Hello Experts, Just recently, my Sony VAIO laptop crashed on me. I just woke up one morning, and it displayed this message on a blue screen:
"Stop: c0000218 {Registry File Failure} The registry cannot load the hive (file): SystemRoot\System32\Config\SOFTWARE or its log or alternate It is corrupt, absent, or not writable.
Beginning dump of physical memory Physical memory dump complete"
When booting up the laptop, it starts off normally. It shows the VAIO icon, and then displays the Windows loading bar. After it is done loading, it displays that message above.
A few months back, the hard drive crashed, and I replaced and upgraded it with a 250G Hard Drive, so it would be hard to believe that this new Hard Drive has already crashed.
I have the same problem, and this also started back in May. After replacing c-mos battery, HDD, memory, Optical Drive and processor, it points to the motherboard. It some how the Sata controler fail to detect a hdd. I updated the bios and the same issue. I have no problem if on the bios I set it up to boot from a usb HD.
Forget about the hdd and used a usb bootable drive or key. I also dont want to buy a motherboard since this problem is happing to a lot of sony Vaio system and they are too expensive.
All this problem started with a blue screen 0x00000218.
The first possibility is simply corruption in the window Registry , the first thing to attempt is a recovery via the Automatic System
Recovery for your particular installation. Since you are attempting to
do a system restore, it's possible you already tried this and had it
fail. If this is not the case, follow the detailed directions presented
in Microsoft Knowledge Base article 307545.
I just downloaded nero 9.Every time I go to import a movie file I get this error unable to insert...
(More)
I just downloaded nero 9.Every time I go to import a movie file I get this error unable to insert c/: any ideas or help would be appreciated thanks in advance...
i instaled wlan mini-pci card (broadcom) in toshiba 2435-S255 notebook, but adapter is not on (radio...
(More)
i instaled wlan mini-pci card (broadcom) in toshiba 2435-S255 notebook, but adapter is not on (radio disabled). wlan swich is on, but led is not lighting. driver is ok..
when i run the software for video it says "this update is not intented for use with your...
(More)
when i run the software for video it says "this update is not intented for use with your computer model"
