Question about Hotpoint (HSM25IFTSA) Side by Side Refrigerator
Ice dispenser not dispensing ice or water
The ice maker is working, but, the dispenser is not. I can't hear the motor humming, just the click when I push the dispenser.
The tube that supplies water to the tray of the ice maker,may have frozen solid. unclog u should be good
Posted on Jul 20, 2009
  • 744 Answers
Check the water filter - it should be at the bottom of the fridge - turn it 1/2 turn to the left. After several months of use (less if you use it a lot) the filter can clog.
Posted on Jun 24, 2009
Ice maker makes ice and dispenses to ice bucket but will not dispense from the door
Check that the motor is connecting to the drive and isn't broken. Also. Check to make sure no frozen chunks are jamming the auger
Oct 07, 2015 | Refrigerators
Water dispenser not working
Have you changed the water filter? they can plug up over time. The water tube can freeze in the door. To test this there usually is a disconnect under the freezer door side of the grill you can disconnect this and hit the water dispenser lever. If the door is getting water then it is frozen in the door. If not the water valve could be your problem there are two sides to the water valve one for the water dispenser and one for the icemaker. A last possibility is there is a water tank or tubing loop in the refrigerator behind the crisper this could have frozen.
Feb 10, 2014 | Refrigerators
Hi, I have a amana af12538aes french door refrig. Starting this am, the control on the door does not deliver ice only cold water from the ice button. The ice maker is making ice. Is this a control...
Is the display flashing when you try and use it or can you hear the dispenser door opening and closing rapidly (clicking or clapping sound)? These are prone to the board going bad and losing the dispenser. Is the "ice" light lit on the dispenser? The touch pad could be bad too. Do you hear the auger motor turning the ice when you press the dispenser? or just the "shhhhhhh" of the water coming out?
If there is ice in the bucket then that is not the problem. Dump it and listen if you hear new ice drop to verify.
There is no such part called an "ice element". Ice maker-yes.. Heating element-yes.. Ice dispenser-yes
Mar 04, 2018 | Amana AFD2535DES French Door Refrigerator
Water dispenser quit.ice maker works fine you can hear motor hum when pressing water dispenser button
You should not hear the noise of a motor unless you are trying to dispense ice. Is that the case your ice dispensor is not working?
Sep 16, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Nov 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hotpoint (HSM25IFTSA) Side by Side Refrigerator Logo
864 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
