Question about Whirlpool LER8648P Electric Dryer
Air not heating up in whirlpool dryer
Everything works but the air doesnt heat up
  • 6,784 Answers
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Jun 25, 2009
94 thunderbird heat or cold air doesnt blow
if you saying the fan wont blow it may need a fan motor not uncommon it might be a speed switch if it has one some time you can hook a wire on the back of the speed switch plug in to get it on high use a 14 gauge wire or bigger a small jumper bent in a loop with the rubber peeled off the ends and shove them in the switch plug find the 12 volt ht wire on the plug with light or vom then try the other wires one at a time til fan runs with ignition switch on
Dec 24, 2017 | 1994 Ford Thunderbird
I have an ap125hd and the fan doesnt blow in heat mode everything works good in cooloing
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV
Dec 30, 2010 | Amana Haier AP125HD Air Conditioner
GE Spacemaker Micro
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
srtat
Jun 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My dryers works when cold but stops working after it heats up.
does everything shut off or just heat if its just heat but motor works and drum is turning than-quickest sulotion would be cleaning the vents from the dryer and out through the wall or window whereever your vent goes. the reason it turns off is because it has a limit thermostat that turns off at about 150 degrees so when the vents are clogged the hot air cant escape anywhere so it stays in dryer and overheats quickly take off the vent in the back than turn on your dryer if it doesnt turn off clean your vents
if everything stops working than you most likely have a bad motor
good luck  feel free to reply with any questions
Jun 09, 2009 | Dryers
My defog, heat, and air conditioning has just
Very very common fault its the display itself, pop it out try resoldering it but it doesnt always work, bmw do offer an exchange though, a new one for your old one plus cash.
Good luck Davelee.
Mar 24, 2009 | 1997 BMW 328
Pontiac montana heater works but doesnt blow heat out on defrost
If the heater core is good and the blower works, the valve doors may not be opening and closing properly to direct air towards the proper vents. This may be because something has fallen in and is obstructing their movement. The actuating motors may not work properly, or the linkages that connect them to the mode doors may be worn or improperly adjusted. You can get a look at the mechanisms by removing the driver side knee bolster (two screws) and a lower trim panel on the side of the center console.
Be careful fiddling with the linkages. Everything is plastic and easy to break, and replacing the heater box requires removing most of the dash.
Dec 20, 2008 | 2001 Pontiac Montana
MMV4205 doesnt heat up
If not a separate fuse, then the hi-voltage inverter or magnatron have likely failed. The first can be $130. The second $45.
Jan 30, 2008 | Maytag MMV4205 Microwave Oven
Whirlpool LER8648P Electric Dryer Logo
532 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
