Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Won't drain
It won't spin either.
I believe the spin is locked out until water drains.
The problem may be the pump as a previous user suggested, however it could also be either a clog or hard water deposits.
Until you open the machine and visually inspect the pump, you can't state the problem.
  • 999 Answers
You can measure the voltage going to the pump in the spin cycle. If the voltage is there and the pump is not running you have your problem. Get some pinch off pliers and clamp off the hose going to the pump from the tub and you only have to deal with the water in the drain hose and pump when you pull the cleanout catcher to see if it is just plugged with something.
Eric
Posted on Jun 24, 2009
Duets washer won't drain
Probably a blocked filter, outlet pipe or pump.
Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
Dec 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
CHANGE DRAIN PUMP WASHER
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 02, 2012 | Whirlpool GHW9300 Duet Washer
Why won't washer drain/spin or allow me to open the door?
Hello Micheal,
The problem is going to be bex=cause the water didn't drain. This tip i wrote explains how to make it drain http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Won't spin and drain
Hello.
The most likely problem is that the drain pump screen is clogged so its not draining and if it isn't draining it wont spin.
To check the pump remove the lower panel and the lower right side will be the pump, unscrew the big white cap a little and use towel(s) to catch the water that comes out ,when all water out remove completly and check for blockage,
Good luck,i hope this helps
Gene
Aug 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer won't spin on spin cycle
Hi rapwizz,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Whirlpool Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Whirlpool duet Washing machine won't drain
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive or spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging.
May 11, 2011 | Whirlpool Washing Machines
Error code Sd (or 5d)
It means Suds Lock(Overdose of Detergent Detected During The Wash Cycle).If suds are detected continuously by the pressure switch during the drain or spin phases,the washer will fill 4 litres of water and during 5 minutes the unit will rest without tumbling,the water will be drained and it will try to spin or drain again.
If too much detergent was used:
– Run the unit through a Rinse/Spin cycle.
– Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,pressure switch and Central Control Unit(CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test.
Apr 11, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool duet won t spin continues to beep and
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 16, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool washing machine won`t spin or pump out
if youre handy with tools , check out the DRAIN MOTOR PUMP , usually located at the bottom on a side of the washer , it could be clogged with lint or debris , need to open washer , remove the DRAIN MOTOR , inspect inside to remove and clean it , be ready with rags , theres a lot of water that will come out once you remove it . good luck AJ
Jun 08, 2009 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
128 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
