Question about Gateway T-1625 Notebook
If my computer isn't booting can i remove the hard drive and use a hard drive adapter to transfer my files to another source?
  • 92 Answers
Yes, You Can !!
Best Regards
Posted on Jun 24, 2009
Transfer stuff from a working and put it on another hard drive
The easiest way is to connect your hard drive to an USB hard drive adapter or USB hard drive dock, then plug this USB adapter ot dock into the USB port of your computer. The computer will see this as an external storage device, you can then open the various folders and copy the folders or files to the computer,
If you want to copy these folders or files to another hard disk then connect the other hard drive to the USB hard drive adapter or USB hard drive dock and plug it into your computer and copy the folders or files from your computer to the external hard drive.
Mar 28, 2013 | Maxtor Hard Drive
I want to turn a memory stick into hard drive. How can i do that?
you will need usb data drive at least 4 - 8 gb
Download the GParted Live utility and the HP USB Format Tool via the links in Resources.
http://www.majorgeeks.com/downloadget.php?id=5757&file=15&evp=fb0a8fee133295405b5af3205e8d2424
Insert your USB stick into the computer. Run HP USB Format Tool. Select your USB stick and then choose the FAT or FAT32 format options. Click "Start."
Extract the files from the GParted Live zip file. Select the USB stick as the destination.
Open a file browser and navigate to the USB stick. Select "utils" > "win32" > "makeboot.bat." Double click on "makeboot.bat." Enter "Y" when prompted.
Power off your computer leaving the USB stick inserted.
Connect your portable hard drive to another USB port.
Power on the computer and quickly press "F8" through "F12" to access your boot menu.
Check your computer or motherboard manual for the exact keystroke.
Select the USB stick as your boot source and press "Enter." Allow the Gparted GUI to start.
Select the external portable hard disk drive. Click "Partition" on the menu bar.
Hover over "Format to" and select "NTSF."
If you are unable to create or format the partition, select delete partition.
This will erase all data on the external hard drive. Confirm partition deletion. Select the external drive again. Click "Partition" and hover over "Format to" then select "NTSF."
Select the external hard disk drive again. Click "Partition" on the menu bar and then "Manage Flags." Check the box next to "Boot." Save and apply changes to the drive.
Power off your computer and remove the USB stick.
Install the OS
Insert or plug your OS installer, usually a DVD, CD or USB thumb drive, into the computer. Power on the computer and access the boot manager again.
Select the source containing your OS installer and press "Enter."
Enter your personalization and registration information if required.
When prompted, specify the portable hard drive as the install directory.
Begin the installation normally.
Restart the computer when prompted and access the boot menu again. Select the external hard drive as your boot source and press "Enter" to ensure the installation succeeded.
Use this process to boot from your portable drive on any computer.
hope this helps
Oct 02, 2012 | Sony Vaio VGNBX196SP
I want to download all info from my desktop and motherboard into mylaptop
Hi Eva!
If your desktop is crashed, then you will need to verify if its internal hard drive is still working, and then conect it using an USB/SATA/IDE adapter to your Laptop. This is one: http://www.sataadapter.com/SATA-IDE-ATA-66-ATA-100-ATA-133-COMBO-ADAPTER/sata-ide-adapter-usb-hard-drive-sata-drive.html
If the problem with your desktop is with its hard drive, then... you need to take your computer to its manufacturer technnical service center.
Sep 27, 2012 | Sony VAIO PCV-W600G PC Desktop
Windows xp operating system
Remove the hard drive from the laptop and connect it to the USB hard drive adapter then connect it to a working computer's USB port. This computer will see the USB hard drive adapter and hard drive as an external storage device, you can then open the folders and files on the hard drive and copy the data files to the computer and to backup your files.
Aug 07, 2012 | Dell Computers & Internet
Gateway laptop will not boot up with or without a disk is there anyway to get my info and files off myself
If you have access to another computer you could purchase a hard drive (IDE/SATA) to USB adapter. Remove the hard drive from the Pacific Blue PC Notebook, plug the hard drive into the adapter and then the adapter into a USB port on the other computer. The other computer should find the USB hard drive automatically and give you access to your files.
