Question about Kenmore Elite Oasis 27052 Top Load Washer
Top load direct drive will not spinn, but pump
  • 58 Answers
Oasis checks are complex if this is what it is, most likely you will have an error code, what is it? If its not an oasis, but a reg top loader, replace the motor/transmission isolation coupler.
Posted on Jun 25, 2009
Cloths come out wet after spinn
The water drained out ok? If yes, the timer is telling the motor to reverse and run in the drain spin direction and it is likely ok. If the draining is slow the clothes could come out wet, if the belt is cracked or streatched the clothes could come out wet. If the motor is not running through the entire spin/drain mode the timer could be at fault.
Will Not Spin
• Check for unbalanced load.
• Check for broken or slipping belt.
• Does the house drain system accept water from
machine?
• Check for blocked drain hose.
• Check for binding tub seal.
• Check for partial engagement of brake assembly.
• Check for obstruction between tubs.
• Check for broken impeller on pump.
Jan 02, 2012 | Amana NAV5800A Top Load Washer
Agitates and drains but smokes when it is time for finall spinn....wont spinn
Thanks for choosing FixYa and welcome. You need to make sure you don't have a frozen pulley. The belt may be causing the smoke you are seeing. It may be coming from the motor drive. None the less, it needs checked out.
Jan 09, 2011 | Crosley CAWC529JQ Top Load Washer
After the final spinn cycle ther is still water in the washer
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag alantis top load washer and it drains out put it seems it dosn 't spinn
heatman101
Sep 20, 2010 | Maytag Washing Machines
The drum will not spinn?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 20, 2010 | LG WM1814CW Front Load Washer
I have Kenmore Series 70 using about 4 years. I realized that my washer won't empty out the water and won't work any of spinn either. Someone told me that need to switch time click and others? How can you...
Assuming that this is a basic Kenmore / Whirlpool direct drive, top load, neutral drain washer.
If the machine fills with water and goes through its' agitate cycle, the motor is working as is the transmission (At least in one direction.
The timer on type of machine reverses the motor to drive the pump and run the spin cycle.
If the machine.
Check this Sears parts site and the Whirlpool Installation and maintenance document to see how the machine works. It appears that you do need a timer.
Sears parts:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components.
Whirlpool document:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Sep 22, 2009 | Kenmore Washing Machines
It won't drain correctly and doesn't spinn. I think the inside drain is clogged with dog hairs.
sounds like the transmission drive has gone bad in unit it runs pump and spins drum
Jul 06, 2009 | GE WBVH6240F Front Load Washer
Top load direct drive will not spinn, but pump water out.
COUPLING BETWEEN MOTOR AND TRANSMISSION IS SHEARED AND NEEDS REPLACED.
Jun 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer doesn't spinn
Defective Lid Switch
Hello
jimen6lWelcome to Fixya
My name is Huum,
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
Faulty Direct Drive Coupling
The Direct Drive (motor) Coupling may be broken. Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
Water Level Switch
If the water level switch is not resetting once the water is drain, power will not be available to operate the motor during spin. Check the water level switch for proper operation.
Thank You For trusting us with your question
Please remember to leave a rating before you leave!
Dec 16, 2008 | Maytag PAV2300 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
107 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
