Question about Garden
I need to replace the assembly starter cup on my husqvarna 125l trimmer. How do I remove the starter coupler? That is keep the crankshaft from turning when I try to loosen?
    Sergeant:
  • 199 Answers
How do you install replacement pull starter assembly on Husqvarna 125L?
should be 4 Torx bit screws holding it on. T-25 or 27 i can't remember
Oct 05, 2014 | Husqvarna Garden
I have a Husqvarna 125L weedeater, New Fuel, has spark but will not start. Pulling the starter rope makes me feel that either I have a compression problem or a clutch problem it is just to easy to pull. I...
Hi there. Firstly remove the end with the starter cord and make sure the fly wheel is opening when you pull the cord. If not lubricate it until it frees.If it is working then it could be just the carb gaskets need replacing or the worst case is that the piston is broke and may need sorting.
Oct 05, 2013 | Husqvarna Forest & Garden 125l 18" Gas...
I have a husqvarna 125L trimmer. I need to get the starter cup off. It's held by a coupling nut. How do I lock the shaft and which way do you turn the nut (left or right hand thread)?
Its a clockwise thread to undo the bolt,you need to put a small bar in the gear head tho to stop it turning. You may have the type of gear head that you hold the top of the shaft with a spanner
May 03, 2011 | Husqvarna Garden
I have having problem with my Hysqvaran 125L with the pull cord. When i pulls cord, it not catching the trans and it sound like the spring is not catching?
Hi and welcome to FixYa, I am Kelly.
It sounds like the starter cup has failed / broken. See this link: (Page 3 item 14.)
http://weborder.husqvarna.com/order_static/doc/HIPL/HIPL2008/HIPL2008_5450143-15.pdf
However... the pawls on the starter pulley (item 28 above) may have broken.
There is a whole kit for repairing the starter recoil: PN 545180844
That can be found here:
http://cgi.ebay.com/HUSQVARNA-RECOIL-STARTER-KIT-124L-125L-128L-545180844-/150485511147
Your need to remove the starter recoil assy and check for damage. It will be obvious. Just remove the mounting screws and lift it off. It is not difficult. Use the first link page 3 to identify the parts you may need once you do the visual inspection with the recoil removed.
Thanks for choosing FixYa,
Kelly
Apr 23, 2011 | Husqvarna 28cc Gas Line Trimmer
Hello I have a Husquvarna 125L trimmer manufactured in 2007. A part has failed in the starter cup assembly because when I try to crank the trimmer it does not engage and simply turns free. I have the...
Have had same problem. This is a very old post so this is for those who have this problem. It is part 15 from the link given up there. WARNING I AM NOT A MECHANIC OR WELL VERSED!!What happens when you pull the handle is two starter couplings(plastic) engage the shaft that engages the engine. When it starts these fall free and allow the engine to spin freely. When they break the engine isn't harmed. You need a star head screw driver and NOT a phillips. Just he two on either side of the starter cup. Don't think you need to take off all 8 or more screws. Just the two. Pull out the other coupling. They just pop in. Buy 2 new ones. The other one is probably compromised anyways. Husqvarna 530059800
Coupling-Starter. Not a very involved process at all. Two screws. Pull off cup. pull out white plastic couplings. Put in new ones. Put the cup and screws back on.
Jul 20, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
I HAVE A 125L HUSQVARNA TRIMMER. THE RECOIL STARTER WAS FINE, THEN STARTED MAKING A RATCHETING SOUND SOME OF THE TIME BUT WOULD NOT PULL THE ENGINE THROUGH AND START IT OTHER TIMES, NOW IT MAKES THE...
Actually, there are two solutions, did not see the two nubs on parts diagram either but I have done some extensive research and the nubs come with the cup assembly. One solution is to go to partstree.com and order part # 545102303 or part # 545180844. Both come with the white plastic nubs and springs. Also, what I did with mine if you are tech savy is cut off the stem that goes through the black cup, drill an 1/8th in hole through the bottom of the plastic nub and then assemble nub and spring and secure putting a screw through the hole in the bottom of the black cup, securing the nub. All you are doing is replacing the part of the nub that goes through the plastic cup with a screw. You are pre drilling the hole in the nub so you dont crack the nub with the screw. Make sure the screw is straight so you dont get too close to the edges or it will crack. This method takes crafty hands and good eyesight. If done correctly, they will never pop out again. Promise!
May 09, 2010 | Husqvarna 28cc Gas Line Trimmer
I have a husqvarna 125L gas trimmer and dies after about 5 to 10 min and keeps dying and won't idle, have to keep throttling up
Could be clogged gas cap. Take the cap off and see if you can blow air through it. If no air passes, the trimmer will become vapor locked and wont be able to get enough gas.
Jun 23, 2009 | Husqvarna Forest & Garden 125l 18" Gas...
Garden Logo
460 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
