LG WM-1832C Front Load Washer
Problem for LG WM-1832C Front Load Washer
LG front load washer -- water leaks
By deb_levy on Jun 25, 2009
LG front load washer -- water leaks out the bottom of the door -- if I push on the door while its running, the water slows/stops leaking...
Best Solution
posted on Jun 25, 2009
Very Helpful)
MNTECH
Rank: Guru  LG Expert
Rating: 94%, 902 votes
First, clean off the bottom of the door glass where it contacts the gray tub gasket when the door closes. Any hair or other build up can result in leakage. Second, if that does not completely solve your leak, you can move the location of the spring which holds the tub gasket from the very bottom (6 O'clock position) to the hinge area (9 O'clock position). Third: Sometimes, the reason you get a leak is due to the installation. If the washer was pushed into place by applying pressure in the center front of the washer, the outer front panel can be slightly deformed (inwerd) resulting in leakage from the door. If that is the case, sometimes you can remove the outer clamp and outer part of the gray seal and pull out on the front panel to correct the situation if it is not too severe, rather than replacing the entire front panel.
Was this helpful?
Yes
No
4 people thought this was helpful
Popular Solutions for LG WM-1832C Front Load Washer
Questions and Unsolved Problems for LG WM-1832C Front Load Washer
Do you recommend LG WM-1832C Front Load Washer?
Answer
Answer
leak from washer somewhere what are the possiblity
Answer
has any one tried "liquid alive" to get rid of mold/mildew smell?
Answer
my lg washer machine keeps showing fault for motor overload the fault code is l1 thanks marty sines
Answer
I'm getting an OE error on my washer--lg tromm 77wd941. I have emptied the lower drai, but I've... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For LG WM-1832C Front Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14935
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
