Question about Philips 32PT6441/37 32" TV
Phillips QuadraSurf 32PT6441137 won't turn on no matter if I use the remote or the power button on the tv. It acts like it is going to start then turns off immediately and the standby light blinks.
  • anniechar1 Jun 25, 2009
    I will have to ask my husband if we want to try to fix it or call for service. Neither one of us are very mechanical. I won't know if the suggestion works until it is tried. Thank you.
    Diane
  • 6,784 Answers
HI. This is the result of a power sector failure. the fly-back transformer has failed. replacing this component will fix this issue.
The fly back regulates the current and, the signal drivers and, capacitors distribute the stream throughout your unit. this power sector or, board, is damaged at this point. replacing these parts or, assembly(board), will restore normal functions.
Contact Phillips for the necessary parts needed for a do it yourself. if you are not considering a do it yourself, a service call is recommended.
Posted on Jun 25, 2009
Philips quadrasurf TV
Analogue TV reception has nothing to do with signals from Blu-ray players.
Connect your Blu-ray player to either a HDMI port on the TV, or use a HDMI to DVI adapter (which is picture only) and supplement it with a a connection for audio via RCA/phono- or RCA/phono to jack cable from the BD player to the TV.
Press the AV Input button on the remote to cycle through the input sockets.
Sep 08, 2014 | Philips 40MF430B/F7 model Magnavox LCD TV,...
How to program my quadra surf remote to hitatchi television
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jul 15, 2012 | Thomson 14MG135 14" TV
I NEED TO PROGRAM A MAGNAVOX TV WITH A PHILLIPS UNIVERSAL REMOTE CONTROLL
Find codes and methods here.
http://www.docstoc.com/docs/23925020/Programming-Remote-Control-Brand-Codes-TV-Sets
If those codes dont work try the last three(or four) numbers of your TV's serial number.
On my universal remote is just a matter of holding down the TV button till the light stays on, then punching in the three digit TV code. When the TV turns off it's the right code. But read your manual for your controller.
Oct 08, 2010 | Universal Remote Control Universal IR...
NEED SONY CODES FOR PHILLIPS REMOTE
Universal Remote Control Simple Setup
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote!
Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Jan 02, 2010 | Philips Magnavox Learning Universal Remote
No code for remote
www.universal-remote.net/philipsmagnavox.html
Oct 18, 2009 | Philips Universal PH301S Remote Control
Need codes for Philips QuadraSurf TV remote
tv code for toshiba tv using Philips QuadraSurf TV Remote # RC1903600
Sep 16, 2009 | Philips Universal PH301S Remote Control
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Tv turning on and off itself
Try "hiding" the remote from the set so that the TV cannot "see" it. Hope this little trick helps...accordianman
Jan 22, 2008 | Philips 43PP9202 43" Rear Projection...
Tv wont come on
Rebuild with upgrade kit #483531057673.
Oct 05, 2007 | Philips 32PT5441/37 32" TV
Philips 32PT6441/37 32" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
