2000 Toyota Camry Logo
A
Anonymous Posted on May 27, 2014
Why isn't my 2008 pontiac g6 power seat not raising and lowering
Pontiac g6 drivers seat not working properly
Lloyd Rosenthal
Level 2:
New Friend:
  • Expert 48 Answers
  • Posted on May 30, 2014
Lloyd Rosenthal
Expert
Level 2:
New Friend:
Answers
48
Questions
0
Helped
14796
Points
134
First verify everything else in car is working electrically speaking, especially other power seats and cigarette lighter / power plug and power mirrors.
First check power seat fuse.
If all good check power seat switch for a good 12 vt positve AND a good ground at the switch using an Ohm meter.
NEVER USE A TEST LIGHT IN YOUR VEHICLE AS YOU WILL HAVE A GOOD CHANCE OF BLOWING UP AN AIRBAG. And they will cost you plenty of money to replace.
If you have power to the seat switch and if everything is working except seat motors unbolt the seat and check to see if the connectors from vehicle to the seat are tight and have not come unplugged. While you are there also check power at the seat motor and work backwards to power source.
Check power seat module, visually for water/rust on casing.
If this vehicle has had a water leak that ended up under seat the module could be fried.
Hope this has helped, most likely it it a switch gone bad.
Good Luck!
Lloyd ......
Owner "Lloyd - Can"
12 vt Electronics Specialist.
Sealy, Texas
(832) 914-0245
If you need further help, reach me via phone at https://www.6ya.com/expert/lloyd_4256582adacd68ee
mike n
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on May 28, 2014
mike n
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
5510
Points
33
Start by checking fuse that supplies power to seats
1 Related Answer
Anonymous
  • 11 Answers
  • Posted on Aug 04, 2008
SOURCE: Raising the driver's Seat
I don't believe there is an adjustment for height
Last year at times my roof would stop part way through when it came to raising it or lowering it. Now it doesn't work at all. What do you think is the problem?
check to see if you have power at the switch... that model has all the little flaps right? they are known for all kinds of problems :-(
4helpful
2answers
Was there a recall on 2008 pontiac g6 for transmission problems
Yes there was. Here is the exact recall and claim number. Also is a phone number you can call for further assistance.
2008 Pontiac G6 Power Train Recall 12V460000 NHTSA: Action Number: N/A Service Bulletin Number: 12V460000
  • Report Date:
    Sep 18, 2012
  • Component:
    Power Train
  • Potential Units Affected:
    426240
  • Manufacturer:
    General Motors Llc
Summary: General motors (gm) is recalling certain model year 2007-2010 saturn aura and model year 2008-2010 chevrolet malibu and pontiac g6 vehicles, equipped with a 4-speed automatic transmission. On these vehicles, the tabs on the transmission shift cable end may fracture and separate.
Consequence: If the tabs were to fracture and separate, the shift lever and the actual position of the transmission gear may not match. The driver would be able to move the shifter to 'park' and remove the ignition key, but the transmission gear may not be in 'park. ' the vehicle may not be able to be restarted and the vehicle could roll away after the driver has exited the vehicle, resulting in a possible crash without prior warning.
Remedy: Gm will notify owners, and dealers will install a retainer over the cable end or replace the shift cable as necessary. This service will be performed free of charge. The recall is expected to begin on, or about, november 12, 2012. Owners may contact general motors at 1-800-521-7300.
Notes: General motors safety recall number 12106. Customers may contact the national highway traffic safety administration's vehicle safety hotline at 1-888-327-4236 (tty: 1-800-424-9153);
Why does our G6 loses power when we try to excelerate
Have you changed the fuel filter lately? The car will loose power if it isn't getting enough gas.
Front part of driver seat not raising or lowering
it is probably the motor that works the front only fix is to replace whole seat track.
9helpful
2008 Pontiac G6 Convertible retractable top won't work
2007 Pontiac G6 retractable top engine swithed off while raising, top continued to close in compartment right side upper forward pad looking thing popped and the compartment would not close, however the top will raise and go back in place, cannot leave top in compartment since the trunk lid will not close over the stored top..........
Lower steering wheel tilt in 2006 G6 GTP
you will not alter the steering angle more that what you have
however you can raise the seat
get a piece of RHS x 1/8" thick ( comes is dimension 1x1", 2x2", 2x1" and 3x1") and by drilling new bolt holes for where the seat runners are , you can raise your seat up to 3"
Any body with mechanical experience can do it for you or get an engineering shop to make the bits for you
2helpful
How to remove door panel 2008 pontiac g6
2008 g6 sedan i want to remove drivers door panel?Curt.
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
