Question about Home
We just moved into a house with a whirlpool bathtub. When I turn the bubbles on in the whirlpool, the jet streams out so hard that it shoots water all over the bathroom. Am I doing something wrong when I opperate the bathtub or is there something wrongwith my bathtub?
  • 21 Answers
The bathtub needs to be full.  and you can turn the jets on some modles.  old homeowner new this and probably turned the jets up so it will do that not really funny.
Posted on Jun 25, 2009
How do I fix a jet that isn't hardly pumping on my Aqualux jet tub? The other 8 jets work but no more bubbles. Is it the switch? Is that one jet clogged? Do I need a new pump? How do I get the jet out
hello Tami!
That particular jet is probably clogged.
You can find special cleaners NON ABRASIVE at your local hardware stores.
Be sure to tell them what cleaners you are looking for to make sure it is a non-abrasive type.
Or call in for service. Here is a link that may be helpful to you.
Best of Luck,
JP
Bacteria Alert How To Easily Clean Jacuzzi Bathtub Or Whirlpool Tub Hot...
Oct 28, 2015 | Home
Maax sa9592 06
Each bathtub has at least one air control on the tub that when opened lets air into the jets that produce the bubbles.
If you are experiencing too much pressure out of each jet, some of the jets if they are adjustable you can turn them down by rotating them left or right.
The other issue may be the water depth in the tub before you are turning it on. Make sure the water level is at least two inches or more above the highest jet.
Rod
US Parts Center
Feb 05, 2014 | Home
The bubbles on the bottom won't come on...???
What bubbles? what heater? we need more information in order to answer those questions and trouble shoot what is going on in your bathtub.
Rod
US Parts Center
888-521-6183
Feb 20, 2013 | Home
Fill tub, press button, hear motor but no bubbles,etc coming from jets
Are the jets open? The center of the jets turn to adjust the pressure of the jets. If this is not the problem, there may be a problem with the impeller in the pump assembly. If you here the pump turning and not buzzing, it could be an air bubble in the suction tube. This tube is the one coming from the front of the pump, if the pump is higher than the tube coming from the tub, or if there is a high spot in the tube, an air bubble is a real possibility. If the tube is level with the pump, there should be no problem with air bubbles and the problem lies in the top part of this paragraph.
Mar 10, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Water runs very slowly when trying to fill jet tub.
Check to see if there are any screen type filter to the tub as debris may be clogging it. Also air lock can occur but it should not be causing problems as 90% clear them selves.....
Feb 15, 2010 | American Standard AMERICAN STD Savona...
I know I can take a bath without turning on the jets. However; does the bath water with soap flow back into the jets? I like bubble baths, If I leave the jets off can I use the bubble bath without having...
The soapy water will fill all of the jets, tubes and the pump assembly. Will it hurt the tub if the jets are not running? The soap film will build up in the jets, tubes and pump assembly and can possibly cause damage if the tub is run at a later date. Contact the tub manufacture and see if there is a safe bubble bath you can use.
Aug 23, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
Cold air coming from jets in a large garden tub indoors
jets pull outside air in thru the water jet in a natural Venturi action. If you are referring to the air bubbles in a bathtub then, yes there are air blowers that have heaters inside them to warm the air before if goes into the tub.
Feb 20, 2009 | Home
Jacuzzi jet pump doesn't produce much bubbles
you need to turn the air on should be some sort of cap or screw in type thing to let the air in open it
Jan 17, 2009 | Pool & Spa
Difference tubs and air baths
whirlpool tub has jets that circulate the water, where an air bath uses bubbles that rise gently from the bottom of the tub. Whirlpools are typically used for therapy, air baths are used for a much gentler experience. Air baths can be used with aromatherapy/essential oils. Both offer a spa-like experience.
Aug 27, 2008 | Whirlpool Pearl Ballade True Bathtub with...
Home Logo
232 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
