Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA 52 in Tv
The Whole pic looks like a bubble + the color is all messed up
Out tv has a row of blue, green and red lines accross the top of it now. i spoke to some people at thompson and rca and we trouble shot the situation. they are saying it is the picture and it would cost between 300-400 dollars to fix, that without the warrenty.
Posted on Nov 09, 2007
Can I repaint a steel enamel finished sink? Has been scratched by clumsy wife!!
Yes you can. they make several products for this at the harware stores. You said enamel but are you refering to porcelain? To do the repair you will need porcelain repair compound and some high-gloss, alkyd-base paint that matches the color of the porcelain. if it is simply enamel then just match the color or repaint the whole sink using enamled paint. what you have to watch and worry about is if the repaired section will be contantly wet, if water gets under the paint it will bubble and flake off and make a mess. So the answer is yes but it may not be worth the trouble.
www.diybathrepair.com
Sep 12, 2011 | Microwave Ovens
Samsung DLP TV- colors seem to mess up -Faces have green streaks
sounds like you are haveing an issue with th color wheel timing. either the color wheel is bad or the dmd board is bad.only way to know is to have a technician look at it.
Oct 22, 2007 | Samsung HCN4226W 42" Rear Projection...
I have a 92 honda accord ex my transmission fluid is almost a pink color i drained the fluids out because it was over filled . after going 30 miles my car does not want to accelerate now the car doesnt...
Thanks for choosing FixYa and welcome. Sounds like you may have drained out to much fluid. You need to make sure that it is full because it will do this if it is not. If you are driving on little fluid, it can mess the transmission up. I would recheck the fluid. Make sure you check it on a level lot.
Apr 22, 2011 | 1992 Honda Accord
My tv needs readjusted (color,focus,etc.)Is there an easy way to do so myself? i got a 1986 45'' RCA projection tv.it started of with just a blury spot across the top but after i messed with it the whole...
First pull back Look for screen and focus block you will have 3 controls ontop for focus and 3 controls below for adjusting screen drive to each Tube R/G/B
turn color off on Menu NOW try to Adjust the red,greenand blue screen drives as close asyou can to a Black and White picture then turn Color back on in Menu also adjust Focus for each Tube Be sure to Clean Top of Tube Lenses of dust&dirt Just in case Post me your Model and Chassis Number it will be on back of TV some RCA Focus&screen drive Block maybe in front of TV if so remove front bottom panel their you will see control box.
Nov 10, 2009 | Televison & Video
Pictures messed up between camera and computer
It sounds like jpeg file corruption. What do the pictures look like on the camera's screen?
If they look OK, try using a card reader to transfer the pictures and not the camera. do they transfer OK now? If not then the card may have a problem OR there is a problem with the USB on the computer that is causing it.
If they look wrong on the camera then it's possibly the card at fault.
What I would do is download what pictures you can and then give up on the others and reformat the card in the camera. That will clear the card as if it as brand new. Take some more pictures and see if you can transfer them successfully.
I've had a card fail (so far only 1) and it's really annoying, reformatting didn't help either, it was still faulty!
There is always the possibility that the camera is at fault! I hope not.
Try shooting some pictures in RAW format instead of jpeg and see what happens then.
Aug 07, 2009 | Nikon D80 Digital Camera with 18-135mm...
Printing wrong colors
you might be running out of the red ink.
Whenever a printer prints the whole image but with different colors it means that the printer uses the available color with enough amount.
Try replacing it with new ink cartridge.
Jul 28, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Screen looks messed up
this is probably a conversion IC that controls the vertical horizontal and color alignment
you will need them replaced as well as a few resistors
if you can't do this yourself then call an electronic repair shop , they will fix it for about $400
thanks
electech
Oct 23, 2008 | RCA D52W19 52" Rear Projection Television
MITSUBISHI 65"
You need to replace both convergence ICs Number STK392-570 If your model number is a WS-65809 you can get new replacement ICs at the following link and they provide instalation instruction with pics as well as free on line tech support so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Apr 30, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Goldstar 27
In picture number 2, I saw some blue also. So I'd guess that the red gun is not firing. This could be a transistor on the board on the back of the picture tube, or it could be a bad picture tube. I would replace all three transistors on the PC board, if the problem remains, it's probably the tube.
Hope that helps...
Geno
Apr 02, 2008 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
