Question about Ricoh Aficio 2020 All-In-One Laser Printer
Service problem service code s556
Re: service problem - Ricoh Aficio 2020 All-In-One Laser Printer Printers & Copiers
Ricoh 2020 scaner giving error 8191
Posted on Aug 05, 2008
  • 37 Answers
Re: service problem
This code is a fuzing unit code , one of your thermosters are busted or dirty so it is not picking up the heat correctly , ill sugest you take out the fuzing unit and clean both thermosters and try again , but you need to reset the code after cleaning the thermosters by pressing :yellow c 107 and hold down orange c until it shows copy sp mode press 1 # then turn the power switch on and of hope this helps
Posted on Jan 07, 2008
0 characters
3 Points
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
Mar 26, 2012 | Canon LASER SHOT LBP-2900 Printer
Sharp Copier Call for service code # H5-01
If you experience <span style="font-weight: bold;">Call for service code # H5-01 </span>just follow the steps below.<br /><br />You might need to run a service mode to reset the machine:<br /><br /><b>P * C * 14 (start) then 1 for Yes</b> and follow on screen directions, code should clear out<br /><br />Or <br /><br /><span>Press <span style="font-weight: bold;">Program Key(P)</span>, <span style="font-weight: bold;">Asterisks</span>, <span style="font-weight: bold;">Clear Key (C)</span>, <span style="font-weight: bold;">Asterisk</span> . when the stand by for simulation code appears type <span style="font-weight: bold;">14</span> to cancel the trouble code</span><br /><br /><span style="font-weight: bold;">Thanks for using Fixya.</span><br />
on Mar 09, 2011 | Printers & Copiers
Panasonic dp 2000 pm error code e04-01 need help
this is fixing error
enter the service mode
Apr 02, 2010 | Panasonic Workio DP-2000P Copier
Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Jun 09, 2009 | Ricoh Aficio AP3800C Laser Printer
Service Code SC 542
That is fuser code and needs to be reset in the service mode, it will not go away by turning the off and back on.
May 29, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Service code SC 548 on a Ricoh Aficio SPC 811dn printer, what is it and how to correct?
I have sc 548 error code also. I was following your instruction, but i couldn't enter to service mode. How do i prepare it? Please write this instruction to me step by step.
Apr 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Need to know how to enter service mode on muratec mfx-2830
Do you mean Service CODES or Service Program MODES? Do you realize that there are almost 800 - 900 service codes and or program modes.... you would do better searching for a service manual for that machine, that will list the codes with explainations and program modes and what they affect when changed.
Apr 03, 2009 | Muratec Printers & Copiers
what is code nomber please send me
Jan 13, 2009 | Sharp AR-651 Copier
CODE H5-01
how to clear the problem, it shows:
call for service. code: H5-01
Apr 22, 2008 | Sharp Printers & Copiers
Error code
Hi Sorry cant send manual U have to buy like every one else.But here are the codes you require It is service code 24 sub code 04 to reset PM counter and sub code 07 to rest drum sub code 09 to reset print count and sub code 11 to reset developer. Hope this helps
Aug 18, 2007 | Sharp AR-5316 Advanced Digital Imager...
Ricoh Aficio 2020 All-In-One Laser Printer Logo
176 people viewed this question
Top Ricoh Printers & Copiers Experts
Bernard D'Souza
Are you a Ricoh Printer and Copier Expert? Answer questions, earn points and help others
