Question about Sport & Outdoor - Others
Need a wiring diagram for 2004 Kawasaki 550 Mule
I have a 2004 Kawasaki 550 mule. I replaced the battery and there is a white wire with an inline fuse on the positive side of the battery that keeps popping. I need a wiring diagram.
  • 272 Answers
SOURCE: kawasaki mule heat light staying on
Replace the impeller in your water pump. It's an easy job and needs to be done every 2 or 3 years depending on use. Why they put a rubber impeller in these I do not know. Your local Kawasaki dealer will be able to help you with the part.
Posted on May 23, 2009
  • 850 Answers
SOURCE: I have a mule 550 that isnt charging the battery,
use a volt meter to test the charge rate
Posted on Jul 20, 2009
SOURCE: i need part no for engine assy. Kawasaki Mule
back fire through carb when you let off gas have to run with choke on
Posted on Aug 06, 2009
SOURCE: where can i download a wiring diagram for a 2009
You have a newer bike which should make it easier to get the Haynes Owners Manual.
Have you tried a bittorrent like btjunkie.com, mininova.com etc.
And use Utorrent (rated one of the best) similar to Kazaa, and napster and try searching there.
Thats where I found my manual.
-jay
Posted on Sep 09, 2009
wayneman01
  • 301 Answers
SOURCE: Kawasaki Mule 500 KAF 300 starter will not work below 60 degrees.
Using a lighter viscosity engine oil can make all the difference. Try something on the order of a 5W-30 for ambient temperatures of 60F or below. Of course, it could also be that your starter solenoid is in the early stages of failure. You can easily check it by using a large screwdriver to bridge the two large cable connections on the top of the solenoid. If the starter spins when you do this, then the solenoid is bad.
Posted on Dec 07, 2009
Can anyone tell me the location of the main fuse on a 1990 Kawasaki Vulcan 88 or if there are any inline fuses hidden somewhere on the positive battery cable
Hi, Anonymous if you really want to know just click on the links below try looking under your seat on the left- hand side sorry you can't find the first and best tool you ever bought for your Yamaha despair, not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Fuse Box Location
Kawasaki Vulcan 88 main fuse location Google Search
2004 Kawasaki Vulcan 500 LTD Main fuse 30 amp
http://www2.vulcanrider.se/DL/KawasakiVN1500_87-99ServiceManual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 30, 2016 | kawasaki Motorcycles
I have a Kawasaki 550 mule that won't hold a charge
Have you disconnected the battery and tried charging it to see if it would hold a charge disconnected? If not, the battery is probably bad. If it will hold a charge, then connect the battery ground cable, then touch the positive cable to the positive battery post and watch for a spark (make sure the key is turned off). If there's a spark, then something is pulling your batter down when the bike isn't running. Now if you have an electronic speedometer, dash gauges, etc., those will draw in order to maintain memory. Disconnect the wires to them then try again.
There's only so much I can tell you this way. I work on electrical systems often, and it can be a real process.
Nov 25, 2014 | ATVs
Replace drive belt 550 mule kawasaki
You will need a special tool from Kawasaki for the clutch tool removal to remove the belt and to install the new belt. Stop by your local dealer for the tool and they can explain the pretty simple way to remove the side panel and use of the tool. the tool runs about 76.00 Hope this helps you out some.
Sep 01, 2014 | ATVs
Where is spark plug located on 550 kawasaki mule
on engine head it will looks like cermic...you want to pull the socket first...
Feb 08, 2014 | All Years Kawasaki Kaf300 Mule 500 520 550...
My Kawasaki mule 550 clicks and the starter wont turn over. it has a new battery and selonoid.
It could be a relay clicking. Check with the parts department to find out if it `has one.
Oct 13, 2013 | All Years Kawasaki Kaf300 Mule 500 520 550...
Main fuse blows when ignition key turned...HELP 1980 Kawasaki kz550 A1
Sounds like a hard short between the main fuse and auxiliary fuses. disconnect the positive battery terminal and measure it with an ohm meter (red probe on positive battery lead, black probe on frame)
Jul 21, 2009 | 1981 kawasaki Z 550 F
Sport & Outdoor - Others Logo
397 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
