Question about Frigidaire FRS26R4A Side by Side Refrigerator
My side by side Frigidaire refrigerator is leaking water on the floor and into the freezer and freezing
  • 21 Answers
DRAIN IN BOTTOM REAR OF FREEZER IS STOPPED UP.DEICE WITH BLOW DRYER,USE TURKEY BASTER WITH HOT WATER.FORCE WATER THROUGH DRAIN.AFTER CLEARED ADD ONE HALF OZ.BLEACH TO DRAIN TO KILL ALGEA
Posted on Jun 25, 2009
SOURCE: refrigerator
my kenmore frig side by side did the same I flushed the freezer drain like the instruction book says but it leaked on the floor after A week.
I pulled out the frig unplugged it in the back I removed the bottom black cardboard grille and vacuumed the underneath and removed the black drain tube and flushed water through it and put it back that solved the problem and took about 15 minutes to do I hope this helps people who are having repeat trouble.
Posted on Jul 20, 2008
SOURCE: WATER LEAK IN FREEZER POOLING AT BOTTOM & FREEZING THEN MELTING
The problem was indeed a clogged frost water drain. I had to pull the frig out from the wall (found an incredible amount of dust accummulation in the alcove), then remove the vertical metal and horizontal cardboard covers to expose the drain catchpan. The 1/2" rubber drain hose end was only about 1/8" above the pan pointing directly into it perpendicularly. This was not enough clearance. There was a plug (formed by dust and water) in the end of the hose that came out easily when I 'roto-rooted' it with a screwdriver. The water flowed easily after that, but I went ahead and trimmed about 3/8" off the end of the hose and pushed it back into its slot. Then I cleaned as much as I could. The prevention is to keep the area behind the frig cleaned!
Bob
Posted on Nov 08, 2008
Sea Breeze
  • 4655 Answers
SOURCE: water leaking onto floor when defrosting automatically
There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are cased by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
SEA BREEZE TIP's
Posted on Sep 04, 2009
  • 86 Answers
SOURCE: My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Posted on Apr 20, 2010
SOURCE: Whirpool Imperial Series UltraEase II side by side refrigerator is leaking from underneath the left side.
no ice
Posted on Jun 06, 2010
Water dispenser does not shut off
That is most likely a dual water control valve stuck open on back of refrigerator near floor. One side feeds ice maker and other side feeds the water dispenser. If the ice maker side began to leak slowly it would create quite a mess of ice flowing over ice maker and freeze every place it could inside the freezer. Part and Model Search If helpful Please Rate this solution, Thank You, Sea Breeze
sea_breeze_260.jpg Refrigerators
Freezers
Washers and Dryers
Oct 18, 2011 | Frigidaire Refrigerators
Sometimes I see water under it. And the pan is always dry. Is there a clog somewhere in the line?
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 18, 2011 | Frigidaire FRS6HR45KS (26 cu ft) Side by...
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
Water is leaking in the bottom of the freezer, also coils are freezing up with ice, this problem is causing water to leak onto the floor from the freezer
when the cold coil is freezing up this is caused by a failed defrost system ( a bad heater or terminator . or the aditive defrost control . it also will freez the drain in the back of the freezer and this will cause the water to end up on the floor . . i would defrost the frig and repl the terminator . the heate is usualy good . and if problem comes back then replace the a d c . // the a d c pt # 241508001 and the terminator 5303918214 . this is a very common problem .. mm hope this helped and thanks for using fix ya ..
Oct 31, 2010 | Frigidaire FRS3R5EMB Side by Side...
The bottom on the freezer side has water leaking and it freezes on the bottom floor and leaks on to the outside floor
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
heatman101
Aug 27, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
Water collecting and freezing in bottom of freezer
Hi, Remove the rear inside panel of the freezer and locate the drain hole under the evaporator coil. Remove the ice and flush the drain hole with hot water to make sure it is free. You can try running a soft wire through the drain also.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 04, 2009 | Frigidaire FRS26R4A Side by Side...
Water leaking frigidaire frs23h5as
yes remove the rear panel in the freezer where you see the drain hole. Clear the ice from the drain hole. It will take a while for the water to start to drain because the ice is deep in the insulation. A small tube is helpful to draw some hot water in and stick in in the drain hole and squirt the hot water down in the hole.
Nov 25, 2007 | Frigidaire FRS23H5AS Side by Side...
FRIGIDAIRE FRS22ZRGD2
you may need to clean the drain tube again. the only other place that water may come from is the ice maker if it is over flowing. this however would be very obvious. use some thing like a length of cloths line cable to "snake" the drain after you defrost it. the fastest way to defrost it is to use hot water and a turkey baister. good luck.
Sep 26, 2007 | Frigidaire FRS26R4C Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
436 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