This of course will only work if your laptop's hard drive is working. If your laptop won't boot because of a hard drive failure then I'm sorry you're out of luck.
Hope this helps ;)
Jan 27, 2011 | Gateway Laptop with Intel Centrino...
Looks like my hard drive is full and it can not boot up. how can I get to the hard drive to delete pictures to have more space for window to load?
If the hard drive is not faulty and the computer won't boot up, then remove the hard drive from your computer and connect it an USB hard drive adapter. Connect the adapter and hard drive to a working computer's USB port, this computer will see this as an external storage device, you can then open the various folders and delete the photos or data files.
When you restore the hard drive back into your computer and when it boots up, your should do a Disk Cleanup then a Defrag. Disk Cleanup will remove old temporary files, old compressed files etc and free up disk space. Defrag will make fragmented files contiguous so the files can be accessed more efficiently. If you have not run these programs before, it will take a log time to complete.
Disk Cleanup and Defrag should be carried out once a month to maintain the hard disk.
Dec 20, 2010 | Computers & Internet
I bought a ep43-ud3l mobo that I installed with windows, after moving some files from my old hard drive windows became corrupted , boot up resulted in BSOD, erased windows bsod, formated HD BSOD, removed...
pls check the cpu compatibility. one time I tried to install 64bit , but could;t install. 32 bit was ok. check the video adapter and remove it and try it with on board vga
Jul 17, 2017 | Gigabyte GA-EP43-UD3L Motherboard
I need to transfer data from an old and sickly Dell Insiron 8100 to a new 2010 external hard drive....no conforming ports....pls advise what I need to purchase...cable?....for transfer ...and either...
The first thing I would do is pull the hard drive from the sick Inspiron. Now get yourself an IDE/SATA to USB adapter from a computer retailer or on Ebay, they cost about 20 bucks. Attach the HDD from the Inspiron to the adapter and attach the usb side of the cable to a good computer. The computer will now read this drive as an external and allow to access any and all files. Just make sure that before you remove the HDD from the Inspiron, you remove any passwords on the computer that might limit your access to files. Also on the good computer go to control panel > Folder Options. Click on the boxes to allow viewing of system files etc. just for a little while, during the files copy. Make a folder on your desktop and name it whatever you want. Now go through the HDD from the Inspiron and copy any and all files to that folder. When you have finished, attach your new external. Now just copy the files from the folder on the desktop to the new external drive and there you go. These adapters are the only true way to be able to pull this off. Good luck
Jan 28, 2010 | Dell (0K724) for Inspiron 8100 40 GB Hard...
ACER Aspire L100 Desktop is dead?
If the hard drive is OK then you can remove the hard drive from the desktop case, and insert the hard drive into a USB 3 1/2" hard drive adapter case, this should come with a power adapter. These are available at your friendly computer shop.
Boot up the laptop then plug this USB hard drive adapter into the laptop's USB port. The laptop will see this as an external USB hard drive. You can open the various folders and files on this external drive and copy the folders and files to the laptop.
You can delete the Windows folder and Program Folders on this external drive to free up disk space and use this as a back up drive etc.
If you are not sure how to remove the hard drive and install it into an USB hard disk case, then I suggest you get a computer savy friend to help you.
Dec 08, 2009 | Acer Aspire L100 PC Desktop
Cannot transfer roots web files from windows xp to routed laptop vista
Most Windows files cannot be copied and / or transferred if they are in use. The only want to actuallt copy and transfer files of that nature is to remove the hard drive and use a usb adapter to attach it to another computer and access the hard drive as if it was an external, since the hard drive is not being used to boot the system all the files will be available. Just make sure that before you do anything, go to control panel > folder options > view > click on show system files and folders. This will allow you to be able to see all files and folders regarless of what they are.
Mar 10, 2009 | Microsoft Windows Vista Ultimate Edition
Gateway T-1625 Notebook Logo
73 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
