Question about HP Office Equipment & Supplies
When I click print. I get a message back that its deleating printing
  • forestlady38 Jun 25, 2009
    this solution did not work. Still working on the problem.
    Scholar:
  • 169 Answers
Check for the installed drivers in the control panel.try uinstalling the drivers and reinstalling them back again...then try a plug and play....it should help.....
Posted on Jun 24, 2009
Document will not print; status reads deleating-printing; printer appears to be frozen; does not print any other items...
Kill the job on computer that sent the print job. If the job fails to clear you can stop and start the print spooler
Right click My Computer > Manage > Services.
Right click Print Spooler > Stop then Start. That should clear the job.
Same principle pertains to a network printer, but needs to be done print server.
Sep 24, 2012 | Lexmark International Lexmark 8300 Series
Keeps printing old mess. can I clear all and start again
just go on printer n faxes
a window will open. just double click on ur printer i.e. canon pixma mx310, it will opean a dialogue box n shows ur printing status. dn select all the jobs command's n right click n cancel after dt a dialouge box will opean n ask u for deleate all ur printing commands. select yes .
All done.
start with new printing commands n get print's
May 29, 2011 | Canon PIXMA MX310 All-In-One Printer
Have a file stuck in printer folder and will not deleate
This step is to clean the print queue, be sure you have a copy of the existing file your trying to print. -click start(Circle windows logo in 7 and Vista) -click run (click on a bar just above logo for7 and Vista) -type"services.msc" then press <enter> -look for Print Spooler -right click and restart -check if the printer queue is clean
Aug 25, 2010 | Computers & Internet
Will not print any documents
first of i need to know what type of computer you aare using then i can help you but you have to check on the process jobs you have in the printing que then delete some of them that might have hang the printer and thus fail to communicate properly with the computer system that is desktop.
get back to me as soon as this helps so we can get another way out kamu2cyprian@yahoo.com
tell me the type of printer you are using
cheers
Jul 04, 2008 | Computers & Internet
I have to restart the print spooler, deleat the printer and re-install the printer in order to get it to work. This is after I turn the computer off and back on. This is the only way I print anything.
check your settings both in the computer and software in the printer properties. Turn off the spooler setting and have the printer print directly to the computer.
Jun 27, 2008 | Office Equipment & Supplies
Not accepting command to print. The printer is OK.
Go to control panel, printers, find the printer you have, right click, see properties, bottom of page print test, see what happens. Did it ever print. Deleate printer, turn computer off turn on XP or Vista should find printer and install. Then test again as above.
Jun 23, 2008 | Compaq Computers & Internet
Printer locks up
  1. Click Start, Printers and Faxes and double-click on the Lexmark printer driver.
  2. Open the Printer menu and select Cancel All Documents. This will purge the print queue so as to allow the printer to print or uninstall the driver.
  3. If the print jobs are not removed from the queue, click Start, Run, type Net Stop Spooler, and press ENTER.
  4. Click Start, Shutdown, and select Restart. The documents or the print jobs should be removed.
If you are having difficulty deleting the print jobs in the printer spooler, do the following:
  1. Restart the PC in "safe mode". To do this:
    1. Click Start, Shut Down and select Restart.
    2. While the PC is restarting, press the F8 key on the keyboard. Note: Do not hold down the key down, but be aware that you may need to press it several times.
  2. When in safe mode, click Start, My Computer.
  3. Double-click on the (C:) drive.
  4. Double-click on the Windows folder.
  5. Double-click on the System32 folder.
  6. Double-click on the Spool folder.
  7. Double-click on the Printers folder.
  8. Select the contents of this folder and click Delete.
Mar 22, 2008 | Lexmark X3480 All-In-One Printer
No Connection Sign
HI Gymap,
you can check the status of the printer in control panel, printer and faxes, in XP and in windows 98 or ME go to printers in control panel.
if the printer status shows paused or off line, then double click on the printer and then click on file then click on use printer off line and that should change the status.
If still no go then make sure there are no documents in the printer que when you double click on the printer icon, then deleat the printer icon and disconnect the usb cable of the printer and restart the computer, then connect the cable, that should fix the problem.
Let me know if you still have any issues.
take care bye
Nov 17, 2007 | HP Officejet 5610 All-In-One InkJet...
I keep getting the message unable to print see trouble shooting in manual
If trying to Print in Word 2003 - 2002 - 2002
Click on tools > options > Print tab > Uncheck Back Ground Printing. Click on ok. Try Printing.
If you are trying to Print from Word 2007.
Click on Office button > Word options > Advanced > Locate Print options and uncheck Backgound Printing click on ok. try Printing
Oct 19, 2007 | Brother MFC 210C All-In-One InkJet Printer
23 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
