Question about GE HEPA 106653 Air Purifier
Red filter indicator light
The red indicator light is always on. Every time I change hepa and crbon filters the warning light still stqys on at the lowest level. Is the unit worn out? Is it costing more to opperate? It still takes a lot out of the air. We have a boiler system and no circulating air for filters, so I run about 5 Of these through the house
Thank You,
Re: Red filter indicator light
OMG, I am so glad I checked fixya out, as my filter has been on the yellow light, and I just figured the filters were bad, and changed them 2 times. They are very expensive.
I had no idea there was a reset button. I pushed it and nothing changed, but when I held it for a few seconds it went to green. Thanks all.
Posted on Mar 28, 2012
The previous post is RIGHT ON! I had to get a small screwdriver like for working on computers or sewing machines and push HARD to get the green light to come on. Maybe I broke something but, for now, all seems well.
Posted on Mar 30, 2008
This also is the case with the 106633 model and I must say, a pen or paper clip wasnt strong enough to depress the reset button but a small punch gave me enough leverage to do it. All is fine. My real complaint on this problem is that nowhere in the instructions is this said but is on a sticker inside the door at the bottom of the filter housing. Oh well, live and learn.
Posted on Mar 12, 2008
Hi Linda - there is a "reset" hole - you have to stick a pin or a paper clip in the hole when you change the HEPA filter - I just found this out myself! It does work. Mine didn't work right away, but it did end up resetting and went back to green after a few moments. I think this happened to me last time. The filters are really expensive, but you can get them at Walmart. If you need more information, email me at and I'll tell you what model filter, etc.
Posted on Nov 08, 2007
0 characters
3 Points
Constant red light
it may need a clean as there is a air flow sensor, if the flow is not right then it will have this on also a faulty sensor will read this aswell.
Mar 24, 2014 | Hoover AH60015 Air Purifier Replacement...
How to Reset Your Air Purifier Filter Light
<span style="font-weight: bold;">Airgle Air Purifier:</span><br /> <ol> <li>Turn off and unplug the unit </li> <li>Press the light button to the "on" position </li> <li>Plug in the unit, and then release the button after the Filter-check starts</li> <li>The system will automatically reset the Filter-Check Gauge in about 25 seconds</li> <li>Once the procedure has completed resetting, please turn on the unit and press "Filter Check" button again.</li> <li>This time, the system should report an accurate result. </li></ol><span style="font-weight: bold;">Alive Air Purifier:</span><br /> <ol> <li>Insert a straightened out paper clip into the reset hole, with the unit off, and push the Timer button.</li> <li>You should hear a 2 beeps, signaling that the Reset was successful.</li></ol><span style="font-weight: bold;">Holmes Air Purifier:</span><br /> <ol> <li>Units which have an indicator light must be reset once the HEPA filter has been replaced. Reset indicator by inserting a small object (such as a pin or paperclip) into the hole marked reset.</li></ol><span style="font-weight: bold;">Honeywell Air Purifier:</span><br /> <ol> <li>Reset the filter indicator by pressing and holding the "Filter Monitor" button until the indicator light shuts off.</li></ol>or<br /> <ol> <li>With the unit powered on, press and hold the appropriate filter<br />indicator button down for approximately 10 seconds until the<br />light turns off.</li></ol><span style="font-weight: bold;">Hunter Air Purifier:</span><br /> <ol> <li>Change the filter and/or pre-filter.</li> <li>Now, you must choose which counter you want to reset. Press and hold the filter reset key (approximately three seconds) until the prefilter indicator flashes. Press and release the reset key again to alternate between the two indicators. The counter that will be reset is designated by the flashing indicator. For Models 36394 and 36395: Use the tip of a pen or pencil to press the key.</li> <li>Once you have the correct indicator flashing, press and hold the reset key for three seconds to reset that counter to zero hours. The indicator will stop flashing when it has been reset. If needed, repeat these steps to reset the other counter.</li></ol><span style="font-weight: bold;">IQAir Air Purifier:</span><br /> <ol> <li>To reach the Filter Life Reset function from the main display window, press the Menu key seven times.</li> <li>Press and hold the Enter key until the flashing cursor appears. Release the Enter key. The first filter selection to appear is the Pre-Filter.</li> <li>Press the Up Arrow key to select the filter that has been replaced. The Filter Life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key to confirm that the selected filter has been replaced. The filter life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key one more time to confirm the filter change or to exit without resetting the filter life, press the Menu key (M=Menu).</li> <li>Upon successful reset of the filter life, the new remaining filter life (taking the currently selected fan speed into account) will be displayed, and the filter LED light on the control panel will change from red to green.</li></ol><span style="font-weight: bold;">Kenmore Air Purifier:</span><br /> <ol> <li>Press the FUNCTION and OFF TIMER buttons at the same time for five seconds. The CHANGE FILTER INDICATOR will flash five times and turn off </li></ol>
on Jun 17, 2011 | Air Purifiers
How do we change filters on a HAP8650 air purifier?
