Question about GE GSS25LGM Side by Side Refrigerator
GSS25LGM freezer quits. I unplug, then replug, works fine then quits again
  • Michael Brennan Jun 25, 2009
    Kevin,
    There is no "clicking". The entire fridge sounds normal, fan operates, but I come home to a defrosted freeezer. Where are the replaceable parts that I might be able to change out.
    Mike
    Sergeant:
  • 193 Answers
It sounds like theres a power surge going through the power cord get it tested before it blows up.
Posted on Jun 25, 2009
    Genius:
  • 1,847 Answers
If compressor is clicking it will be the relay, If the compressor is cold not making any noise it sounds like the defrost timer stuck in defrost cycle..if it is a mecanical time advance it ..if compressor starts replace timer...some refridge defrost timers are built into control board so anly way to find out is replace board. Hope this helps...feel free to comment again if i can assist you further.
Thanks
kevin
Posted on Jun 24, 2009
Not cooling in fridge,fridge temperature in freezer
Self defrost mechanism has a problem. Check the defrost timer and defrost heater element for proper operation. Ice buildup is the culprit.
If you unplug and defrost overnight, replug, it will work fine till the ice builds up again.
Nov 26, 2013 | Refrigerators
When my refrigerator needed to be cleaned, underneath (I have cats and dogs) the refrigerator section would quit working and I would have to unplug and clean then replug and it would be fine until it...
check the start relay located on the compressor when this gets fur in it it tends to burn out much quicker then without pets. This is the plastic piece located on the compressor that turns the compressor on you would also need to pull the unit out and take off the back panel and clean around the compressor and start relay area this way as well if you have never done this there would be alot of build up if you have any further questions message me back and please remember to rank how this opinion has helepd it allows me to help others in similar situations p.s remove the start relay and shake it in your hand if you are hearing something jingling on the inside of the relay replace the relay Thanks Rick
Apr 04, 2011 | Whirlpool Refrigerators
Freezer is frosting, water pooling below in fridge
When in doubt call a professional, the ongoing defrost problem is not what should be happening. It is possible that the machine simply wasn't unplugged long enough but without pulling the back cover of the freezer off you aren't going to know that. You may need a timer or a defrost thermostat. If you do decide to diagnose on your own, pull the back cover out of the freezer and defrost, a hair dryer helps.
Jun 19, 2009 | Whirlpool GR9SHKX Top Freezer Refrigerator
GE GSS25LGM freezer not working. It's about 8
it seems like the thermostat on the freezer side is not function right but does the motor of the freezer run or not if not check thermostat
May 16, 2009 | GE GSS25LGM Side by Side Refrigerator
Ice building up on freezer coils
sounds like the fan for the freezer is not working
Apr 03, 2009 | GE GSS25LGM Side by Side Refrigerator
Freezer freezes and then thaws
check wiring into outlet and at breaker that feeds outlet. you may be losing high volts at or to the switch. if possible check power into the stat when the condition occurs. this will telll you if stat is bad or power into it aka the outlet is bad. you may be jiggling wires in the outlet enough to fix short term each time you replug to outlet or get a good heavy extension cord and plug in else where to seee if problem goes away.Good luck
Dec 06, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Thermal switch disfunction
How long did it work before quitting? how long did you have it turned off? Does the compressor run? Many things can cause this problem..Is the back wall of the freezer cold? Are all fans running? let me know....
Feb 15, 2008 | Refrigerators
GE GSS25LGM Ice maker
one of the valves could be open circuit. ice build up where the pipe enters the cabinet or sadly if not that then the complete ice maker. hope this helps
Feb 11, 2008 | GE GSS25LGM Side by Side Refrigerator
Side by side freezer defrost automatically
try to limit the humidity of food put them in close bags or something/check the seal of the door/are you open it very often?this can cause small defrost cycle
Nov 17, 2007 | GE GSS25LGM Side by Side Refrigerator
GE GSS25LGM Side by Side Refrigerator Logo
60 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
