Question about Toshiba SDV393 DVD Player/VCR
I have a toshiba SDV 393, combo DVD/VCR. It has worked wonderfully for 3 years but just yesterday the DVD stopped working. I put in a DVD but it says "no disc". I tried several different commercial dvd's that used to work, but now they don't. What can I do?
  • totalfreedom Jun 25, 2009
    Are there any other ways I can take care of this at home? What might it cost to get it cleaned by a repair service?
  • totalfreedom Jun 26, 2009
    I bought the laser cleaner. But since the dVD player won't read the disc, the cleaner couldn't work. Is there a way to force it to read the cleaner?
  • 250 Answers
Many DVD players are not able to properly detect and playback recordable DVDs. If trying to play a DVD disc that is a DVD-R/RW or DVD+R/RW, you must check if the check is one of that kind.
Insert the disc and listen closely by placing your ear to close to the drawer of the DVD player. After the disc tray has closed, you should be able to hear the disc spinning. If you hear no such sound, it is common that the disc is not spinning up, which is why you would recieve a "No Disc" message when a disc has been inserted. In some cases, it can be difficult to hear the disc spinning, so you could remove the lid of the player to actually see if the disc spins.
After a DVD player has been used for awhile, another common problem is that the laser in the DVD player becomes misaligned, inhibiting its ability to read DVDs. In many cases, DVD players with this problem will still be able to read a CD. I'd try a cleaning disc first, since the only way to fix this problem is to bring the unit to a service center for repair.
i dont think you can fix it by yourself.
There are other possibilities for the players failure, such as a defective laser motor (the motor that moves the laser), bad spindle motor (the motor that spins the disc), as will as other various circuit falures that could be the cause.
or try a few of this
*Turn the device off and unplug it. Take off the outer casing by removing the three or four screws and lifting the top piece off. This will allow you to see if anything is simply stuck or jammed. If this is the case, a simple nudge back to the correct position will fix the problem.
*Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
most probably the spindle motor might be the case.
if nothing of this work,take it to an authorised techinician
-ray
Posted on Jun 25, 2009
  • Rajath Johnny
    Rajath Johnny Jun 26, 2009
    after doing so much i think a better idea would be taking it to service center.
    the solutions i can mention from one part of the world is limited you know.
    it takes examination to fix those problems.i just told you some basic checks that you must do.
    -ray
This usually occurs with overtime dust build-up on the laser unit. You will need to get the laser unit cleaned at a service centre or local repair store. In most cases, cleaning the laser unit does fix this common problem.
Best regards
nLinked
Posted on Jun 24, 2009
  • Anonymous Jun 25, 2009
    Yes, but results might not be accurate. There are laser cleaning DVDs, specially designed to make contact with the laser head and clean it. Whether this will work or not depends on whether the laser head is close enough to the DVD cleaner.
    Here's an example, but you should be able to get one online in your country or in a good computer store.
    They are quite inexpensive and should be effective enough to solve the problem from home.
    A repair service may not cost so much either as it would be a case of opening the unit and cleaning it out. Doing this at home might have risk of damaging the sensitive laser and reading components.
    Best of luck
    nLinked
Universal Remote Codes
Try, 0045, 0043, 0845 or 0154, 0156, 0060
Feb 03, 2009 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
No cable. converter box needed for Toshiba MW20FN1?
www.radioshack.com , get a digital stream 1500150, I sell them, they work wonderful. I personally have been selling them for over a year now, and I've only ever had to exchange one once (and we do thousands :-) )
Jan 02, 2009 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
Toshiba TV Combo MW24FP1, DVD player doesn't work on some discs
This is a common problem for all combo units. The high voltage of the TV section attracts large amounts of particulate dust from the air and often it collects inside the DVD unit. The best way to deal with this is to clean the lens of the DVD unit u sing a cotton swab and alcohol. The store bought "cleaners" MAY work, but that is rare. These cleaners are nothing but small brushes embedded into a disc. They attempt to brush off hte dust. This rarely works. Open up the unit (if you feel comfortabel in doing so) to access the DVD section. Remove the top cover and carefully clean the lens. That should resolve the problem.
Dan
May 21, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
20 INCH TOSHIBA DVD VCR COMBO, DVD KEEPS READING BUT NEVER DOES
I was having the same issue and I've been to several video stores to rent DVDs and 2 out of 3 rentals have the same affect where it is just 'reading' but even worse, it would play fine and then freeze up during the movie- very frustrating. Now, after 3 years of owning it, it died today. They just don't make them the way they used to :(
Apr 01, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
DVD problem with Toshiba TV/VCR/DVD Model MW24FP1
I've only had mine for 3 years- DVD didn't recognize 2 out of 3 discs or would cut out- started about a year ago. Today the whole picture went out. Just don't make them like they used to
Mar 04, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
DVD Picture jumps and freezes
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 07, 2017 | Toshiba SDV-592 DVD Player / VCR Combo
Toshiba SDV393 DVD Player/VCR Logo
80 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
