Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mine is a 48" deck it runs good but when I engage the mower deck it blows the fuse
    Problem Solver:
  • 7 Answers
Check wire touching frame
Posted on Jun 25, 2009
Even with the mower not running when i pull the switch to engage deck it blows 20 amp fuse
Kelly, ray g. nailed it, First be sure it is only to be a 20 amp fuse, The wires to the clutch that drive the deck will be broke or bare shorting out on each other or on metal, wire are quite commonly broke by the clutch plug or close by. what you can do is carefully follow the wire from switch through the system and look for damage or bare spots, pay special attention when wire runs through frame/body holes and any where it could rub on metal or moving parts. Check the attached links,instruction and guides,4th link see Randy T. reply in forum, has good test method for your problem. Good Luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Craftsman 917 273631 Fuses keeping blowing when blades are engaged
CC1042 with Kohler Keeps Blowing Fuse when PTO Engaged
Blowing Fuses
265 blowing main fuse when engaging PTO
Apr 25, 2016 | Garden
The mower starts but it keeps blowing the fuse when I engage the blades
check for a area of the wire insulation that has been wore off against the frame or body of the mower. sounds like a electrical short. it may be a very small spot that's all it takes so check well
Jul 09, 2014 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna EZ5424 lawn mower zero turn mower deck will not engage checked fuse checks good where is the electromagnetic coupling located and what is its purpouse?
The electromagnetic coupling is on the bottom of the crankshaft under the mower engine. When the magnets are engaged (power is supplied), they activate the pulley that moves the deck belt.
Jun 22, 2014 | Husqvarna EZ4824 24 hp 48" Zero Turn Lawn...
EXmark mower blows fuse when deck is engaged.
try checking the wires from the switch that engages the mower deck. if there is a wire grounding out sumplace when you kick it on it will keep popping the fuse no matter what. id say its a short.
Mar 16, 2012 | Craftsman Garden
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My 48 inch riding mower shuts off when I try to engage the blade. It runs until I try to engage
mine has a reverse cut out when blades are running....maybe the switch is bad and thinks mower is in reverse therefore shutting down the mower when the blades are engaged....
Aug 21, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
2007 Husqvarna Riding mower blade will not engage when switch pulled out. Fuse blows & mower dies! Help!
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Apr 25, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Blowing fuses
try unplugging the pto, starting the mower and then engaging the blades. If it still blows a fuse the problem lies in the mowers wiring. If not the problem is the pto. Hope this helps
Jul 13, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mower deck will not engage.
you have sheared off the keyway either on the mandrel or pully on the engine
Jun 30, 2009 | Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
80 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
