Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Programming LX18H for TRUE FILL AND DRAIN
We manually add detergent to our HOBART LX-18H and need to reprogram the unit for TRUE FILL & DRAIN. The operator's manual does not provide any clue as to how to program this option. Can anyone shed some guidance please?
Thanks.
  • 3 more comments
  • tcweeks Sep 12, 2009
    Rob-OES,
    Please send me instructions. We're a non-profit organization and my budget will not allow me to pay HOBART several hundred dollars for a service call.
    My email is
    tcweeks at embarqmail dot com
    change the "at" and "dot" as appropriate.
    Thanks!
    Terry
    Rob-OES,
    My email is
    Thanks!
    Terry
  • Stuart Mettler
    Stuart Mettler Mar 18, 2014
    Please send me instructions. I have an Hobart LX18 in a bed & breakfast and need to reprogram it to a True Fill and Dump.
  • stephane godin
    stephane godin Apr 01, 2014
    Could you post the instructions to reprogram for true fill and dump? Thanks!
  • stephane godin
    for lx18h Could you send me the instructions to reprogram for true fill and dump godin.serviceplus@telvic.net
    Problem Solver:
  • 6 Answers
The LX18 series was a compromise machine, the lack of a sump heater causes numerous rinse temperature problems due to it's increased water use (over the sump-heater equipped, fresh water rinse LX30 series).
The LX18H can be reprogrammed for true fill and dump operation. If you still need to do this, please let me know via e-mail or post a reply, otherwise a won't post the long answer!
(I worked for Hobart as a service tech. from 1994 until 1999, and have been independent since then)
Posted on Sep 12, 2009
  • 4 more comments
  • jff0071 Aug 30, 2010
  • lefaudio Aug 21, 2011
    Rob-OES, if your still at this would you please email me instructions to program my church's LX18 to true fill & dump? Thanks - lefaudiovideo@gmail.com
  • babydean1 Nov 06, 2014
    We have a lx-18 at The Salvation Army that we are adding a pump kit too. I would like info t0 reprogram it. babydean1@hotmail.com. Thanks
    We have an LX-18 at The Salvation Army that we are adding chemical pumps too. Can you tell me how to reprogram it. babydean1#hotmail.com Thanks
    sorry babydean1@hotmail.comnot #
  • Scott Bicknell
    Scott Bicknell Nov 08, 2015
    Hi Rob, would you send me the directions to program my lx18h for true fill and dump please? .... sbicknell@wma.us
    New Friend:
I am interested in finding out how to reprogram lx18h for TRUE FILL AND DRAIN. Blubull@hotmail.com
Thanks!
Posted on Feb 11, 2016
Hobart lx18h Booster does not heat up. machine powers up and will wash thouugh all cycles but the booster does not heat up water.
There are one or two hi-limit relays on the booster. One is on the front and if there is a second one, it is on the right hand side as you face the front of the unit. They are both manully have to be reset if tripped. Check them and also the booster's contacter
Oct 03, 2016 | Hobart Dishwashers
Hobart dish machine. We were told by Ecolab tech that we need to rinse off all presoak, soaps and sanitizers before passing through the maching as they cause foaming/excess suds. I do not find that info...
That's true. excess of foam can cause poor wash pressure and poor final rinse.
Operation manual , pag.24. (F17791Rv02-06.pdf)
DO NOT exceed chemical manufacturer's recommended concentrations for detergent, sanitizer, rinse aid or lime scale remover.
Mar 13, 2015 | Hobart Dishwashers
Looking for parts numbers for a heater element and thermostat for a lx18h
If you have your manual. It should be in it. If not, (your dishwasher brand).com and you should be able to get it there.
Jan 06, 2010 | Hobart Dishwashers
How much delime agent should I use to clean the system in a Hobart LXI-H?
Depending on how often you delime the dishwasher use 2 cups.The delime light will come on after 1000 cycles set from factory default.If the delime icon is lit and beeps,turn the unit off.
Push and hold the delime/wash button and on button for 5 seconds and youll be in delime mode.
The unit will fill and heat up and display "add delime".Open the door add the delime and press the wash button.The dishwasher will run for 5 minutes then rinse and drain twice then shut off.When you turn it back on the delime icon will be gone.I'm a hobart tech and repair these dishwasher often,any questions let me know and please rate me,Thanks.
Nov 24, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Howdy, We have a Hobart H600 mixer and it looks like it needs oil. Where do I add the oil and what type should be used? Wesley McMenamins Pubs & Breweries
take off top cover, where the front screw on top cover threaded into is the fill plug for the trans.drain oil replace drain plug , also ck. sight glass if dark or cloudy replace,@this time.trans. oil can be bought @ any hobartoffice the part# for the trans. oil is102973-66 that will come in a 128 oz bottle you will not need all of it. pour a little @ a time till oil hits line on sight glass. please vote thanks
Oct 16, 2009 | Hobart H600 Stand Mixer
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
How do you delime the hobart LXi. Where can I find the manual online?
With the unit off----hold the wash/delime button in and hold the on button in for 5 seconds.the dishwasher will fill and the delime icon will be on,then it will prompt you to add delime,add the delime and hit the wash button.It will run for 5 minutes,fill up twice and drain twice then turns off.
Feb 26, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LXiH
Hobart doesnt release service manuals but you can get an operation/installation manual for free here http://www.hobartservice.com/Manuals/ Im a service tech for hobart so if you have any questions let me know.
Dec 03, 2007 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
936 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
