Question about Kenmore 18 in. 14432 / 14439 Built-in Dishwasher
Pump Sleeve and seal for 18" DW (part # 154387601) does not fit
The motor shaft is sleeved with a rectangular plastic piece. The sleeve on the new part can't possibly fit on this shaft. The Sears diagram shows what looks like a hollow sleeve; the new part is hollow on one side and solid on the other. Is there a mistake with this part#???
  • Anonymous Mar 14, 2014
    we are having problem inserting new plate fitting parts as we have no diagram
  • 999 Answers
It is correct, the grooved side goes down towards the motor.
Eric
Posted on Jun 25, 2009
How do I get the piece that turns the flex shaft that is attached to motor shaft off
Don't know what type trimmer you have but many have a bell housing with long sleeve that the shaft fits in. You have to remove flex shaft and look inside the sleeve there is a Allen head or star head screw in center these normally turn ccw to remove but some turn cw.
Sep 23, 2017 | Garden
Cambelt timing marks 4jx1
sounds like the injector sleeve O rings have failed this was common.
if you put a clear plastic piece of hose on supply line for diesel fuel filter to head fitting at front and fuel is not black but normal diesel colour thats good.
then put clear hose on return line fitting at rear of cylinder head and fuel is now darker, engine oil is by passing injector sleeve top O rings and entering into fuel gallery in head.
rocker cover, injector rail, injectors need removing and injector sleeves need replacing as well as O rings and seats.
a special tool is needed to remove the injector sleeves out of the head. you will also need to drain the cooling system before removing the injector sleeves, so coolant is also needed.
dealers have special tool for injector sleeves
Mar 28, 2014 | 1998 Isuzu Trooper
I have a motor with a 3/4 inch shaft and a pump with a 5/8 inch sleeve. Should I replace the sleeve or the shaft?
Neither you hack, get the correct pump or a motor that fits the one you have! You're not an engineer or scientist so just do things the right way.
Oct 31, 2013 | Karcher 2500 PSI Pressure Washer
I have a sears aircompressor model# 919.163450 Broke off intake muffler How do I get the rest of it out {plastic sleeve in head housing}?
Hello, what I do when I have a problem like this is I find a piece of metal (chisel, screwdriver) that fits the inside of the broken part (the tool is slightly larger than the inside diameter of the sleeve) and push firmly while turning counter-clockwise removing the broken plastic sleeve. Sometimes, if a tool will not fit on the inside of the sleeve, then I push it against the broken stub of the sleeve, and push against the stub while turning out the sleeve. I hope this helps.
Jan 11, 2011 | Garden
I replaced the powerhead drive belt. Now (2 times) while vacuuming the powerhead motor appears to run backwards. Because the metal pully which has left hand threads on it will backout / unscrew it self....
Look at your power head motor. If you see a fiberglass looking sleeve on the shaft where the belt attaches to it, you need to remove that. You can slip it off, chip it off, or break it off piece by piece. You can usually use pliers and break it into pieced until you get it all off. It could also have a metal sleeve or a plastic or rubber sleeve on it. You will be able to tell if it has any sleeve on it. If it does remove what ever sleeve that it has. Tighten the brushroll pulley snugly tight. That should do it.
If you have any more questions, let me know,
Ralph
Sep 11, 2010 | Rainbow 75th Anniversary Canister Vacuum
Steering wheel changes
Here is the simple steps to change the old steering wheel and install the new one.
Remove the Original Steering Wheel
1.Read instructions that come with the steering wheel, and gather the following tools: screwdriver, pliers and a puller.
2.Point wheels straight ahead.
3.Disconnect battery or pull horn fuse before removing the old wheel. This prevents the horn from shorting out or blowing during installation.
4.Remove the horn mechanism by doing one or more of the following steps: Press down on the horn cap or ring and turn; remove the emblem cap from its snapped-in position by grabbing it and pulling it toward you or prying it loose; or if the horn ring is secured by screws that are concealed in the rear side of the wheel spokes, use a screwdriver to remove the screws and the ring.
5.Remove horn wire or spring-loaded metal plunger from plastic housing by either pulling straight out on the metal plunger or, on most models, by twisting the plastic sleeve to the left and then pulling out. Cut the wire off the plastic sleeve and keep the sleeve for later use.
6.Remove the shaft-nut retainer clip, if it is present, and keep for later use. Remove the shaft nut, which holds the wheel to the shaft.
7.Mark the shaft at the twelve o'clock position so that you will know where to position the top of the new wheel.
