Question about Whirlpool Duet GHW9150P Front Load Washer
Cycle selector not working
The cycle selection is not working I can only select a few of the cycles
  • 6,784 Answers
HI, when this happens, you will need to replace the switch. the mechanism will become faulty overtime.
Posted on Jun 25, 2009
Why isn't it responding to was cycle selection?
If you have a top loader, the lid switch may be defective. Sometimes a dial-type cycle selector needs a little nudge to start washing.
Dec 01, 2015 | Washing Machines
Maytag Coin Washer can't select Cycle after putting in coins
check the coin mech
If it is turning on properly
check the selector itself.possibly the switch
Mar 18, 2015 | Maytag MAH21PDD Commercial Front-Load...
My frigidare affinity dryer is only starting on delicates and touch up, nothing above that
Hi.
If machine runs only in low heath cycles, then there is a problem with timer control, low heath selector, or heating assembly (cycling thermostat).
The first thing to do would be locating the tech sheet. The sheet is tucked inside an envelope located inside the control panel assembly. In the tech sheet you will find instructions to run a diagnostic cycle. The diagnostic cycle will return an error code that will help locating the fault.
With different Frigidaire Affinity dryers you need to press and hold Pause Cancel and SELECT for about ten seconds, then leave, put selector to NORMAL, temperature selector to HIGH HEAT and press START to run the diagnostic cycle. The procedure for this specific model is described in the tech sheet.
Nov 19, 2011 | Dryers
Seems to be stuc in Demo mode and refuses to do anything except select programs
the way I clear a cycle on my FDW50 is to open door,push and hold cycle selector and cycle start until you hear prolonged beep followed by three short beeps-this will cancel whatever has been selected
Nov 10, 2011 | Hotpoint 24 in. FDW60 Free-standing...
What is the capicity of a GE WWA7600S washer
Here is the user's manual:
http://genet.geappliances.com/DocSearch/pdf/49-9810.PDF
They never talk about weight or capacity other than
Setting the Controls
Use the Suggested Fabric and Cycle Settings guide ~ Select Rinse Temperature.
to help you make the proper selections.
~ Select Wash Spin Speed.
~ Push Cycle Selector knob in and turn clockwise to
your selected wash setting. If you wish to change setting
~ Select Water Level. ~ Pull Cycle Selector knob + START out to start the washer.
SMALL: Washer is less than 1/3 full of clothes.
MEDIUM: Between 1/3 and 1/2 full.
LARGE: Between 1/2 and 2/3 full.
This washer will pretty much take anything you can throw at it. It was a competetor of the Maytag large capacity washers. As long as you follow the loading guide above you are not going to hurt it.
Thanks for choosing FixYa,
Kelly
Oct 17, 2010 | GE Washing Machines
Will not go into high speed final spin after rince cycle..only spins back and forth slowly and the uE indicator comes on stopping the machine. Have tried taking out a few laundry items and re-starting and...
uE is unbalanced error. When you have bulky items, wash them with a slow spin speed. Larger loads actually balance out better, so adding items might help instead of subtracting them. After the cycle completes, if you want to you can turn the power on again and (without selecting a cycle) just push the spin speed selector button and select the next highest spin speed. The load will most likely make it through the next higher speed now that it is partially spun out. You should get a 14 minute spin and pump only when you start it now.
Nov 15, 2009 | LG WM0642H Front Load
Whirlpool Duet GHW9150P Front Load Washer Logo
156 people viewed this question
Dan Webster
Dan Webster
Sal De
