Question about Electronics - Others
My HT-TX75 DVD flashes a message
My Samsung HT-TX75 DVD flashes a message "PROTECTION...GOOD BYE" then shuts off. What is wrong with the unit?
    President:
  • 1,114 Answers
First thing to do is disconnect all your speakers at the back of the receiver, then turn it back on. If it does not go into protection, post a comment and I can walk you thru troubleshooting. If it still goes into protection, your unit needs to be serviced. Hope this helps
Posted on Jun 24, 2009
Hey Smarthome, i didnt post the above problem but mine is the same, so was hoping you could help?
I have the Samsung HT-TX35r system, has worked perfect for the last 16 months until only recently started turning off (after displaying the protection message)
Now this message only appears to be displayed when the system is in use, i have had the system reamin on for 24hours plus, but this is only when i remove all the speakers and it is not ouputing any sound, nor is it interacting with any of the functions, ie its not on radio, nor is a dvd player or my ps3 running.
Ive tried a number of different variables but its as soon as i starting using it as id like to, its only then does it turn off?
Does that all make sense?
Thanks in advance
Posted on Jul 20, 2009
My dvd home theatre system ht tx75 keeps shutting down
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 28, 2009 | Samsung HT-TX72 Theater System
Shuts down by itself
If there are no speakers connected and you still get the protection message, there is a problem internally. Exchange the unit while you can. The typical parts required to fix this problem will be over $75 US.
Dan
Mar 25, 2009 | Samsung Audio Players & Recorders
I have a samsung ht-tx75 and it keeps shutting down every 10 minutes saying protection.the fan is working
Protection is very likely caused by an over heat condition, even with the fan working if the receiver is in a very enclosed place that warms up and is not ventilated it will cause the problem. The solution is to provide more ventilation so that the receiver can cool itself properly.
Feb 26, 2009 | Samsung HT-TX72 Theater System
I didn't solve the problem,however i called sam sung and I will be sending it in for repairs under warranty.
thank you
Jan 27, 2009 | Samsung 1200W 5.1-Ch. XM-Ready Home...
"Protect" error - HTZ110
Home Theater System Is Displaying "Protection" spacer.gif As soon as the unit is turned on, the word "PROTECTION" will flash on the front panel of the unit and SHUT OFF. This error message usually indicates that the fan in the back of the unit is not on.
The PROTECTION feature automatically shuts down the unit to avoid further damage. The unit will need service if this error message is displayed.
Please use our ASC Locator to find your nearest Authorized Service Center
from samsung's web
http://www.samsung.com/au/support/faqs/supportFaqList.do?group=&type=hometheatre&subtype=hometheatresystems&model_nm=HT-Z110&dType=D&mType=UM&vType=R&prd_ia_cd=03030100&acc_ia_fl=&disp_nm=HT-Z110&menu=faqs
Jan 18, 2009 | Audio Players & Recorders
Samsung dvd/disc protection
Try a hard reset: unplug from power source, remove all cabling and wait for 5 minutes before recabling.
If that fails, it is a logic board error, in which case you are probably better off buying a new device..
May 24, 2008 | Samsung HT-DS610 System
My home theatre system (sAmsung DVD home theatre system HT-Tx75)shuts down automatically after 10 minutes of listening to the radio...it says 'protection', then shuts off. i checked to see if it was on...
Protection mode on a Samsung player most likely means that the unit is overheating due to a non or low functioning fan. Before taking it somewhere to be serviced turn the unit on and see if the fan in the back is functioning (it should be on whenever the unit is on). If it is not you can try gently blowing it out with a can of compressed air.
I am sure that you can have it serviced but it might be cheaper to purchase a new player.
Good luck and take Care,
-WN
May 06, 2008 | Televison & Video
Samsung HT-DS610 System Problem
I found this online. Don't know if it helps you guys or not?
Samsung HT-DS610
1. Remove any discs from the tray
2. Flash the RAM (disconnect from the mains for 30 seconds)
3. Plug it back in, switch on from the remote
4. Wait for "No disc" message
5. Press Enter.
6. Press 8,4,2,6,9 slowly.
7. Press Enter.
You may need to repeat steps 4 through 6 before the try is open.
Nov 25, 2007 | Samsung HT-DS610 System
Dvd home theatre system
When I turn on my DVD it says "welcome to samsung dvd, no disk, protection, good bye" Why? What is wrong and how can I remedy it???
Oct 18, 2007 | Samsung Audio Players & Recorders
Electronics - Others Logo
502 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
