Question about General Electric DHDSR46GGWW Gas Dryer
No heat This is 2-month old GE dryer. It ran but didn't have heat.
  • 64 Answers
The heating coil is gone (burnt out). Remove the back panel and take out the curly wire that circles around and try to find a replacement. It's a cheap repair especially when you do it yourself.
Posted on Jun 25, 2009
Hi, I'm having a problem with my new dryer. We got this dryer about a year ago and for some reason in the last couple months, almost every 2 weeks the fuze blows. The dryer turns on but it doesn't...
Makecertain that your wiring is not exposed to anything. Be sure to turn the power off to the dryerand check the outlet. Also check to seeif your dryer cord is connected to the dryer right. Usually the outer prongs on the dryer are thehot and in the inner one is the ground.
May 11, 2011 | Dryers
Dryer turns on, drum moves, but seems to be no heat even though the setting is on for heated dry not air dry. Only 2 months old.
This could be due to a bad heating element or bad controller. I would suggest that if it's only two months old that you contact the store you purchased it from and get a replacement.
Aug 05, 2010 | General Electric DCVH680EJWW Dryer
I have a GE Dryer Profile Harmony. It is several years old. The dryer is not blowing air out the back ventilation so not drying. It is making a quiet odd sound as well. When I troubleshooted I shut the...
You vent is plugged very bad. Disconnect the vent tubing and thoroughly clean it out. It will heat and dry like new afterwards guaranteed. These dryers have sensors that shut the burner off if the exhaust is not venting properly. Once its cleared out it will run perfectly again
Apr 09, 2010 | GE Profile Harmony DPGT750EC Electric...
GE profile harmony dryer electric won't heat after first load
Did you end up replacing this thermistor? If so did that solve the problem? We are having the same issue and I don't want to waste time and $$.
Dec 22, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Electric Dryer Heats up but does not automatically turn off
Change the sensor in the drum. Theres a sensor that tells it if there is moister in the enclosure.
Feb 12, 2009 | GE DBXR463GB Gas Dryer
My GE Driver will not heat
Check the circuit breaker or fuse box it takes two one to run one to heat. Then check thermostats Hi limit may be burnt if it overheated If the venting had been blocked. Hope that helps
Dec 26, 2008 | GE DBSR453EBWW Electric Dryer
HOW TO FIX A NO HEAT ON A GE ELECTRIC DRYER OVER 10 YEAR OLD
Either one of 2 ways to get to the thermostat on a GE dryer.....
depending on your model, you will have an access point on the back of the dryer to get to the heating element which has attached to it, the thermostat.
If there isn't an access point on the rear of the unit, open the front door of the dryer and remove the 2 screws in the top of the door opening. Using a small prybar, slightly apply pressure prying up the lid. On the inside of the face of the dryer in the corners will be 2 more screws, remove those and pull the face of the dryer outwards to you to about a 45 degree angle. From there, you will be able to lift off the face. Be cautious to unplug the wires for the door switch before pulling the face all the way out. There isn't much to a 10 yr old dryer, just take your time, study the parts and put it back just as you took it apart. For the replacement thermostat or heating element look at
www.marcone.com
www.partstoday.com
Good luck and let me know if there is any more trouble I can help with.
Mar 17, 2008 | GE DCSR483EA Electric Dryer
Dryer will not start. Ge DX4500EAoWW
You may have a bad timer: Also, there may be a separate thermal fuse for the motor, usually an inch long white plastic one attached to the blower housing.
Apr 23, 2007 | GE DBSR453EBWW Electric Dryer
General Electric DHDSR46GGWW Gas Dryer Logo
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Tyler T
Level 1 Expert
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
