Question about Technics SL-1200MK2 Turntable
Weak output signal when compared to my other table.
Just recently I noticed that the output from my one turtable was obviously lower than my second table. I swapped Stylus', swapped cartridges, swapped channel inputs used on the Mixer (DJM-500) yet the problems is isolated with the turntable unit. I assured the channels were equal, trim was equal, and even used the same vinyl to test it out. Any suggestions??? Thanks in advance.. Mike B
  • Drenalin Nov 06, 2007
    That sounds like a good suggestion. But would the cables gradually deteriorate. Not too long ago they both were putting out equally, yet for whatever reason one is sounding weaker. I recal reading a turntablism page a while back and they mentioned that if you look at the serial number on the back, the two letters after the serial number indicate where that particular table is destined/manufactured. Would this have some bearing? Another thing that seems strange is that the table which is weaker, oddly emough happens to be fairly new in the sense that it hasn;t been play as regulary in the past when the previous owner had it. And I myself havent spent many overkill hours pumping out the tracks. I suppose it wouldn't hurt the get the cables replaced on both units.... Any repitable service depot in Alberta that you know of?? Thanks for the quick response, that was awesome..!! Mike
  • 515 Answers
This does happen. The RCA cables used on the Technics 1200's aren't of the greatest quality, and you will find lower output on some turntables. This can become an issue, if you record your sets to your PC, or you use Serato, Final Scratch, or any of the digital control set ups. There is only 1 way to resolve this, and that's to switch out the RCA cables on both turntables, and ensure that they are matched. This can be done by any qualified audio service technician. Just make sure you choose some good quality RCA cables, and not the standard OEM Technics cables.
Posted on Nov 05, 2007
Record player turn table and needle not communicating
1. Check that the cartridge is fitted to the arm properly because if there is a bad connection you will get no sound.
2. If properly fitted to the arm there may be a problem with the cartridge the stylus is mounted in. You basically have to trace it back from there.
Most of the new lower end turn tables I have seen on the market are pretty shoddy and if people are having problems with them I am not surprised. You pay big dollars for a good turn table now like the Thorens. If you want a good turn table that will last a lifetime and be 100% reliable with excellent sound that is what you need to buy.
http://www.thorens.com/turntables/drives.html
Dec 26, 2015 | Audio Players & Recorders
Fixing to solder wires back on a Philco turn table needle assembly. need to know sequence of where each wire goes. 4 total
You'll have to reverse-engineer the cartridge and cables. If you know how to use an ohmmeter, it isn't that difficult.
First, this is a stereo cartridge, so it will have two pickup coils. The only question is whether they are connected one on each side, or on one on the top and the other on the bottom. Most likely it is one on each side. Use the ohmmeter to verify by looking for a resistance between the upper and lower terminals on one side of the cartridge, then checking for a similar resistance on the other side.
Next, you'll need to match up the wires with the output connections. You will have tip (right), shield (right), tip (left) and shield (left). The right side wires go to one coil of the cartridge, and the left goes to the other. If you get the wires backwards, you will have a phase-reversed sound (the speaker goes in instead of out and vice versa - only an audiophile would notice the difference). If you get the wires to the wrong coils, the left and right channels will be reversed, but you can get around this by swapping the left and right connections at the amplifier.
If you are lucky, your cartridge has colored markings at the terminals for the tip connections. Red would be right, and white would be left. You can also try to find a data sheet for the cartridge, perhaps at the cartridge manufacturer's website, if one exists. The cartridge manufacturer probably has a single standard connection scheme for all products, so any data sheet would provide it.
Dec 18, 2014 | Philco Audio Players & Recorders
How to replace stylus on AIWA stereo turtable
the old stylus snaps off. pull evenly straight out. The new one snaps on in its place. Do not touch the needle as it is easily damaged.
Jul 02, 2014 | Aiwa PX-E860 Turntable
WANT TO REPLACE STYLUS FOR AKAI TURTABLE MODEL NO. AP-001
Look at the cartridge it fits in. That will have a make and number. You can trace the stylus by entering that into Google.
Mar 31, 2013 | Audio Players & Recorders
Epson Stylus C40 Plus printer cartridge replacement instructions
Hi
It sounds more like the printhead is blocked as if it either hasnt been used much or if the cartridges where taken out and the air has got to the nozzles, this would cause it to dry out and prevent the ink from flowing from the cartridge itself.
The C40 is pretty dated, so would probably cost more to repair than its worth. The S20 is about the closest match and is about £35 so might be worth looking at replacing.
Thanks
Taz
Oct 24, 2009 | Office Equipment & Supplies
No Right Front Speaker Output
Swap speakers over...check the balance isn't fully to the other channel...swap left/right phono cables over (if thats how your using it) other than that i would say is broke.
Easy way to check speaker cable/speaker... touch a small battery (like used in a remote) across speaker wires, you will hear and see the speaker cone move.
Aug 07, 2009 | Audio Players & Recorders
Catridge won't go to right position
Please follow the steps below to replace one or more cartridges.
NOTE: It is necessary to have all four ink cartridges installed and supplied with ink in order for the unit to function properly. The unit will be in an OFFLINE state if the any of the cartridges are expended. This is a protection feature of the unit, to prevent air from being pumped through the print head.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
**NOTE** To avoid damaging the unit, NEVER move the print head by hand.
1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
3. Press and release the INK button. The print heads will move to the left, and the cartridge that needs to be replaced will stop directly beneath the OUT OF INK symbol. Make a note of which cartridge requires replacement.
4. Press and release the INK button again. If more than one ink cartridge is empty, the next cartridge will move under the OUT OF INK symbol. If no other cartridges are out of ink, the print heads will now move to the REPLACEMENT POSITION.
5. Open the CARTRIDGE COVER. Pinch the front and back tabs of the empty cartridge as you lift it out of the unit. Dispose of this cartridge.
6. Before you remove the new cartridge from its package, shake it four or five times.
7. Remove the new cartridge from its package, and lower it into the cartridge holder. Push down gently until the cartridge clicks into place.
8. Repeat steps 5-7 for each cartridge that you need to replace. Close the
CARTRIDGE COVER once all of the necessary ink cartridges are replaced.
9. Carefully lower the scanner, until it clicks into place
10. Press and release the INK button.
The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus printer while the ON light is flashing, unless the Stylus printer hasn't moved or made noise for more than 5 minutes.
Jun 12, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Changing the ink cartridge in Epson Stylus CX4200
8. Repeat steps 5-7 for each cartridge that you need to replace. Close the CARTRIDGE COVER once all of the necessary ink cartridges are replaced.
May 15, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Epson stylus cx5400 reset???
try doing this :
Reclamping the Ink Cartridges
Once you start the ink cartridge reclamp procedure, you must complete all the steps in one session.
1. Make sure the EPSON Stylus CX5400 is turned on and not printing.
2. Press a MENU button until you see CHANGE CARTRIDGE, then press the COLOR COPY BUTTON. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Lower the cartridge back into its holder, then press down on the top of the cartridge until it clicks in place.
Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
6. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX5400 hasn't moved or made noise for more than 5 minutes.
if the issue still persists - you need to call the vendor - it´s a hardware issue
Dec 30, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Technics SL-1200MK2 Turntable Logo
310 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