"After replacing the HEPA filters, RESET the Filter Life Monitor by inserting a small object (such as a pin or paper clip) into the hole below the red filter change light marked RESET and holding it down for 2-3 seconds." This came straight out of the Owner's Guide. Hope it helps!
Sep 13, 2012 | Holmes HAP8650 - HEPA Allergen Remover for...
I had a honeywell hepa air purifier 50250 given to me as a gift with no owners manual! Is there somewhere I can get one? also, there is buttons on the top, one saying check filter and the other saying pre...
The Intelli-Check™ Filter Monitors will indicate replacement of the pre-filter and the
HEPA filter. Depending upon your individual usage (environment and hours used),
you may need to check and replace the filters more or less frequently.
To check Expected Filter Life Usage
When the unit is turned on, quickly press the appropriate filter monitor button. The
pre-filter light will flash up to 3 times and the HEPA filter light will flash up to 4 times,
depending upon how much expected filter life has been used.
1 flash = from new, up to 1/3 expected life used up
2 flashes = between 1/3 and 2/3 expected life used up
3 flashes = between 2/3 and all of expected life used up
Remains on = time to check/replace pre-filter
1 flash = from new, up to 1/4 expected life used up
2 flashes = between 1/4 and 1/2 expected life used up
3 flashes = between 1/2 and 3/4 expected life used up
4 flashes = between 3/4 and all of expected life used up
Remains on = time to check/replace HEPA filter
To RESET Filter Monitor
When the filter monitor light remains on, it is time to check/replace the filter and reset
the filter monitor, if needed. With the unit powered on, press and hold the appropriate
filter monitor button down for approximately 5 seconds until the light turns off.
Page 6:
Mar 29, 2011 | Kaz Honeywell Hepa Air Cleaner (50250) Air...
Turn off reset button
Mar 19, 2009 | Whirlpool Whispure (45030) Air Purifier
Red light won't go off
To RESET the Electronic Filter Check:
When the filter check light remains on,it is time to check/clean the HEPA-Type
filters and reset the filter check,if needed. With the unit powered on,insert the tip of a ball-point pen or
paperclip into the hole next to the LED filter check light and hold for approximately 5 seconds until the
light turns off (Fig 5). Depending upon your individual usage (environment and hours used),you may need
to check and clean the filters more or less frequently. If the HEPA-Type filters are cleaned before the filter
check light turns on,the filter check should be reset at the same time.
These cleaning intervals are intended as guidelines only. Performance of any filter media is dependent
upon the concentration of contaminates going through the system. High concentrations of contaminates
such as dust,pet dander and smoking will reduce the useful performance of the filter.
NOTE:The HEPA-Type filters are not washable.
May 24, 2008 | Honeywell HHT-090 Air Purifier
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Hepa filter
    The red light indicates a plugged filter. Replace the filters plug the machine in and get a paper clip. Streighten out the clip and put it through the tiny hole in the top. You'll feel it push a switch that will give a click you can feel. Keep holding the clip wire down for several seconds. When the red flashes remove the clip wire. The light will stay off if the filter is clean.
    Aug 22, 2007 | Holmes Products HAP422-UC Air Purifier
    Red Light indicator on
    I have a Bionaire tower air filter model BAP1700 that I bought from Costco. The filter check LED came on recently after 5 months of use. After cleaning the Permatech filters, I tried every remedy on this website including following the instructions that say push power button for 2 secs. Nothing worked. Then I noticed a tiny hole on the control panel in front of clean filter LED; I pushed a paper clip pin into that hole, felt a click, held it down and 2 secs later, LED went out. Success!
    Apr 06, 2007 | Bionaire BAP1500-U Air Purifier
    Red Light on front of Filter Queen Defender
    When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking. It cured my problem.
    Mar 06, 2007 | Filter Queen Defender Air Purifier
    GE HEPA 106653 Air Purifier Logo
    593 people viewed this question
    Top GE Air Purifiers Experts
    Are you a GE Air Purifier Expert? Answer questions, earn points and help others
