Question about Epson Stylus Photo 1280 InkJet Printer
Put in a new ink carriage still says color ink is out.
How can I fix my ink problem?
It is possible the ink carriage and print head are very dirty and needs servicing.
Aug 25, 2014 | Brother LC51BK Print cartridge, Inkjet...
No ink output from Epson Stylus Color 777
I don't have an answer for you but I have the exact same problem.
I have an Epson Stylus Color 777 and I put in new cartridges (black and color) that I bought yesterday (03/05/10).
I pulled the tape off the cartridges and inserted them in their carriages. Everything works like usual except that no ink at all prints on the page. Comes out completely blank.
Nov 11, 2009 | Epson Stylus Color 777 InkJet Printer
Yellow light for ink missing is blinking all the time i put the two new black and color catridge
This is a typical cartridge problem.Try clean the contacts on the carriage unit using piece of cotton and some alcohol.If this not help open the printer cover and look when carriage unit stops.On the carriage unit have a yellow arrow.In the left sidе of printer, where the carriage stops have a two icons.If the arrow shows left icon change the color cartridge.If shows right icon change the black cartridge.If this not help there is a problem in carriage unit and your printer need repair.
Nov 05, 2009 | HP DeskJet 1280 InkJet Printer
I put in a new color cartridge...it will not print in color..what do I do?
If you confirm your ink cartridge is ok.
You need to change carriage unit.
Oct 28, 2009 | HP Deskjet 3845 InkJet Printer
Model Cannon MX310 - replaced ink cartridge, both black and color. Window states, check ink - black and color. Will not work. Replaced with new cartridges again. Still will not work
Is the carriage unit moving?If not the carriage motor is defective.If moving the problem is in the carriage unit or logic board assembly.
Oct 07, 2009 | Canon Office Equipment & Supplies
Put in new ink cartridges - when powered on, cartridges slam against end of printer and I get a carrier stall mesage - the slam also loosens the ink cartridges from their position.
Does the problem happen when there are no cartridges in the carriage? What happens if you manually pull the belt to move the carriage to the park position or a position it's not normally in when you turn the machine on when the problem happens. There should be some kind of encoder that lets the printer's computer know the position of the carriage at a given time. This may look like a plastic or metal ribbon. Try cleaning it with rubbing alcohol or window cleaner.
Sep 17, 2009 | Lexmark 83 Color Ink Cartridge (Twin Pack)...
I changed the ink cartridges and i can not get the
Do you mean you can't print text in black? You are correct to replace black ink. Turn off printer. Turn on printer, and immediately unplug power when carriage moving. So, carriage will stop not at parking position. Unplug usb. Move carriage freely bay hand.
Aug 12, 2009 | Epson Office Equipment & Supplies
I replaced both cartridges on my printer, but the color will not print. I cleaned the carriages but it still won't print in color Thank you for your assistance
you have a bad or defective cartridge,remove color cartridge,put a cup of water in the microwave and heat untill boiling point,put the tip of the cartridge in the hot water for 20 sec.(you should be able to see color ink flowing out of the cartridge) hold it tight in your hand and shake it hard like if you are trying to spray ink in the floor,put it back in the printer and run a test page...........if not color coming out after this process the you have to buy a new cartridge.....good luck.
Aug 03, 2009 | HP DeskJet 895cse InkJet Printer
Keeps telling me the following ink tank is not installed - color ink tank It is installed and i have replaced it with a new one
That printer has a little switch on the carriage assembly that is made when the ink is put in. It's a tiny switch easily broken, and you have to replace the carriage assembly if it's broken. Make sure you place the ink in properly, the right side goes in under the ledge and then press down the left side.
Jul 29, 2009 | Canon PIXMA iP90 Mobile Printer
Kodak easyshare 5300 printer
try try again..........
I had this problem;
Printhead replacement instructions are in the users guide.
THIS WORKED FOR ME --AND IF YOU CALL THE TECH SUPPORT # KODAK WILL SEND YOU A REPLACEMENT HEAD........
Power on printer, the printhead rides on a carriage that is connected to the ribbon cable. When the printhead is in the center position and movement is stopped REMOVE THE INK CARRIAGES. DO NOT TOUCH THE INK-PADS OR THE CONNECTION POINTS. You can just place the ink carriages on their side on a clean piece of paper.
......... To separate the printhead from the carriage press the release botton(above the bulls-eye sticker) in the top center of the printhead. You will hear a click and the top of the prinhead will pop forward about 1/4 of an inch. GENTLY lift from back (where you pressed the botton) to front and lift the printhead up and out of the printer.
---------U will see where the printhead and the carriage connect-------
It is best (very important) to not touch the shiny contact area
Now you are ready to install your new printhead.
BE CAREFUL BE GENTLE............Place the new printhead into the carriage and again at the center top back bulls-eye press back until you hear the click and the printhesd is secured in the carriage.......... replace the ink carriages.......
I would power off the printer and wait about 60 seconds then power on and run self test.
TO RUN SELF TEST
power on the printer and wait until the printhead is in the center position THEN press photo and copy buttons at the same time, you will hear the printhead carriage start to move and a test print page will print.
CHECK for print quailty; run all diag. from the help tab as needed.
REMEMBER; IF YOU THINK THE PLASTIC WILL CRACK U ARE PRESSING TOO HARD....... KEEP IT CLEAN, BE SAFE
Dec 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Epson Stylus Photo 1280 InkJet Printer Logo
32 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