8.Insert a conventional puller into the two tapped holes which appear in the hub of the old wheel and pull off the steering shaft.
9.Remove the original wheel.
Installing the New Steering Wheel
1.Place the small tubular metal sleeve down over the steering shaft.
2.Position hub on splined shaft, making certain that the shaft is properly positioned using the mark you made in step 7. You may have to rotate the plastic horn contact tube slightly to align it with the appropriate hole through the hub.
3.Insert plastic sleeve and spring from step 5 without wire into plastic horn housing. If the plastic sleeve extends above the top bolt surface of the custom hub, cut down the sleeve so that it is 1/8-inch below the top of the hub. Remove sleeve.
4.Insert through the plastic sleeve the wire lead that was supplied in the wheel kit. One end will not pass through the sleeve. This bell-shaped end will go into the horn contact housing. Insert the sleeve and wire into the housing and lock into position.
5.Route wire around the hub from the ten o'clock position to about the two o'clock position to properly align wheel. Position post cover and wheel on hub. Make certain that the wire lead passes through the appropriate holes in the two o'clock position. Using the three shoulder bolts provided, fasten the hub, post cover and wheel together, but do not tighten.
6.Check wheel for proper positioning. If correct, reinstall the shaft nut from step 6 and tighten. Reinstall shaft-nut retainer clip. If the retainer does not fit into the groove on the shaft, tighten the nut until it will fit as originally located.
7.Remove shoulder bolts and reinstall them through the retainer ring with the fiber side toward you. Tighten the shoulder bolts with caution - excess torque will result in damage to the hub. The shaft nut, if correctly tightened, will firmly hold the hub and wheel assembly on the shaft.
8.Connect wire lead to the connector on the retainer ring. Position spring on center nut. Align the dimples of the horn cap with reliefs in fiber material and push into the dimples past the fiber. Turn cap left or right until tight.
9.Reconnect battery or replace fuse.
Sep 09, 2010 | 1991 Honda Accord
I need to remove the plastic motor shaft sleeve from my Cuisinart DLC10. THe old one cracked, I have a new one but the old one won't slide off...
Many people have had this problem. When I called Cuisinart, they said, oh sure we will send you the part and instructions. When I called because there were no instructions, I got another story about how I needed to send it back because that repair is only made at the warehouse. I have found other places online where people just chip and pick at the plastic until it comes off. Short of sending it back and paying the shipping I don't know what else to say. My husband is chipping and picking as we speak.
Jan 02, 2010 | Cuisinart DLC-10S Pro Classic Food...
Input shaft seal leaking after replace seal
Firstly, make sure the seal you fitted is the correct one, sounds silly but I have been given the wrong seals by parts people. It pays to check. Next, if you have fitted the seal correctly, and made sure that the seal is in flush with the housing, then it may be that the shaft is worn and may have a groove in it which was caused by the old seal. Pull the shaft out again and check for this groove in the shaft. If it does have the groove, you will need to find and purchase a steel sleeve which is fitted over the worn section of the shaft and ensures a nice clean and tight surface for the new seal to run on, thus stopping the leak.. Here in australia these sleeves are called "speedy Sleeves" and are available from any bearing shop and auto parts stores. The sleeve has a removable step on it which is used to tap the sleeve onto the shaft ( with a small hammer) and is then removed by twisting it sideways with pliers or sidecutters. The sleeve has a scored edge to help with this. Once you have removed the step, carefully clean up the edge with very fine grade rubbing paper ( wet and dry or fine emery cloth) with Oil applied to it to remove any sharp edges BEFORE you refit the shaft into the gearbox. This ensures that the new sleeve does not damage the seal. Re-assemble everything and test drive. As long as the seal is correct and fitted correctly and the sleeve is fitted correctly this will stop the leak. Have fun..
Oct 31, 2009 | Ford Festiva Cars & Trucks
Plastic sleeve on shift linkage cable is broken
You cannot take the sleeve off. It comes with a new cable. Shift cable is enough for any parts man to know what you need. Generally this item is a dealer part.
Mar 26, 2009 | 1996 Chevrolet C1500
Water dispenser not working
The reservoir is in the back of the fridge compartment behind the bottom crisper. The inlet and outlet tubes are permanently crimped into the resevoir. I cut them off, drilled out the inlet and outlet on the reservoir, and then used hose clamps when reinstalling.
Nov 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 18 in. 14432 / 14439 Built-in Dishwasher Logo
213 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
