Question about Caterpillar Backhoe Tractor
The exstention on my cat is loose, I can;t pull
The exstention on my cat is loose, I can;t pull it back in,There is no oil leak, what could caused it?
  • 64 Answers
Sounds like the ram that pushes out and retracts the extension has come apart inside. You are going to have to open it up for inspection.
Posted on Jun 24, 2009
Nissan online mechanic
code p 0432 is main cat converter bank 2 --efficiency below threshold ===causes -- cat converter---wiring heated oxygen sensor (HO2S ) in the bank 2 manifold before the cat converter
ave a compression test done to determine inlet valve seat insert loose
if you have a problem with it there should be a bit of a miss, or it should change with rpm
could be a cam lobe failing and the noise should change with rpm
Aug 07, 2017 | 2003 Nissan Maxima
Does any one know normal voltage readings for a 2003 chevy cavalier
Trouble Code: P0420
Catalyst System Low Efficiency
Possible Causes:
Air leaks at the exhaust manifold or in the exhaust pipesBase engine problems (i.e., high engine oil or coolant usage)Catalytic converter is damaged, contaminated or has failedContinuous engine misfire conditions, or weak or low coil outputFront HO2S or rear HO2S is contaminated with fuel or moistureRear HO2S is loose in the mounting hole (check it for a leak)Front HO2S older (aged) than the rear HO2S (HO2S-12 is lazy)
Dec 05, 2012 | Chevrolet Cavalier Cars & Trucks
I have an everlast folding treadmill and the machine starts fine but then it speeds up and and stops and the display say E1. I tried adjusting the belt but to no avail. Please help. Thank you.
if your everlast speeds up all of a sudden it is your speed controller and this is useally caused by you not lubricating under the walking belt, a dry belt will cause friction which causes the motor to labor harder and then over time your motor will over heat and cause speed problems,
or buy pluging your power cord directly into your out let the surges with cause your controlle board to fail over time u must plug the power cord into a 15amp surge protector with min 500 jouls and 1 plug at all times,
you should always have a anti static mat under the whole treadmill if your treadmill is on carpet static can de magnatize your motor, and static will be pulled into the treadmill
so when u step on your treadmill u become charged with static so every time you touch your computer console you are causing little charges to your console which over time cause the computer to male fuction,
also watch out for useing cheap exstention cords they will cause major damage to your treadmills electronics and motor they can not carry the proper voltage from the outlet into your treadmill so this will daMAGE YOUR TREADMILL ALWAYS USE A HEAVEY OUT DOOR THICK EXSTENTION CORD make sure it is 15 amps and a heavy gage and no longer the 10-15ft
the longer the exstention cord the more power you loose
Tim Ramsay
Lubeatread Inc
lubeatread@sympatico.ca
16 feb 2011
this goes with all treadmills
Jan 27, 2011 | Sport & Outdoor - Others
2000 E-350 V-10. P0174 with exhaust fix
Before I even finished reading this i knew you had a clogged cat. If you have fixed everything you mentioned i would lean towards a clogged cat. This is a large reason this code pops up.
To check this you could pull that cat out and drive around and see if the code comes back, make sure to stay away from the police though.
Subikid90
Mar 03, 2010 | 2000 Ford Econoline
My 2000 ford expedition would run and then start to jump and then shuts off....what can be causing this...?!
sounds like a coil pack going back ....they work ok while cold but once it gets hot it stops putting spark out causing car or truck to stumble and stall and not start back up till it cools back down. Or it could be a bad fuel injector either clogged which would cause a lean cond. that would also make engine temp. higher then normal that over time will burn out a cat. converter which will choke the engine also or leaking tip which would make for poor gas mileage -rich, gas mixture and also cause a soot-black looking exhaust ,to check if cat. is back you can simply unhook exhaust before it reaches the cat and see if it will stay running then if it does then the cat is melted down -bad and need replaced if not something else like stated above is your problem.
Dec 01, 2009 | 2001 Ford Expedition
I have a Whirlpool LSN1000LW0 Washer. How do I separate the agitator to replace the dogs?
remove the fabric softner assemble.if ther is a plastic cover remove it remove 1/2 bolt and reach down under agitator up. put agitator on the floor.put a foot on both side's of the bottom of the agitator.place a hand on both side's of top part of agitator and pull up.turn top agitator upside down and the dog's should come out along with the holder.replace the dog's.to put holder and dog's back in top agitatoruse your 1/2 socket and exstention.place the 1/2 bolt in socket and place holder and dog's on bolt.turn top agitator upside down and feed holder and dog's up in top agitator.holding socket and exstention in top agitator,rotate top agitator down holding dog's and holder in with socket and exstention.place top agitator over bottom agitator and line up the two aliment ear's on bottom agitator and use exstention to push top agitator down on bottom agitator.place agitator back on transmition shaft and replace 1/2 bolt.replace plastic cover and fabric softner assembly.
Nov 15, 2009 | Washing Machines
Oil leak driver side towards the back of motor what should i check out
Check the rear main seal, very common cause of oil leaks in the Camaro.
Nov 02, 2009 | 1995 Chevrolet Camaro
PO420 DTC code on 02 Nissan 2.5 Altima
i found out the cat bein broken up and suckin into the fudgin pinstons....good luck everyone
Apr 14, 2009 | 2002 Nissan Altima
Car Oil Leak
bmw has a problem in that the exhaust manifold bolts are through to the rocker cover oil reservoir and the stud threads allow oil past the threads , past the washer and onto the hot manifold
the fix is to remove the studs and use a thread sealer in the threads to seal off the threads
use a quality thread sealer ( suggest loctite red gasket sealer as it is heat resistant)
there is nothing wrong other than a lack of bmw knowledge
discuss it with the bmw shop to see what they say
Apr 03, 2017 | 1998 BMW 7 Series
Leaking oil under car
check and see if your oil filter is tight, if being loose wasnt the prob. remove it and see if whoever replaced it before accidently left the old gasket in between the new one and block. as far as the antifreeze goes sounds like a gead gasket
Dec 28, 2008 | 1983 Chevrolet Caprice
Caterpillar Backhoe Tractor Logo
134 people viewed this question
Top Caterpillar Toys Experts
fordexpert
DROPNDEAL
DROPNDEAL
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
