The outdoor a/c condenser fan has stopped spinning. I manually got it to spin, but then it stopped again.
  • 439 Answers
Ok, this can be caused by a few problems, you either have a bad fan motor, a bad contact switch, or a bad capacitor.
Posted on Jun 25, 2009
Ruud. How do I repair?
It is likely that the fan will have to be replaced.
Jul 13, 2015 | Heating & Cooling
How can I prevent the outdoor fan from spinning in the wind?
First of all, this is NOT an outdoor fan. Unless you want to take the blades off you won't be able to stop it from spinning in the wind.
May 30, 2015 | Casablanca Fan 3245T Ceiling
Error code 10
Check to see if condenser fan (condenser is the outdoor unit) is spinning freely
Aug 08, 2014 | LG Art Cool LA181CNW Split System Air...
My air conditioner tries to turn on, air comes out of vents but isn't cold, and outside the blades on the AC unit are not spinning. I hear a noise when it tries to turn on but they don't start...
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor
Jun 17, 2011 | Heating & Cooling
Have an expensive Hunter indoor/outdoor pedestal Fan that stopped working. It just "hums" and does not turn. Please help.
With the fan UNPLUGGED, try to spin the fan blade with a pencil or something that will fit through the blade cage.
If the blade spins easily, there is an electronic problem (control or motor) that must be serviced.
If the fan blade is stuck or very hard to move, the shaft and bearing are probably dirty and need to be cleaned. You can temporarily fix this with a tiny amount (a drop) of WD-40 applied to the shaft where it enters the motor. Spin the blade manually to work the oil into the bearing. If the motor spins freely, the dirty bearing condition is verified. To properly clean the shaft and bearings, the motor must be disassembled.
Jun 11, 2011 | Hunter Floor Stand Fan Stand (Pedestal)
I addred coolant to the AC unit a few weeks ago and it has been running fine until last night. I went to check the pressure and make sure the line was not frozen this morning since the indoor air climbed...
It is just coincidental that the fan motor died now...
Replace the condenser fan motor and you will be good again...
Here is a tip about troubleshooting your airconditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Apr 20, 2011 | Carrier 38CKC036 Air Conditioner
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Fan stops
The cooling fan for the condenser is probably running, getting hot and seizing up. Check to see if the fan is free spinning after it stops. Take a probe and try to spin it manually. If it turns freely, then it could be going bad with it's electrical windings, the internal coils that create the magnetic field that spins the rotor of the fan motor. I suspect it is seizing up, however, once a fan seizes up, it usually stays that way and won't spin even after it cools down. It could be a capacitor that is going bad and not starting the fan after it gets hot. A capacitor is a small round shaped can type with usually 2 wires hooked in series with the motor it is trying to start. That is what it does, help start the device (compressor or fan motor). Good luck.Ken from Henderson NV.
May 30, 2009 | Dometic Rooftop RV Air Conditioner
C6 error code on LG art cool
Try turning the power off at the fuse box, waiting 5 minutes turning the system back on and spray some water on the vents on the side of the outside condenser. If the fan isnt spining get a twig and spin it in an anti-clockwise direction after 1 or 2 spins it should start spinning on its own. continue to hose the vents with water for another 5 minutes. Its important to have the fan spinning as it extracts the heat from the condenser box.
Jan 03, 2009 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
