Question about Refrigerators
Peg that holds up shelf is broken. how do you remove broken part.
  • 999 Answers
If it is one without a screw- twist it 90 degrees counterclockwise to release it.
Eric
Posted on Jun 25, 2009
I have a peg perego gaucho grande and used the kids wheel overhaul kit two months ago and just today removed the pin for the high low function ... Now my gaucho does this choppy sound when in low spee
sounds like you have some broken teeth in one or both of your gear boxes, see which side the sound is coming from, and you can either open the gearbox and remove the broken teeth or just buy a replacement gearbox
Sep 13, 2014 | Peg Perego Gaucho Superpower
How do Ireplace a refrig shelf post?
Buy the peg to replace it,then turn the broken one clockwise 45 to 90 degrees and take it out.
put the new one In and turn it 45 to 90 degrees to lock it in place.
Sep 05, 2014 | KitchenAid Superba Architect KSCS25INSS...
Steering lock
The steering lock is a spring loaded peg, which is drawn out of a slot in the steering column when the key is turned. The spring holds the peg against the column and then pushes the peg into the slot when they line up. With the key removed turn the steering wheel to line up the slot, then the steering will lock. If this does not happen the lock will have to be removed to find out what is wrong, possibly broken spring.
Jan 27, 2014 | 2006 MG ZT-T 190
Broken door hinge on Stoves 900dfa oven
STOVES 900DFa - how can I download the USER MANUAL and the TROUBLESHOOTING and MAINTENANCE MANUALS
Dec 30, 2012 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Broken sitar tuning peg
by now I hope you've bought or made a new peg. with any tension on it, the splintered wood, broken at an angle, won't hold long enough to tune the string. either make one out of a dowel rod, with the tapered end sanded to fit tightly, or use a brand new one made of plastic.
Aug 06, 2012 | Mid East Sitar Sympathetic Tuning Peg,...
How can i remove the foot pegs from my XL1200 C Harley?
There's a pin that holds the foot peg onto the foot peg extension. Take the clip off the backside of it and remove the pin. The foot peg will come off.
Good Luck
Steve
Jun 18, 2011 | 2009 Harley Davidson XL 1200L Sportster...
Trying to get right side foot peg case off foot peg seems to have a nut behind case not sure how to get off
Yes there is a nut on the backside of the stud that the peg mounts to. The stud is also the shaft for the rear brake pedal. To get to the nut, take the master cylinder loose and the snap ring that holds the rear brake pedal on or the remove the pin from the brake pedal. Now, take the large nut below the peg and brake pedal shaft off and the other two bolts that hold the front sprocket cover on. Remove the cover and you can get to the nut.
Good Luck
Steve
Apr 03, 2011 | 1993 Harley Davidson XLH Sportster 883
My temperature gauge stop working
First check to see if wire is plugged in or corroded to sending unit in engine block. If ok hold wire to a good ground,should peg guage to hot. If no broken wires or no peg guage is bad.
Jun 07, 2010 | Buick Park Avenue Cars & Trucks
Foot peg bracket removel 2000 sportster
you must remove pulley cover and master cylinder. inside cover is a large nylock nut holding peg mount. once removed a bolt and nut should be replaced in its place as it holds some of master cylinder
Jan 25, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
Turn Tble will not turn.
open up the top (where the record player is). Take off the pad, then remove the little c-clip surrounding the metal peg (in the center). Remove the turn table. Check underneath to see if the strap/belt is rather broken or has slipped off. If it broke, you have to go buy a new one. If it slipped off, put it back on. Put one end of the belt around the white plastic peg (the one that turns) and then the rest goes around the first outer ring on the bottom of the turn table (the middle one, between the outer edge and the middle insertion area. Its a real pain in the **** to do because it slips off a lot the first couple times...but you will get it eventually :) Once that is done put the table back on, test it, if it works put the c-clip back on (which is a lot harder than taking it off if I do say so myself lol) Put the rubber cover back on and Voila! You have a working turn table. For those with a broken belt use this as a replacement guide :)
Good luck guys and enjoy some good ol' Vinyl cause they are making a comeback!
Nov 13, 2007 | Philco (R) 841.205 CD Shelf System
Refrigerators Logo
147 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
