Question about NetGear WGR614 Wireless Router
  • 1,463 Answers
Have you tried the nethgear home page for more info
Posted on Nov 05, 2007
0 characters
3 Points
When i disable the firewall for the netgear dg834gv4 router i cannot access to any web site i uplode the firmware to the router but it dosen't worck if any one can help i will be Thankful
Try to reset firewall McAfee Firewall settings and click on "Restore Default" button and let us the status after that.
And upgrade your netgear router more
If you need any kind of technical assistance you can contact support cell at
Aug 30, 2012 | NetGear DG834G Router
Can t get on line on my ps3
The PS3 is plug n play and if your router is as well then it will configure the firewall automagically. However, often the older routers just don't play well together. You need to open up ports manually and configure the router and firewall separately for each game you want to play. Each game has specific TCP and UDP ports that need to be opened up to allow access. Its not a trivial exercise. You need to statically assign an I{P address to the PS3 and direct traffic from the router to the PS3 IP address for those games you want through. Each game has the details on which ports to open on the website or in the instructions. Lots of luck
Jan 13, 2011 | NetGear WGR614 Wireless Router
The router was open two days ago when I was playing the xboxlive suddenly the next day it changed to strict how can I change it back to open so I can play with my friends online?
Basically what happend is NAT closed instead of being open NAT. You have to log in to the router ip address in your web browser and set it to open nat. You get your router ip address by going to the command prompt and typing ipconfig. You can google this procedure or consult Netgear as they can walk you through it easily. Youtube has videos on how to open Nat on many different brand of routers. Now you know the problem and what the answer is please rate and comment!!! Thanks.
Dec 22, 2010 | NetGear WGR614 Wireless Router
Cant get full online with ps3
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Jun 17, 2010 | NetGear WGR614 Wireless Router
How do i change my NAT setting to open
On your router you can try to reduce the MTU settings .
If MTU is 1500 then make it 1365.
Also disable the firewall on the router.
You will also need to open the port number for the gaming Device.
You want the NAT open for the X-box or Play station ?
For this you will need to access the router set up.
After opening the ports , power cycle the router.
I hope the following link will help you.
Click Here for more info
Nov 12, 2009 | NetGear WGR614 Wireless Router
My NetGear Router will not let me video chat on xboxlive
Hi, You will have to open ports on the router for XBOX and for this you need to have a computer connected to the router.
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari)
2. Access the router, usually with or
3. Login to the router (Username = admin Password = Password unless you have changed it)
Create Services for the ports on the router:
1. Click on Services under Security.
2. Click on 'Add Custom Service' button.
3. Specify any name for the service (for example, XBOX1).
4. Specify the Start and the End Port as 88.
5. Click on 'Apply' button
6. Follow the steps 2 to 5 to create the services XBOX2 for the ports 3074.
Open Outbound rules for the services created using the steps below:
1. Click on 'Add' for outbound services.
2. Select the Service as the one that was created(like, XBOX1 in our case).
3. Select Action as Allow Always.
4. Set LAN users as Any and WAN users as Any
5. Set Log as Always and Click Apply
6. Follow the same steps for other services also.
Open Inbound rules for the services created using the steps below:
4. Set the 'Send to LAN Server' as IP address of the XBOX
5. Set WAN users as Any and Log Always
6. Click Apply. Follow the same steps for other services also.
Click Apply on Firewall Rules Page.
I hope this information allows you to resolve this issue.
Aug 21, 2009 | NetGear DG834PN Router (DG834PNAU)
these need to be primarily setup on your router...
and likely within your pc firewall if you have one.
What router do you have ?
What Firewall software are you running ?
Jul 21, 2008 | NetGear WGR614 Wireless Router
Netgear Firewall
with the router connected, open Internet Explorer and type after you log in there is a option on the left for firewall and you can turn it off. If it were me I would use the routers firewall over a software firewall though. By the time a software firewall detects a hack, its already in the PC.
May 19, 2008 | NetGear RangeMax WPN824 Wireless Router...
Xbox360 connection problem
The generic connection and configuration document
This is a good description of possible router options.
If you need assistance setting this up in your environment leave a comment on this problem and I will respond.
Dec 22, 2007 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
Top NetGear Routers Experts
Level 1 Expert
 Mike M
Mike M
Level 1 Expert
Are you a NetGear Router Expert? Answer questions, earn points and help others
