Question about Maytag MDB7100AWB Dishwasher
Upper rack roller replacement on mdb7600awd - Maytag MDB7100AWB Dishwasher
  • 58 Answers
Go to www.searspartsdirect.com and search model # mdb7600awb, track and rack assy, this will give you the parts breakdown and you can order as needed. if you don't feel comfortable changine these components yourself, call a&e factory service, or www.aefactoryservice.com, these guys are cheap and good. jordanservices inc. doesn't yet serve your area, hope we could help :)
Posted on Jun 25, 2009
Upper rack track wheel broke
You can try to obtain the part from KitchenAid or an appliance parts supplier. However, you may only be able to get the complete assembly.
Nov 07, 2013 | KitchenAid KUDS30IX Dishwasher
How to replace the top rollers on a GE dishwasher model # gsm1800nww
Lower Rack
  • Remove all of the dishes from the lower dishwasher rack.
  • Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
  • Lift the lower rack up and out of the dishwasher.
  • Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
  • Upper Rack
  • Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
  • Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
  • Pull the upper dishwasher rack straight of out the arms to remove.
  • Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
  • Align the end caps with the ends of the arms, then push the end caps into place.
Feb 04, 2011 | Maytag Dishwasher
Upper rack roller axles are brittle and 1 has
Our upper wheel failed. It is part of the huge assembly called the "Rack Adjust" on our model # PLD4460REC Frigidaire Dishwasher and cost $88 to $120. Hey.. thanks to the guy above I was able to fix my machine without spending to much!! for a huge part when all I needed was the upper wheel. the part # for the upper wheels is = PS976006 and is for another model dishwasher (Sears located it for me first.. without trying to make me buy the huge assembly) but might work... I will order and give them a try. The model # referenced about seems to be incorrect... We used model # PLD2855RFC1... as google helped us fill in the missing part# letters. I asked frigidaire... why they encouraged customers to borrow this small part from the store display.. why not just sell it!! .;)
Aug 02, 2010 | Frigidaire PLD4460REC Stainless Steel...
Water not getting to upper wash arm / glasses on top rack are dirty after the cycle - I do not know how to take out top slide basket to check water flow in tube at rear of machine-
remove the roller rack plastic end caps this will let you remove the upper rack,then you can replace the whole wash conduit from the bottom sump all the way to the top,also if theres a middle(center arm) this has a horn on it that is to seal when the rack and door are in and closed,but after while the water wears out the plastic o-ring and they leak and you lose water pressure to the top wash arm
Apr 01, 2010 | Dishwashers
2 upper rack rollers cracked in Maytag #MDB7600AWS - cant find simple replacement rollers for inside track - 1 1/4" - of upper rack.
JP Weld works great on repairing these junky Maytag parts. Note that they don't have a replacement for these upper wheels and a guy is selling expensive stainless steel replacements. The round connector broke off of ours that holds the wheel to the rack. My wife found a plastic button that fit within the space and we glued it with JP Weld epoxy (water and temperature resistant). 10 washes later, still working great! I expect it will "heal" any other plastic parts. NEVER will I buy a Maytag again!
Sep 11, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
I need the upper and lower rack rollers replaced but do not know the part numbers. I am looking for a parts diagram on the internet but have been unable to find one. GE Nautilus, Model GSD2200G00CC
http://www.myapstore.com/Omega/Dispatcher?REQUEST=HOMEPAGE
Start at the link above, enter your model number in the box near lower part of screen, you will then be asked to verify by clicking it on the next page.
When you have done this, the next page should default to a choice of "body parts", see if your rack roller assemblies don't appear in the list you will find there.
I did this and seemed to work well at finding the upper and lower rack assemblies. ( I am pretty sure you have to buy assembly and not just rollers.
Hope this help.
Aug 31, 2009 | GE Nautilus 24" Built-in Dishwasher
How do you remove the caps from the upper rack glides? I'm replacing the rollers that attach to the upper rack because one is broke.
Caps on the front ends of the glides can be pulled out. Sometimes they are hinged at the top and have a tab at the bottom to pull out. With the caps out or open you can roll the upper rack out of the glides.
Aug 12, 2009 | Dishwashers
GE Adora Dishwasher Upper Rack Binding Issue
I have a GE Profile model PDW7800.... and just replaced the rollers on one side since one of them had broken. There is a 'magical' way to reinstall the rack so the side guides ride inside the roller guides without touching. I suspect that the rack has not been reinstalled in the precise manner - which I am still trying to figure out. The new roller assembly which attach to the rack fit differently than the original ones. I found that you do have to remove the rollers screwed into the wall to get the glides out and that could also cause rough gliding. Part of the 'binding' is designed, I believe, to keep the racks from coming out too easily.
Sep 17, 2008 | Dishwashers
MDB7601AWS Maytag dishwasher
hi there,
go to www.whirlpooparts.ca and type in the model # under Repair Parts. it will show you the exploded view of the racks.
May 13, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Maytag MDB7100AWB Dishwasher Logo
342 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
