Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Hi there.....I am REALLY hoping you can help me. We have a Honeywell automatic thermostat. Every year when we switch from heat to cool.....we cannot get cool air. Instead, it is getting hotter in here. I pulled off the cover and I see that there is one connector not attached.....is this the culprit. Please help, Adele
  • 67 Answers
If you have to switch from heat to cool, then tou don't have an automatic thermostat ---- you have a programmable heat and cool thermostat. For cooling mode you have to program in the temperatures you want for the various times of the day and days of the week. If you have a fan selector for auto or on, switch to on and see if the fan works. Let me know the results.
Posted on Jun 24, 2009
Honeywell thermostat...says thermostat not communicating with wireless network.
Carol,
Would really like to help but need more information. There are many Honeywell thermostats.
Semper Fi,
Z
Feb 18, 2018 | Honeywell Heating & Cooling
Honeywell thermostat will not work when put on automatic
Depends on what type of heat you have...if it is electric, it could be your thermostat (some electric heaters use contactors & rely on the thermostat to switch the fan on). Heat pumps also use the thermostat to switch the fan on in heat & cool mode. Most electric furnaces use a sequencer to switch the low speed of the fan whenever there is a call for heat. Gas furnaces use either a fan/limit controller (if the unit is older) OR a circuit board based on time (after the thermostat calls for heat). SO depending on the type of system you have, it could be a bad sequencer, controller, relay, thermostat, or control board. Hope that helps.
Dec 17, 2013 | Heating & Cooling
Manual for honeywell 3550d1006
Press the SYSTEM button to select Heat, Cool Off or Auto. Here is the manual. Check this link for more information on Honeywell thermostats
Feb 29, 2012 | Honeywell Heat/Cool Thermostat
How do I wire a Honeywell T410 Thermostat?
It is a switch, therefore power goes in on one side hot, and when the tstat calls for heat it closes and sends the power to the baseboard. Again this is a switch not a power consuming device. Hope this helps
Nov 03, 2011 | Honeywell Electronic Programmable...
HAVE A HONEYWELL THREMOSTAT TH8000 NEED WIRING HELP HEAT IS COOL COOL IS HEAT
Most of the time the white wire hooks to W and the yellow wire hooks to Y....... W= Heat Y= Cooling In any case if you are getting Heat when you set the thermostat to Cooling....... Turn the furnace off at the ssu or main breaker and then ... Pop the thermostat off of the subase and switch the wires that you have on Y with W and put the wire from Y to W.... Here is some more information on how a typical thermostat is wire in the pdf..... Hope this helps...
Here is a pdf for the installlation manual for a Pro 8000
http://www.hydro-temp.com/help/drawings/honeywell%2069-1894ES.pdf
May 05, 2011 | Honeywell Heating & Cooling
The thermastat will not stay as programmened? It blows cool air for long periods. I set it and seems like all is working then the next thing I know its off doing its own thing frustrating??? Please Help...
so its obviously an air con? are you running in automatic mode, if so that can be a problem as automatic yes is a good idea to maintain a set temp but it goes from heating to cooling so you heat an area and t/stat says its too warm turns heating off then goes over set temp so its starts cooling usually that is to do with the location of t/stat and set out of heater but automatic is useless and really is only good for offices where its not noticed like your own home, i tell people not to use automatic but set the control to what you want so if its cold you heat if its hot you cool you don't need both tassie where i'm from has four seasons in one day but i still don't think you need to heat and cool in one day the only place in the world that has such major condition changes is the sahara desert where it'l cook you during the day and freeze you of a night so if my assumptions right and you are using auto function DON'T. use what you need to either cool or heat your house not both in the same day it doesn't make sense and yes you can run it all year long on auto but its really not worth paying to run something you don't really need!
Nov 18, 2010 | Honeywell Programmable Thermostat Heater
Blower won't shut off on heat or cool cycles
Hi it souds like the afc is not working check the setings on it or clean the back of it /or replace
Dec 13, 2008 | Honeywell CT3200 5-2 Day Electronic...
Honeywell Old T874D1512 dual heat/cool thermostat
I think I understand what you are saying....First, that switch marked On and Auto, is to control the blower fan only. So when you switch that to On, it turns on the blower, but not the actual heat. It sounds more like a problem at the furnace then at the thermostat.
Nov 17, 2008 | Honeywell Consumer Products Mechanical...
Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Sep 30, 2008 | Heating & Cooling
Heating & Cooling Logo
136 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
