Question about Elan Audio Players & Recorders
Have an Elan S6 need speaker connectors. They have specific connectors and i just recently moved and the movers disconnected the wires without thinking to keeo the adapters....
2 Suggested Answers
  • 3 Answers
SOURCE: Leveler Leg
this company has gone out of buss,? but the speaker company.com has either bought there exsisting stock or reproduced the same speakers i have the ST3 model that is now called TST3 or TST2 higher the # the more bass it can handle. awsome speakers and you cant beat the price. sorry if my typing stinks but i hope i helped someone out there if you bought sapphire when they where a hot item here's your answer lol pete n.j.
Posted on Aug 14, 2008
Arcam avr-250 shuts off?
New problem?
Did you move it recently? Sometimes the speaker wires are stripped too long and short out against each other in the back
Disconnect EVERYTHING from the unit but please take great care to document how everything is connected so you can connect it again the same way.
IF the unit powers on fine with everything dis-connected, I can assume that you have a connections problem with the speaker wires being the most likely culprit.
Make sure your speaker wires are not stripped too long where bare copper is touching other terminals OR make sure the speaker wire is pushed cleanly into the speaker connections without stray wires to cause a short.
Also make sure you have the speaker wires connected to the proper terminals and are not mis-wired into the wrong terminals.
IF it still shuts down after a few seconds with nothing connected then there is an internal problem that will need to be repaired.
Good luck.
May 28, 2014 | Audio Players & Recorders
Elan wall speaker mounts
Try Radio Shack, Best Buy, Sears, or eBay.
Apr 13, 2012 | Elan SEL350 Speaker
Canon ir 600 error e537
E537
The front aligning plate does not reach home position when the front align-ing motor (M3) is driven for a specific time.
The front aligning plate does not leave home position when the front align-ment motor (M3) is driven for a specific time.
Possible causeThe front alignment motor (M3) is faulty.
The front aligning plate home po-sition sensor (S6) is faulty.
The sensor connector is disconnected or has anopen circuit.
The front alignment motor relay harness if faulty.
The frontaligning plate is subjected to an abnormal load.
The finisher controller PCBis faulty.
Remedy1)Front aligning plate home position sensor (S6)Check the front aligning plate home position sensor (S6).
Is the sen-sor normal?NO:Replace the sensor.
2)wiringIs the wiring between the finisher controller PCB and the frontalignment motor (M3) normal?
NO:Correct the wiring.
3)Front aligning plateIs the rack riding over the collar of the roll?YES:Correct it.
Nov 21, 2011 | Canon imageRUNNER 600 Printer
Installing a speaker on the passenger front door on my acura tl 2005. There is a red and blue wire!! Which color in positive and which is negative??
As far as i know the "RED" wire is usually the Positive + wire on those cars
But if you really want to be 100% sure you can do this little test..
(This is assuming that you are removing the stock speaker and replacing it with a better one? )
Anyway just look at the old speaker with the wires plugged into it like it was before and make a note of witch wire goes to what connector on the speaker
Then disconnect the wires and touch the two terminals on the speaker with a 9volt battery and if the polarity on the battery is correct on the speaker it will move outward and if it is reversed then it will move inward... that is a good way to determine the polarity of the speaker itself then you can look to see witch wire goes to what connector on the speaker and that should tell you which wire the positive one is
Hope this info helps
Jun 23, 2011 | Kenwood Car Audio & Video
Moved to a new house, set up tv.........no sound. volume control moves but no mute to be found. no remote either.
Check the speaker either its disconnected to connector.try to open the cover of ur tv and check the connection of the wire to speaker.
Apr 04, 2011 | Pioneer PDP-6071HD 60 in. Plasma...
Need speakers for a 2001 Saturn L300
Your best bet for replacing with OE components, without going to a dealer and paying their prices, is to visit your local salvage yard and pull them out (if you can do that). My local yard only charges $4 per speeaker, regardless of size or specification.
Aftermarket replacements will require some wiring to the extent that you'll need to change the plug-end on your existing speaker wiring to female blade terminals that will plug onto the aftermarket speakers. The speakers will work well with your OE head unit, though. There is no need to replace anything other than the speakers and the wire connectors when upgrading your audio components for replacement purposes only.
I don't have the information for speaker size in front of me, but I can find it if you need it.
Dec 30, 2009 | Car Audio & Video
I Need the Wiring guide
1992 Saturn SL2 Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Radio Ground Wire: Black
Car Stereo Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
May 21, 2009 | 1992 Saturn SL2
Wiring harness damaged during move
Jay Give Me a Model and Make and year and A little bit better disciption where these wires are
Jul 20, 2007 | Samsung HCN653W 65" Rear Projection...
Speaker and Mic problems
Hello Elan, You will need to have the device dissasembled and checked for a loose connector to the mainboard. Those 2 components are linked to the mainboard via a ribbon like cable that may not be making a perfect electrical contact. It'a a cheap repair, you don't have to worry, other than that if the device is still in warranty it will be made for free.
Jun 05, 2007 | i-mate JAM Pocket PC
Leveler Leg
Nov 15, 2006 | Sapphire Technology ST2B Main / Stereo...
194 people viewed this question
Top Elan Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Elan Audio Player and Recorder Expert? Answer questions, earn points and help others
