Question about Xerox Phaser 8560MFP Laser Printer
LCD blanked out on my 8560
Xerox Phaser 8560 LCD quit working. Opened the top door to the drum and closed and LCD worked again for about 24 hours. Checked connectors and they seem ok. Solutions?
    Sergeant:
  • 199 Answers
Check the contrast dial on the copier
Posted on Jun 24, 2009
Xerox 8550 yellow bleeds into black on lightstripe test. After several runs of test it improves and my blacks are black again for awhile. Do I need a new printhead? I don't want to buy a new printer...
This could be a leaking printhead but it is more likely to be a failed wiper/cleaning blade.
I have checked and as far as I can see, the additional trays should work on a Phaser 8560 as they both have the same part number which is 097S03174.
Hope this helps.
Jan 03, 2011 | Xerox Phaser 8200 Laser Printer
Control panel is blank even though power is on
Had experienced the same problem with a Phaser 8560DN, the only solution for that is to replace the panel. You can buy one off Ebay for $50: http://cgi.ebay.com/Xerox-Phaser-8500-8550-8560-LCD-Control-Panel-Display-/110649342908?pt=LH_DefaultDomain_0&hash=item19c336fbbc
Dec 18, 2010 | Xerox Phaser 8560DN Laser Printer
Xerox phaser 8560 1st page is blurry. The 2nd page is OK.
The good news is that you don't need any parts.
The oil from the drum is drooling to the right side to the Drum Position Sensor is located.
Remove the right cover. Remove the fan. Loosen the clear plastic cover under that. Clean the sensor and all the wires with very pure Isopropyl or denatured alcohol.
The situation may reoccur every year or so.
Whit
Item, Inc.
Jul 26, 2010 | Xerox Phaser 8560N Laser Printer
LCD screen blank on our Xerox 8560 Printer
You should replace the control panel yourself 802K93650. It's a 5 minute job.
-Whit :)
Jun 24, 2009 | Xerox Phaser 8560MFP Laser Printer
RESET INSTRUCTONS FOR XEROX 8560 MAINTENANCE KIT
There is no reset. Xerox never designed a supply reset for this machine.
If you installed a new one, either 1) you've got a bad one (get it replaced under warranty) 2)
the chip is not being read (due to drum maintenance camshaft cracked and out of position
Jun 03, 2009 | Xerox Phaser 8560MFP Laser Printer
P/N FOR pHASER 8560 DISPLAY PANEL
P/N for Phaser 8560 printer is 802K93650
Apr 21, 2009 | Xerox Phaser 8560DN Laser Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
XEROX Phaser 8560 - Maintenance Kit
They sell a lot of maintenance kits that way.I worked for a major Tampa are copier company for 10 years and they used every part until it just quit.However, you should line up a maintenance kit at the ready.Sometimes a counter will shut down the copier when it gets to the point where they want it to stop.
Apr 07, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox 8560 37X Fault code
either the paper pulling gears are not spinning properly or they are craked or getting blocked by any dust particles.
or the fuser unit in the copier is not getting properly heated up.fuser unit has to be checked first before replacing and the printer /copier needs to be opened to check the fuser unit.
Feb 26, 2009 | Xerox Phaser 850DP Thermal Printer
Xerox Phaser 8560MFP Laser Printer Logo
461 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
