Question about Mitel 5212 IP Phone
Ring tone for internal and external calls
I need to differentiate the ring tone for internal and external calls. How do I do this in a Mitel 5212 IP Phone ?
  • 37 Answers
This is a change your system administrator will need to handle, (or your phone tech). There is an option in the under "system options" called internal ring cadence for external callers; this is where you can have the system do a double ring for External and a single ring for internal or vice versa.
Posted on Oct 14, 2009
Testimonial: "It worked !!. Thanks !!"
Problem with Mitel 5212 IP Phone
Need to login to. The phone system and change it back.
Jun 06, 2013 | Mitel 5212 IP Phone
Cannot get incoming calls on my Mitel 5212 IP phone. When my colleagues phone internally, they get the "NO DISTB" message.
Your phone is in Do-Not-Disturb. Press the blue superkey. Press No until you see DND or Do-Not Disturb and press yes... press Turn off.
on this phone, the * and # are the keys for yes and no.
Nov 11, 2010 | Mitel 5212 IP Phone
Where can I find an online user manual for the Mitel 5212 IP Phone? Quick reference guide says to go to www.mitel.com, but found nothing there.
I have exchanged the telephone on my desk but cannot get a ring tone or flashing lights for incoming calls?
Nov 08, 2010 | Mitel 5212 IP Phone
I can't pick up a phone call
Call Pickup doesn't ring your phone or light up. Your 5212 phone isn't considered a "display phone" Meaning that the display doesn't have softkeys. These are the 3 keys directly below the display and their function changes as you are using the phone.
Your phone's Pickup Key should be used if you want to pick up a call that is ringing on a nearby telephone... usually only the phones within earshot of your phone.
You must pick up the handset, then either press the call pickup key or dial the call pickup feature code.... this code can be different for every system as it's custom from the install vendor.
I hope this helps.
Mark
May 24, 2010 | Mitel 5212 IP Phone
Disable external calls on mitel 3300
This is a function your phone vendor will need to complete for you specifically they will need to setup a Class of Restriction for the set that you would like to block from using your outbound trunks.
Nov 25, 2009 | Mitel 5212 IP Phone
Can't activate voice mail on Mitel 5212 IP phone
You need to verify your Call rerouting, you will also need to clear any call forwarding that might be active. Its possible the system is not able to transfer a call to the forwarded location.
Sep 29, 2009 | Mitel 5212 IP Phone
I have a Mitel 3300 and one of my voicemail extensions never answers. It just rings and rings.
system administration, Call handling,Call re-routing. make sure the phone is call routed
Aug 11, 2009 | Mitel 5212 IP Phone
Mitel 5212 no dial tone and goes straight to voicemail
Not too sure about the no dial tone issue, but you can check to see if the DND is turned on...
Press the Blue Superkey and scroll thru till you see DND (Do Not Disturb) is on and shut it off.
Jul 20, 2009 | Mitel 5212 IP Phone
We have a mitel 3300 connected to cisco CM thru siptrunk
can somebody help me we have a Sip connection between a mitel 3300 and Cisco callmanager only the conference call doesn't work who can help me out
Apr 02, 2009 | Mitel 5212 IP Phone
At our tech support centre we have installed total mitel solution. This includes your MItel 5212 IP phone. Can you provide me details of any headsets which can be Y-JACKED with youe 5212 ip phone and used...
There are a number of Headset that will plug directy into the back of your 5212 phone. (I would suggest Googling for results) As for Monitoring an agent the Mitel ICP has the capability to allow a supervisor to dial a code and mointor the agent while on a call. Contact you Mitel Vendor and I'm sure they would be happy to make the program chage for you. (This is a class of service and Feature acces code change)
Jan 19, 2009 | Mitel 5212 IP Phone
Mitel 5212 IP Phone Logo
804 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
