Frigidaire ,model no.mwv150kba
Good Morning Friend,
I understand that your Frigidaire microwave, model# MWV150KBA, sounds like it is running but will not heat. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes.
Once power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "Clock" button once for AM and twice for PM, enter in the time, and press the "Clock" button again.
Put a cup of water in for about a minute. If the water does not get warm, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your microwave and determine why it is not heating. Hope this is helpful.
-Best Regards-
WP
Thank you for your inquiry, Justin!
From the information you have provided your Frigidaire microwave is not turning and it has stopped heating up. It sounds like the motor, magnetron, or control panel may need to be replaced inside of your microwave. This could also be a miscommunication within your microwave and a reset could help clear it out. You can reset your microwave by flipping the household circuit breaker off for at least ten minutes. If that does not help correct your issue I would suggest contacting a professional technician for proper diagnosis and repair. I hope this information is helpful. -Matt
Good Morning Jim Cole, thank you for your post!
From what you are describing it sounds like it could be an issue within your control panel or door switch. I would recommend having a technician out to properly diagnose your Frigidaire microwave to avoid any unnecessary part purchases. I hope this is helpful. -Matt
Hello friend, thank you for your inquiry!
Sounds like there could be a potential problem with your magnetron, capacitor, or control panel inside of your Frigidaire microwave and that is why it is not heating. I would recommend seeking assistance from a professional for additional assistance towards a proper diagnose of your appliance. -Matt
