Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer frosts up and stops cooling after approximately 2 weeks GSS201EPHWW
  • 82 Answers
My first guess would be a bad defrost timer. Second would be a defrost heater element.
Posted on Jun 26, 2009
  • 21 Answers
AUTO DEFROST IS BAD REMOVE FREEZER BACK PANEL CHECK HEATER CONTINUITY WITH REFR. UNPLUGGGED IF HEATER BAD ORDER HEATER KIT FOR YOUR MODEL
Posted on Jun 25, 2009
Defrost heater,every 2 weeks back of freezer frosts over, fridge gets warm, manualy dethaw get 2 more weeks
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 06, 2011 | Microwave Ovens
FRS26KR4CB1 side by side refridgerator
Hi MDstuff,
Stopped cooling.  Check the backl of the freezer to see if the Coils are Frosted completely.  The buzzing sound could be the frost touching the  Fan in the back of the freezer behind the cover. Sounds like your Defrost heater has gone south.
1. unplug the Freezer, power down.. for safety
2. Clean all the food out of your Freezer,
3. Remove the shelves and Ice maker tray stuff.
4. REmove the panel in the back of your freezer
5. Is the Coil(Evaporator, Radiator)you see  frosted up?
6. At the bottom of this coil. you should see a metal assembly that stretches accros the bottom of the coil with a wire connection on both ends. This is the Defrost heater.
Remove the heater and look to see if the heaterspring inside the glass tube is broken.  If so, get a new one from Ebay, or www.repairclinic.com.
In the mean time while your waiting on a part, Use a hair dryer to get rid of all the frost and put your freezer back topgether.  You sahoul get 2 or 3 weeks of service on your Freezer, before it happens again.
Oct 13, 2007 | Refrigerators
I have a GE side by side refrigerator, model GSL85JFPHBS. It sstopped working altogether last month. first the refrigerator stopped working, two day later the freezer part stopped working. I had someone...
I think you meant you have a GSL25JFPHBS (not 85).
It sounds like you have a defrost problem. If your refrig. was off for some time, like a day or more, or it was manually defrosted, it would work for about 2 weeks before the problem would re-occuer. This is caused by a build up of frost on the cooling coils, preventing air flow over them. Un-load the freezer and remove shelves and the back wall inside the freezer. Melt the frost with a hair blower, and replace the defrost heater (part # WR51X10055) and for good measure, replace the defrost thermistor (part # WR55X10025) located at the top of the cooling coils.
Mar 21, 2011 | GE Refrigerators
Freezer frosts up, cleaned coil under fridge and defrosted. worked for about 2 weeks and is starting to frost up again.
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 19, 2010 | Amana ABB1927DE Bottom Freezer...
My freezer has started to frost over. It started about 2 weeks ago and is getting worse. What is the cause for the automatic defroster to stop working.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 15, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
either low in freon or defrost timer stuck or unit needs cleaning, remove front louver panel on bottom (either 2 screws or snap fit) look for timer then use small straight screwdriver to turn slowly till clicks then wait to see if working properly, if not could be problem. if you see a lot of dust bunnies while doing then clean with vacuum and do same to back area also
Jun 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
With your new timer in hand look and find a slotted screw driver head that you can turn. That is to manually advance the timer. Now put the new one in and advance it to engage the compressor and fan. Might be in the middle of defrost mode. Your unit goes through 3 defrost modes in a 24 hour period. And each mode last for 20 minutes. Once you do this I could help further if that was the case. Okay ken
May 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge has problems
sounds like the defrost clock may be going bad and or a door switch. Look for a hole that has whatr looks like a big screw that you can turn.
Oct 21, 2008 | Frigidaire FRS26R4A Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
467 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
