Question about Samsung HL-S5087W 50" HDTV
Turns on fine for about 10 sec. then off & the 3 lghts blink
The lights Green, Red, And yellow are standby, Power, and Lamp. If I unplug it it does the same thing no matter what outlet I use.
I took the back off the TV and for that 10 sec the the TV comes on I can see the lamp lights up fine.....So I am not sure if the lamp is the problem yet.
I also checked to see if the fans were turning and they seem to be working.
Then I removed the thermal switch that was mounted above the lamp and tested it with a ohm meter and its good. It reads 0 ohms across the 2 pins.
Please Help if there is anything else i can do.
Thanks
    Champion:
  • 205 Answers
It sounds like power supply.
Posted on Jun 28, 2009
HELLO MY kdf-e55a20 tV IS NOT WORKING. THE GREEN LIGHT FLASHES 6 TIMES THEN IT FLASHES RED 6 TIMES
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The Lamp light blinks when the Lamp requires replacement.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the power light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
This indicates that there is some kind of audio problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jun 11, 2011 | Sony KDF-E55A20 55 in. LCD Television
Sony 3 lcd rear projection tv hd w/ wega gate. kdf-e42a10. tv will atempt to turn, shuts down, greem power light blinks 12 times on average. red standby light blinks 4 times. i replaced lamp [ xl 2400...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Mar 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
Tv keeps turning itself off and then back on. green power light blinks. If i tun it off when it does that the red power light blinks 5x repeatedly.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
Jun 22, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
KP57WV600 SCREEN TURNS GREEN THEN BLANK
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
  1. Turn off the television. IMPORTANT: For a projection TV that uses an internal lamp, wait 5 minutes after turning off the TV to allow the lamp to cool before continuing with the following steps.
  2. Unplug the TV power cord from the electrical outlet.
  3. Let the TV remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
  5. Turn on the television. NOTE: If the TV does not turn on immediately, the fan may need to finish its cycle. This is part of the cooling process for some projection TVs and is normal operation. After the fan turns off, attempt to turn the TV on again.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
Sep 22, 2009 | Sony KP-57WV600 57" Rear Projection...
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
My tv is blinking red in the power indicator 4 times on my KDS-50A2000
I had the same problem. Red LED blinking 4 times. This error means that one of the fans is NOT spinning! To check.... unplug the tv.... turn the TV around to a well lighted area so that you can see the fans in the back... plug the TV in and turn it on. Watch for the fans in the back... and see if they are spinning. If not... that is the reason why the TV will not turn on! In my case, the fan next to the lamp was stuck for some reason. I removed the the cover of the TV from the back... and cleaned the fan, made sure all connectors to it were properly connected... and viola! The TV is perfect again! Enjoy!
Feb 05, 2008 | Sony KDS-50A2000 50" HDTV
Sony kv32fs16 problem
The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Nov 02, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Problem turning on the TV
I have the same problem. Did you find a solution?
Oct 24, 2007 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Samsung HL-S5087W 50" HDTV Logo
148 people viewed this question
Jerry Greenberg
Jerry Greenberg
