Question about Frigidaire Dishwashers
I have an FDS252RBS2 Frigidaire dishwasher. It's about four years old, and has always worked well. Now, no water appears to be entering. The dishes are dry and dirty at the end of the wash cycle. I removed the tower and the float, and both were clean. Is this a total disaster, or can it be fixed?
SOURCE: My Dishwasher does'nt dry my dishes.
set the sanitize button and they will dry
Posted on Dec 30, 2006
catriver
  • 878 Answers
SOURCE: Kitchenaid Superba Dishwasher
gagaweaver, couple of things you want to check here. Check the upper spray arm for any clogged holes or cracks along the edges. Position it in the 12:00 position and run the dishwasher for a little, open the door and verify that it has rotated. Make sure the water entering the dishwasher is min. 120 degrees, use a thermometer. Makes sure that there is no large pans or dishes blocking the upper spray arm from spraying onto the inner door. If all that checks out. You will have to remove the lower spray arm, filter cover and chopper cover to make sure the chopper screen is not coated or plugged up. If it is, it will prevent a good flow of water to the upper spray arm. Catriver..post back.
Posted on Mar 08, 2007
  • 1314 Answers
SOURCE: frigidaire dishwasher ultaquiet , model=FDB750RCC1
the first thing that your dishwasher does when you turn it on is drain when you turn it on you hear a motor running then it stops then it fills start the washer when it stops to start filling open the door should be no water in the unit if there is you have a drain problem and in fact are washing your dishes in dirty water can be several things that can cause drain problems a piece of food blocking the line at the sink where the drain goes in if its run to a disposer there is a knockout plug that should be removed just stick your finger in there to see if it was removed get you installation instructions and read the part about not removing the drain loop but just about all the time installers will lol if you cant find the instructions go to www.frigidaire.com under customer support can down load them there let me know what you find
Posted on Jan 17, 2008
IFIXALL
  • 868 Answers
SOURCE: Dishes are ALWAYS WET!!!
It is 1 of 2 things here,your either not using rinse aid or your heater is not on.Make sure you have selected the option "heat dry".
Please Rate This !
Posted on Aug 25, 2008
SOURCE: dishes dirty
did you rinse them off first
Posted on Sep 14, 2008
I have a Frigidaire dishwasher approximately one-year-old. Has always worked great but lately white residue left in bottom of stainless steel and residue on dishes. Have switched dishwashing detergent Ran...
Try doing a wash with vinegar. It will clean all of those hard water and soap/lime deposits away. We do this frequently (once a month) here in Dallas, TX because the water is really bad.
Oct 27, 2014 | Dishwashers
Frigidaire dishwasher 15 months old. just started not washing dishes very well. set it for high temp wash. put plenty of fresh dishwashing liquid in. the unit goes thru a full cycle. you open the door and...
First I would check to see if it is getting enough water. There is a screen in the water inlet valve that tends to pick up debris. Follow the links Dishwasher not cleaning starting with the video on the water inlet valve.
Nov 05, 2010 | Frigidaire Dishwashers
I have a frigidaire dishwasher 3yrs old and it leaves a thick white film on on my dishes. Tried a dishwasher mayic and nothing works
well first, is it draining properly? Secondly, you should always run the hot water in your sink b4 starting the dw. It only brings in a little water, and if it just pulls it from the pipes, it will be house temp. Hot water is needed to activate the detergent. Also, if you are using tablets or squares, try simple powder or liquid. Always make sure that your jet dry dispenser isn't empty.
Nov 04, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Frigidaire built in dishwasher model PLD2855RFC1. Have to wash dishes pretty much spotless prior to using dishwaser. Glasses come out with what appears to be soap residue regardless if powder or liquid....
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
May 31, 2010 | Frigidaire PLD2855RFC Dishwasher
Dishwasher does not drain completely
Check your main drain system where your finally connect to let off the dish washer water.
Apr 10, 2010 | Frigidaire 24 in. PLD2850 Built-in...
TOP RACK NOT CLEANING DISHES
Possible that the motor impeller has good particles in it, causing poor water pressure, which would be most evident on the top rack. You would have to remove the spray arm, then the filter, then the torx screws to get at impeller....unfortunately, that model of dishwasher isn't the greatest in the first place for washing, since it only has the one spray arm.
Apr 04, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Dibris on glasses afterwash. Dishes not coming clean
First check salt level is ok, the next thing may be it's having problems pumping out after the primary wash.
Try running a hot cycle with a dishwasher cleaner or 2 cups of washing soda, then pull out outlet hose and check it's clear.
Check all filters are clear and in good condition with no cracks.
Aug 05, 2009 | Thermador DW44Z Built-in Dishwasher
The dishes don't get clean
Dishes not cleaned properly....
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Mar 31, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Very filmy looking glasses
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Jan 31, 2009 | Bosch 24 in. SHY66C05 Stainless Steel...
Water not draining out after wash cycle
frigidaire dishwasher model#MDR251RER0/serial#TH84453602 not completely draining. I hear when it the drain cycle begins but does not empty completely out.
Jan 05, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Dishwashers Logo
55 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
