Question about Digital Cameras
Internal stoage loss. Protax dc 1200 digital camera
On 3,5 or 12 megapixels, you take 3 photo's and camera's storage media indicator flashes and it won't take anymore photo's.Is it worth trying to do anything with it's 5 weeks old.
  • 363 Answers
Re: internal stoage loss. Protax dc 1200 digital camera
Buy a 2GB SD card. This is the maximum memory size the camera can take.
Posted on Nov 06, 2007
    Brigadier General:
  • 6,966 Answers
It is possible that the camera's internal storage media has a limited capacity ( I was made to understand only 32mb). Perhaps what you need to do is use an add-on SC Card to the memory with a bigger capacity, say 1Gb.
It is also possible that you simply need to re-format the memory card/storage.
In some models/versions, settings such as in SHQ (super high quality) while in 12 megapixels or high image resolution (4036 X 3026) or such a combination would result in an image size that is quite big and therefore would occupy a big portion of the memory.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
0 characters
3 Points
Can you download pics from a olympus tg810 onto a xbox 360?
Yes you can the easiest way is to plug a usb flash drive "at least 1GB" into your xbox 360 find it on settings tab >Storage... format it if it isn't already when it is formated remove from xbox 360 plug both usb flash drive and camera into pc/laptop then copy photos from camera onto usb flash drive. after your finished remove usb flash drive put it back into xbox 360 and you can move them to or from any formatted storage device including you hard drive
Jan 02, 2014 | Olympus Refurbished Tough Tg-810...
How to download a video from samsung L200 10.2 megapixel to my computer?
If your videos and photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Aug 23, 2012 | Samsung Digital Cameras
I need a manual for vivtiar 3188
Product MPN MPN: 80640 Key Features Features: Red-eye Correction Camera Type: Compact Resolution: 3.1 Megapixel LCD Screen Size: 1.5 in. Optical Zoom: Without Optical Zoom Digital Zoom: 4x Lens Interchangeable Lens: Not Interchangeable Lenses Optical Zoom: Without Optical Zoom Focus Type: Autofocus Macro Focus Range: 7.87 - 11.81 in. (w) Focal Length: 6.1 - 18.3 mm Image Quality Image Sensor Type: CMOS Camera Resolution: 3.1 Megapixel Image Resolutions: 2560 x 1920 · 2048 x 1536 · 1600 x 1200 Video Video Resolutions: 640 x 480 (VGA) Video Speed: 15 fps Video Format: AVI Exposure Control Aperture Range: f2.8/f4.8 (w/t) White Balance: Auto · Daylight / Sunny (Preset) · Cloudy (Preset) · Fluorescent (Preset) · Tungsten (Preset) Storage Memory Type: Built-in · SD Card Built-in Memory Size: 16 MB Compression Type: JPEG Flash Flash Type: Built-In Flash Functions: Flash Off · Auto Flash · Forced On Viewfinder / Display LCD Protected Position: Without LCD Protected Position Interfaces Interface Type: USB 1.1 Video Interface: Video Out Power Supply Battery Type: 2 x AAA Batteries Included Features Built-in Microphone: With Built-in Microphone System Requirements Operating System: Microsoft Windows 2000 · Microsoft Windows 98SE · Microsoft Windows ME · Microsoft Windows XP Dimensions Width: 3.5 in. Depth: 0.8 in. Height: 2.44 in. Miscellaneous Family Line: Vivitar ViviCam UPC: 19643806405 Product ID: 44609540 Return to top
Aug 30, 2011 | Digital Cameras
My camera the mercury cyberpix 2-210s only take 20 or so pictures and has a memory card of 8 mb and I don;t understand why.
Your Mercury Cyberpix S-210S has an internal memory of 16MB and can be expanded using an SD/MMC Card up to 512MB.Since the picture you capture using this 2 Megapixel camera has an approximate resolution of 1600*1200 and a size of approximately 400kB you can store only around 18 to 20 photos in an 8MB Memory Card.So if you want to store more pictures you have to insert a Memory Card of bigger capacity.Remember the maximum Memory Card capacity supported on your camera is 512MB.Thanks for choosing Fixya.
Jun 19, 2011 | Kobian Mercury 3.1 Deluxe Classic Digital...
I own a samsung ST60 digital camera, which was brought by my friend from France. The problem is that i cannot take photos and am receiving the message memory full. the photos also could not be deleted. ...
Sounds like your camera has some pictures on its internal memory and is preventing the memory card from working. With no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. Then, your memory card should work.
Dec 14, 2010 | Samsung Digital Cameras
Message "internal memory is full" comes up on my DX6340 camera. I know that all photos were deleted. What now?
Check this You have to choose "Image storage" to "Internal" from the settings menu (Read the Manual). And there will be images there, delete them and then make the storage back to "Auto".
The camera writes quickly to internal memory, so even after you've filled the buffer (it holds four 3.1-megapixel shots), you can snap one more picture in just a few seconds.
If i was helpful, kindly do Rate!
Jul 26, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
I have a brand new Finepix S8100fd camera and the majority of the photos are speckled no matter what setting I use. However the super macro setting rocks and pictures are super clear! My Fuji 7.1 mega
Common issue with the A8100fd. The most likely problem you are having is not enough light. Try shooting in bright sunlight to test the "graininess". Make sure you use the flash anytime the light is not bright. Even though the camera will shoot in low light (without flash), because it defaults to a high ISO setting, which (just like film) accentuates the "grain", or more properly termed in digital photography, "noise". Set the camera for a low ISO setting and use the flash whenever you see the "red hand" symbol on the screen.
Apr 22, 2009 | Fuji FinePix S1000FD Digital Camera
Internal memory is full
Hi There Kyle,
At the moment I have my friend's Kodak camera M1033 with me, because it has some minor problems. So Your camera model is quite the same as this one.
So coming to your problem, go to the normal Photo mode and press the Menu button.
There if you search then you'll find an option 'Image Storage'. Did u find it yet? Good. Now according to your problem, it must have been at 'Internal Memory', so set it to 'Auto' and you're good to go!
Feb 16, 2009 | Kodak EasyShare M1033 - black Digital...
Vupoint underwater camera -fuzzy pictures
My girlfirend just got me this camera and I've noticed that it takes fine pictures when the lighting is good. Under low light (i.e. underwater or in the dark) it's not so hot. I don't think there is a fix for that.
Feb 13, 2008 | Digital Cameras
Digital Cameras Logo
62 people viewed this question
Top Digital Cameras Experts
Are you a Digital Camera Expert? Answer questions, earn points and help others
