The lines freeze up outside and then it shuts off
  • 43 Answers
When the refrigerant piping ices the cause is usually low or refrigerant (Freon is Dupont's name for Refrigerant) or the evaporator coil is not getting enough air flow thru it. It would be best to have a qualified technician test your system.
Posted on Jun 25, 2009
Any chance for repair? Had a very unusual artic front come down here and it apparently froze up in the unit.
Open up the shower head so its open put heat it to room to help defrost lines . Or use a blow lamp on line to defrost or use heat tape
Jan 18, 2018 | Refrigerators
Kozyworld kwp324
Sounds like water in the line. You could try wrapping the gas line
with insulation, like it was a water pipe.
Can't the gas co. flush the line? OR suggest a fix for a valued customer?
Feb 06, 2014 | Heating & Cooling
Sump Pump Ejector line (outside) freezes.
IF the drain on the outside of the home is in the ground and is not below the freeze / frost line, it needs to be changed. If the drain is above ground at any point it needs to be unhooked at the point it exits the structure and diverted to the ground with an elbow. A splash diverter would be placed under the elbow.
Jan 09, 2018 | Washing Machines
Model Number: UACC-036JAS The unit works fine. The problem is it doesn't shut down after the specified temperature has been reached. The furnace blower shuts down, but the ac unit keeps on running....
Hello, usually a stuck contactor coil will cause this on the outside unit. When the outdoor unit runs continously and the indoor blower does not run no heat is being absoebed by the evaporator coil and thus the line freezes. Replaceing the contactor will fix the problem.
Aug 30, 2011 | Ruud Heating & Cooling
Central air unit two part system, inside and outside. Freezes
If coils are clean and blower is working properly,
then you're probably low on freon.
Jun 09, 2009 | Goodman GMS90703BXA Heater
Icetube leaking water inside freezer and outside back of freezer
Your refrigerator needs a new water valve and possibly some new water tubing. You can find the correct part by going to sears.com and entering the refrigerator's model number in the parts search field. When you have the valve, shut off the water to the refrigerator. If you're not sure how to do that, just shut off water to the entire house. Be sure to run the kitchen sink after you shut the water off to relieve any presure and double check that the water is completely shut off.
Be sure to unplug the refrigerator before you start this project...water and electricity aren't friends! Using a 1/4" nut driver or socket, remove the cardboard or metal cover off the back of the refrigerator. Follow the water line to the water valve, unscrew the nut going to the valve, and remove the water line. There are 2 screws holding the water valve to the refrigerator cabinet; remove the screws and gently pull the valve out. Unplug the electrical connectors and remove the water lines. Take the new valve, connect the water lines and electrical plugs, screw the valve back into place, attach the water line and turn the water back to to test for leaks.
Since the valve has been leaking inside your freezer it would be a great idea to clean out your freezer and let the water tube and lines thaw. Find a place for your frozen food, unplug the unit and let it sit overnight with the doors open. Don't forget to remove the ice bin, as these make quite the mess when the ice melts. Once it's thawed, plug it back in, make sure the water is on and not leaking and enjoy!
Jun 03, 2009 | Kenmore 57029 Side by Side Refrigerator
Can't pump gas into tank when the outside temp is below freezing
That is an issue I have never heard before, but I would pour some gas line antifreeze into your tank. It sounds like you have some trapped water in the tank.
Dec 05, 2008 | 2004 Hyundai Elantra
Water line in freezer for ice maker keeps freezing
I have had this happen to me before. What happens is the water fill valve
does not completely close and the tube will freeze shut as a small ammount of water will continuosly dribble into the tube when the valve shuts off causing the tube to freeze solid. I tried to clean the valve but that did not work so I replaced it and that ended the problem. A new valve is not expensive.
Oct 08, 2008 | Whirlpool ED2FHEXN Side by Side...
My AC unit keeps freezing up on the copper lines going into the house from the outside unit. It also freezes up on the inside lines and the air is not cooling my home down.
Operate your air conditioner with the fan in the on position. But first turn the fan on, turn the temp up or shut the cooling off. Your coil is more than likely frozen over. At night when outside temperature drops the refrigerant pressure and temperature in the system also drops. This action can cause icing of the cooling coil, with the fan in automatic everything shuts down at the end of a cooling cycle. Thus no air movement to melt ice on previous cooling cycle.
May 09, 2008 | Heating & Cooling
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
