Question about Belkin (F5D7230-4) Router (587009)
Very short range of wireless network
We have a Belkin Wireless G router type: F5D7230-4. It connects two main computers and two laptops, one of which is a Mac. We are going to connect a third laptop eventually. At the moment we are having difficulty with the range. Our laptops connection is very iffy. Usually we have to move them within about ten meters of the router. According to the catalogue the router should have a range of 400 feet.
Please point us in the right direciton.
    Brigadier General:
  • 6,966 Answers
Re: Very short range of wireless network
Your Belkin Wireless router being an RX/TX device follows the basic rules of radio communication:
1. LOS - line of sight range; anything in between the router and the laptops such as doors, walls, drapes, foliage is an obstacle that reduces the signal strength to a certain degree;
2. Height is might, the higher the router the better;
3. Antenna, the more exposed the further the range. Internal antennas such as in most laptops reduce both receive and transmit. Likewise, placing the router in a shelf or cabinet reduces antenna exposure. How you position (orient the antenna also plays a role in coverage. Some materials will reflect radio signals and change antenna radiation pattern.
A few things you can try to improve coverage:
a. Mount the router to the highest practical position;
b. ensure that there are no obstruction between router and laptop;
c. position router to approximate practical center between two furthest laptops;
d. install an external antenna if the Belkin would allow;
e. Replace the F5D7230-4 with another with more punch such as a LinkSys WRT300N; and/or
f. In really extreme range, install repeaters.
Hope this be of some help/idea. pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 05, 2007
0 characters
3 Points
I have belkin connect n150 and i have two laptops my one laptop is connect to wireless but the one laptop cant access to wireless it says no wireless network were found in range..
If your message is like this " no wireless network found in range make sure wireless on the computer is On". All you need to do is look for the wireless switch usually located on the side or the back of your laptop. Sometimes its near the F keys or start button. You may check your laptop manual to see where to locate the wireless switch , or you can check the laptop manufacturers website usually they gave information on where to locate or enable the wireless feature of laptop.
Mar 30, 2011 | Belkin Basic Wireless Router
Hi I have just installed a brand new Belkin wireless router and it works great with all computers and laptops in the family (including Apple products) apart from my daughters laptop...she has a toshiba...
Check the main computer you set up the network router may need to go to the network status and tasks in control on this...then you will see a map of all the network devices connected...find the belkin router and click on this window there should be a tab called wireless this...the wireless properties first page should have the wireless SSID name listed here...and if you click the security tab then the security type and network key are displayed here..You need to write down the SSID, security type, and network key and make sdure the toshiba laptop setting for the wireless network are exactly the same. There may be a link on the first page of the wireless securities saying copy to usb can use this to copy all network settings to and then transfer these settings in to the toshiba by using the network setup wizard.
Jan 04, 2011 | Belkin (F5D8231-4) Wireless Router...
I have a belkin wireless router it works fine but i dont know how to get the laptops to work as wireless, i also dont know how to change the password or any keys to get the other laptops to works, thanks...
is it a wireless computer or the wired computer?
I believe the main computer is online.
Check the settings on the router.
You will need to open the router set up page.
here you will see the settings of the router.
If you are trying to connect to the wireless network then make sure that you are typing the correct network key.
Click here for more information about routers and network
Aug 13, 2010 | Belkin Routers
We have a belkin.49ed router and hooked it up. It
The wireless security of the Belkin must have been enabled. Use a computer wired to the router to access the setup page and get the network key.
In the address bar of your browser, type
By default, leave the password blank.
Once on the setup page of the router, go to Wireless -> Security. You will see the network key here.
On your laptop, view the available wireless networks and you should see your wireless network name or SSID, then when you click connect you have to enter the network key.
I hope this helps!
Jul 18, 2010 | Belkin Wireless Share Router (F7D3302)
Where do I enter the wireless router password on my laptop
Hi Friend,
Step 1; Try to search for wireless networks in the range from your laptop
Step 2: You will be able to see the Network Name
Step 3: Connect to the Wireless network name
Step 4: Now it will prompt for Network Key or security key,Type the password,you will be connected
Jun 04, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
Wireless connection to belkin g router model no. f5d7230-4
You need to access the setup page of the router using connected computer.
In your browser's address bar, type
On the Belkin setup page, go to Wireless.
Take note of the SSID. This is the name of your wireless connection.
Then go to Security under Wireless. Copy the network key.
On your friend's laptop, view the available wireless networks, you should see the SSID, then just enter the network key.
I hope this helps!
May 18, 2010 | Belkin (F5D7230-4) Router (587009)
I am using a Belkin router and I cannot connect to Internet
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Jan 05, 2010 | Belkin (F5D7231-4) Wireless Router
Cannot get wireless connection onlaptop .
you can try disconnecting and connecting again from your wireless network. if that doesn't work, try to access the configuration page of your wireless router, try to type in a different password for your wireless network and try connecting again.
Jul 11, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
My Belkin G Wireless Router won't connect to my laptop.
this type of problem can be fixed in simple steps -:
1. first check all connections, check lan driver
2. update belkin firmware,and restart laptop
3. restart belkin router and go and connect the laptop
4. for more information contact belkin Services i hope this will solve your problem..thanks
Mar 17, 2009 | Gateway Belkin F5D7230-4 802.11g Wireless...
Cannot connect new laptop to wireless network. Belkin Wireless N
The wireless settings on the laptop and the router should match. To check the settings on the router you need to access the setup page by typing in a web browser's address bar.
By default the password is blank.
Click the Wireless tab. And take note of the SSID or wireless network name.
Go to Security, then Wireless. If the wireless security is enabled, copy the network key or security key.
On the wireless computer, you should detect SSID and if wireless security is enabled, connect to it with the correct security keys.
Hope this helps! Good luck!
Feb 22, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin (F5D7230-4) Router (587009) Logo
163 people viewed this question
Top Belkin Routers Experts
 C. Dante
C. Dante
steve morris
steve morris
Are you a Belkin Router Expert? Answer questions, earn points and help others
