Question about DeVilbiss Traveler Compressor Nebulizer System
My Devibiss Traveler is not staying charged and keeps losing power even when it is plugged in.
  • ptlsn Jun 25, 2009
    I can't find my manual, but it seems like ther was a sticker attached that told what to do when the battery wouldn't charge.
  • 6,784 Answers
HI, this is just a bad cell. the battery cell only has a set amount of physical charges(6000hrs). when this limit is reached, the cell will not be able to hold a charge again. The best action is to contact the nearest service depot or, try contacting the manufacturers accessories department for a new cell. this will fix the issue.
Posted on Jun 25, 2009
This would indicate a failed battery or memory loss effect on the charge area of the battery. Replacing the battery should solve the problem.
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
Battery light stays on car loses power, battery won't stay charged
check charging system like altenator or make sure battery cables are clean and tight. go to advance or autozone they will check it for free.
Jul 09, 2012 | 2008 Dodge Avenger
Power plug on chair losing power
The problem may be that the power cord's internals were broken by keeping the wire plugged into the chair at a bad angle That damaged the connection. If this is the case, you may need to purchase a new power cord.
Try shopping online for a replacement or calling the manufacturer.
Jun 01, 2012 | Pyramat Sound Rocker Gaming Chair
Even when my gps is turned off it loses battery power. How can I get it to stay charged?
You could hard wire the car power adapter for your gps to a Constant 12 volt wire and ground to prevent your gps from losing it's charge. Else you will need to plug in the car charger for your gps and charge the battery a bit before you can use it.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Oct 01, 2011 | Nextar X3 GPS Receiver
Just tried turning i phone on after a couple of months of not using it but no joy. Doesnt even register its charging. Help
Hello teresadonach!
Your iPhone is probably fine! When a device using a battery isn't used for an extended period of time, the battery still loses its charge. More than likely, the battery is completely drained and will require you to have it plugged in for 15 to 30 minutes before even getting a charge indication. The time varies depending on device.
Keep it plugged in for about 2 hours and check back! As long as it was working fine when you stopped using it, it should power on!
Please remember to rate if this was helpful!
Mar 18, 2011 | Apple iPhone Smartphone
When I turn on my laptop the power lights up and shuts off after a few seconds
either a bad battery, or charge port. even if the battery was fully charged it will still keep the light on, try this. plug it in, and power it on, then remove the battery completly, the computer should stay on, as its running off the plug power cord. if this port is a bad one the pc will shut off immeadatly. and if it stays running then it will be the battery.
Jan 06, 2011 | Gateway M-6843 Notebook
My Toshiba laptop model A215-S4807 will not hold a charge
Hello. It might be a problem with the charging set. If you took another charger and it did not work it is from your mainboard.
Feb 22, 2009 | Toshiba Satellite A100-S8111TD Notebook
Low battery, wont' charge in car
I pushed the reset button, on the side,during the brief moment that it stays powered up. Now it is staying on with the wall plug.
I'll let that stay on for a while and then try to keep charging it with it turned off.
Aug 10, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Battery Depleted
Are you able to run the laptop with no battery installed but the power cable plugged in? If not, there's a good chance your power jack on your laptop has broken (or almost broken) and will need to be replaced or the power adapter isn't working.
If it does run, your battery is probably bad and can't take any charge. It will need to be replaced.
Apr 10, 2008 | HP Pavilion dv1000 Notebook
DeVilbiss Traveler Compressor Nebulizer System Logo
56 people viewed this question
Top DeVilbiss Health & Beauty Experts
syspro
Tom Chichester
Are you a DeVilbiss Health and Beauty Expert? Answer questions, earn points and help others
