Our AC unit @ the house is putting out heat instead of cold air. wastold it was the heat reversing valve was not opening and closing.
  • 43 Answers
If you have a "Heat Pump" there are many causes for your reveresing valve not to close or open depending on which way your system works. You would be wise to have a qualiforned technician test your system to find the cause of problem.
Here is a list of things thast could cause the problem:
control wire for reversing valve disconnected or broken
wrong thermostat
thermostat gone bad
reversing valve coil defective
defrost timer bad (some makes)
system wired incorrectly
The above are just a few......
Posted on Jun 25, 2009
In AC mode the cooler fan doesn't turn on and after a little while the warm air starts to blow instead of cold air. Any ideas
Sounds like a bad or stuck reversing valve. Typically r.vs. are energized in cooling, verify 24 volts to valve, if yes , bad valve
Sep 30, 2016 | Whynter ARC-14SH ECO-FRIENDLY 14000 BTU...
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
Using as heater and unit is blowing cold air
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
My 19 ft airstream's Penguin duo-therm a/c unit just started blowing out HOT air!!!! Why is this occurring?
If you have a heatpump model a/c unit, and it is blowing air that is hotter than the ambient temperature inside the airstream, then it is likely that your reversing valve is stuck in the open or closed position. A heatpump is basically an air conditioner that will also run in reverse (via the reversing valve) in order to heat instead of cool. The valve can get stuck for a variety of reasons, including; faulty wiring caused by rodents chewing or vibrations, insulators (dirt) between switch surfaces, or it could be a mechanical problem within the valve its self; these valves break often.
Sep 12, 2013 | Dometic Heating & Cooling
Heater and ac controlls not working 1994 corvette
Are all the vents working? Does your Cruise Control work (properly) it may work and shut off. If your vents are working is only hot air or cold air coming thru, or just your defroster vent?
You have a 3 way check valve under fuel rail guard on passengers side, its a pastic barrel shape thing it rots and creates holes in it causing your ac vents and cruise control to malfunction.
next your heater control unit if you have the one with a slider to regulate the hot or cold temperature breaks easily inside unit, its only plastic. Its an arm inside unit to control the temp in car it slides a door open or closed for heat. If you look where he slider enters thru that hole space you will see a post it sits on to open and close .
Nov 20, 2012 | 1994 Chevrolet Corvette
2004 mercury mountaineer.heat problem When turning ac knob to heat clicking sound like door opening and closing repeatedly sounds and air blows cold instead of hot.
Sep 13, 2010 | 2004 Mercury Mountaineer
I have a gas furnace that was to have a 10acc air conditioner unit installed with it. Instead of the 10acc unit a 10hpr48 heat pump unit was installed, The house is 4 years old and the reversing valve has...
it should definitly be warrantied. their is nothing wrong with your set up however id have the contrator pull a new wire and go dual fuel withh outdoor sensor and get the full benifit of dual fuel. you should use the hp above 40
Sep 16, 2009 | Heating & Cooling
Ac BLOWING HOT AIR INSTEAD OF COLD. All of a sudden my AC started blowing hot air instead of cold. It is set on cool.
Check to see if your outside unit is running. If not, check the breaker. If it is running you may have an issue with the reversing valve. It looks like three lines coming out of the top and one on the bottom. Trace the wires back to see that they are tight and secure. Of course, TURN OFF THE POWER first. good luck.
Apr 18, 2009 | Hunter 30124 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
