Whirlpool s/b/s refrigerator - water not evaporating on freezer side - collects & freezes under bottom food bin
Did any of the repairmen replace the heater which is at fault or did all three of them change it? If it has not been changed then I would suggest that it should be. If it continues to be a problem then you can get drainline heaters added to the system but you would need to talk to a fridge guy before they wasted a journey. The other possibility is that the front cover is not inside the drain pan or a leak in the drain pan, and if you have an icemaker you could even get water coming from further up the cabinet. Either way I would suggest picking your favourite of the three and tell them that the problem is unresolved. Most fridge guys offer some sort of warranty on work that they do. Hope this is of some help.
Posted on Sep 11, 2007
  • 22 Answers
SOURCE: refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Posted on Nov 13, 2008
MNTECH
  • 1543 Answers
SOURCE: GE TFX20JR side by side/water leaks out freezer during defrost
Yes, you are correct, that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrig. (where the air blown over it will cause it to evaporate)
Posted on Jan 06, 2009
SOURCE: freezer not freezing
It is likely that you have ice build-up on the tubes behind the back of the freezer. This will prevent effective heat exchange and block air flow AND can cause the water line to freeze. Same exact thing happened to me. Look at the back wall of the freezer. If there is any ice/frost on the wall and ESCPECIALLY if you can see ice through the ventilation holes this is probably it. You will need to defrost the freezer. Uplug the unit and take everything out of the freezer. Put a towel in the bottom and leave the door open. If you want, you can try blasting it with a hairdryer, but even with several spells of hair dryer it took my freezer 18 hours for all the ice to melt. This seems to be a common problem with Samsung side-by-sides. Good luck.
Posted on Jan 21, 2009
  • 400 Answers
SOURCE: i have water standing inside the crispers, shelves
I beleive that your thermostat is faulty which is causing an excessive build up of ice.
Posted on Mar 05, 2009
Samsung RS2630sh. Drain line Freezes shut. Water drains to bottom of freezer and freezes there. Cooling coils are not collecting ice. Drain line has been cleaned. Why does it keep freezing shut?
If water still collecting and freezing at freezer bottom then drain line is not cleared and still obstructing the normal flow of water downward.
Aug 22, 2017 | Samsung Refrigerators
Have whirlpool ET18NK/ET18NM refrigerator-food freeze in the center of frig and veggie bins--water collects in bottom of frig to overflowing if I don't keep a container in middle of top shelf to catch ...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 27, 2011 | Refrigerators
I have a model RF26VABPN french door, bottom freezer unit. It has a leak of cold water pooling under the crisper trays. I can't find where the leak is coming from. I clean the water up, and within days,...
Defrost drain plugged in fresh food section. Samsung will repair it under warranty. Might pay for it if you complain nicely, if it is out of warranty.
Mar 31, 2011 | Samsung Refrigerators
Water leaks inside,cant seem to locate drain. Water freezes in bottom of freezer,then runs down to the bottom of frig. I SEE a drain in the back right of bottom of frig but it sits up like a knob with...
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer
Nov 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Is your problem fixed yet?
Yes, I fixed my problem of the plugged drain that caused the ice to melt onto the floor. Apparently, frostfree frigs have a drain that leads to a pan under the frig by way of plastic tubing from inside the freezer compartment. The drain tube end for my frig only had about 1/8" clearance above the pan bottom. The pan was dirty with an ENORMOUS amount of dust that had collected. So, I had to move the frig out from the wall, remove the back cover at the bottom of the back of the frig. This exposed the white tubing and the gross pan of dust and water paste. I cleaned the pan, disconnected the tubing from the clip holding it in the pan and trimmed about 1/4" off the end to create a bigger clearance into the drain pan.
Make sure the frig is unplugged before you do the job so the evaporator fan doesn't hurt you.
Now, I will have to clean from behind the frig at least once a year.
Hope this helps. Good luck.
Bob
Dec 15, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
WATER LEAK IN FREEZER POOLING AT BOTTOM & FREEZING THEN MELTING
The problem was indeed a clogged frost water drain. I had to pull the frig out from the wall (found an incredible amount of dust accummulation in the alcove), then remove the vertical metal and horizontal cardboard covers to expose the drain catchpan. The 1/2" rubber drain hose end was only about 1/8" above the pan pointing directly into it perpendicularly. This was not enough clearance. There was a plug (formed by dust and water) in the end of the hose that came out easily when I 'roto-rooted' it with a screwdriver. The water flowed easily after that, but I went ahead and trimmed about 3/8" off the end of the hose and pushed it back into its slot. Then I cleaned as much as I could. The prevention is to keep the area behind the frig cleaned!
Bob
Nov 07, 2008 | Refrigerators
Water collecting in Refrigerator freezer section
the drain hole could have ben clogged with dirt and now with ice as the water did not drain as it went back to freezing mode. un plug the unit, let the ice thaw for a day, open the rear cover of the freezer and clean the bottom part of the evaporator. you can find the hole at the bottom part of the drain pan. i hope i was able to help.
Jul 05, 2008 | Kenmore Refrigerators
Refrigerators Logo
65 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
